Best Adhesives for Attaching Side Trim on Mazda 323 Front Door
dj-norek 85093 12
What should I use to reattach a heavy, rigid side trim on a Mazda 323 front door so it stays on securely?
Use a proper automotive double-sided tape, preferably the original/company type; forum users report it holds well for years and is used for moldings and mirrors [#1287619][#1295998][#1297240] If you want a stronger bonded fix, use windshield/glass adhesive or Terostat instead of ordinary store tape, because some users say cheap tapes fail sooner or later [#1287674][#1296108][#1296611] Clean the door and trim thoroughly, remove old tape residue, and degrease both surfaces before sticking [#1287674] One method is to warm the trim slightly so it becomes flexible, press it into place, and keep it held while the adhesive cures, ideally in a heated garage or overnight [#1287674][#1288696]
  • #1 1287576
    dj-norek
    Rate: 33
    I lost my side trim in the front door. With what to glue it so as not to lose it right away? The trim is quite heavy and rigid. The car is a mazda 323.
  • #2 1287619
    PIOTREL
    Help: 41
    Rate: 172
    There is a special two-sided adhesive tape for this type of trim. Ask around at automotive stores.
  • #3 1287674
    0__0
    Help: 115
    Rate: 101
    These tapes from stores are lousy - they will fall off sooner or later the original, used by the manufacturer of the car tape is double-sided adhesive aluminum tape, but such in stores do not exist.
    I always glue such parts with windshield adhesive (without using the primer (prime) just the glue itself. Clean the door and trim from dirt, residues of old tape and degrease it with gasoline.Then you should slightly heated
    the strip (heat gun with temperature control about 100 degrees or
    dryer), then it becomes flexible and easy to form it to the door, which are rarely ever flat
    apply glue and press against the door, I press the strip
    against the garage wall with wooden wheels.
    After a few hours, as the glue binds is not moveable.
  • #4 1288696
    yasiu.brzeg
    Help: 127
    Rate: 195
    I will agree with 0_0 while you do not need to fasten the slats to the wall just stick with paper tape overnight. Remember that the glue sets in positive temperatures. That is, only a heated garage. KUDOS TO
  • #5 1295998
    zbyszek lublin
    Rate: 21
    Buy the company's double-sided tape, it will certainly hold, I have had for 3 years and still have not fallen off, washed at the car wash and hold, why do you need any inventions
  • #6 1296108
    pelek
    Help: 34
    Rate: 34
    glue with terostat.Sooner you will break the whole door than the trim.In car assembly plants they glue the sheet metal with this among other things
  • #7 1296596
    dj-norek
    Rate: 33
    how much does such an original double-sided tape, glass glue or this terostat cost? and where to get it?
  • #8 1296611
    WBART
    Level 19  
    Help: 20
    Rate: 156
    glass glue about 20 zł only buy fasta it catches in two hours, I support colleagues, glass glue is an old proven way
  • #9 1296673
    Mathevp
    Level 19  
    Help: 14
    Rate: 75
    I use for this purpose a fast-bonding glue from the company Loctitte 406. It works great.
    You only need to remember to previously clean everything thoroughly and heat to at least 20 St.C.
    It has a disadvantage - you will never again peel the strip ;-)
    Greetings
    M
    PS. Loctitte to be purchased from PREMA store chain
  • #10 1296711
    Darexxx
    User under supervision
    Help: 9
    Rate: 9
    for resins try
  • #11 1297240
    Stefanek1
    Help: 46
    Rate: 237
    Double-sided tape the best possible, you will get at the plant dealing with car mirrors.
    They glue with this and moldings, checked .
    Pos.
  • #12 1299430
    Darexxx
    Help: 9
    Rate: 9
    Yes they glue, but for what price I went to such a station what they deal with it just when I was on the road and they charged me 50PLN for gluing the inner mirror for me a bit too excessive price greetings
  • #13 1303431
    Stefanek1
    Help: 46
    Rate: 237
    I, in Czestochowa on ul.Warszawska, made a large, smoky and spherical side mirror for a bus with disassembly of the old broken, cleaning of the plastic face and pasting the new, heating the whole thing, all for a whole 40.-zł, ie the mirror and labor. And also received a free piece of this very good tape.
    Bonding a rear-view mirror to the glass, inside the car takes no more than 5 minutes / with cleaning the old tape /,. then maybe you were mistaken about this "0" /zero /, or maybe you did not ask before, how much this service ???????
    Recommend this plant and greetings.
To reattach the side trim on a Mazda 323 front door, several adhesive options are recommended. Users suggest using specialized double-sided adhesive tape, although some express concerns about its durability. An alternative is windshield adhesive, which should be applied after cleaning and degreasing the surfaces. Heating the adhesive can enhance its flexibility and bonding strength. Other suggestions include using Terostat adhesive, which is known for its strong hold in automotive applications, and Loctite 406 fast-bonding glue, which requires thorough cleaning and heating before application. Users also mention sourcing these adhesives from automotive stores or specific suppliers.
