Repair Glass Heating Paths: Rear Window, Creating New Paths & Special Preparations
bati1986 79820 19
How do I repair broken rear-window heating tracks, and is any special preparation needed before making new tracks?
Repair the broken tracks with a silver-based conductive adhesive; it’s the usual material for this job and costs about PLN 25 [#6028878] Before applying it, clean the ends of the original track, mask both sides with tape, and apply the glue in thin layers rather than one thick coat [#7261088][#6029925] Let it dry fully before testing; the glue does not have to conduct immediately and may need 8–24 hours or even 24 hours before the first power-up [#7211882][#6029925] If the repair does not heat, check for another break in the same track, a blown fuse, or a damaged connector/damper adapter [#7211662][#6029781] Some users reported better results by applying 3 layers with about 3-hour intervals and re-taping each time, and then waiting a day before switching the heater on [#6029925] If the glued spot warms faster than the rest, that can be normal while the whole track is still heating [#7215559]
  • #1 6028846
    bati1986
    Rate: 29
    Does anyone know how to repair the glass heating paths? Are there any special preparations for creating new paths
  • #2 6028878
    malez4
    Help: 48
    Rate: 375
    There is a special silver-based glue, the cost is about PLN 25.
  • #3 6029017
    bati1986
    Rate: 29
    I tried it, but it cracked for a little bit, and it did not heat up, someone maybe a diagram of the paths connection
  • #4 6029075
    mr-perch
    Help: 94
    Rate: 287
    Connection scheme of paths? Did I read it right?
    | _____________ |
    | _____________ |
    | _____________ |
    | _____________ |
    It's something like this ...
  • #5 6029366
    Doktorr
    Help: 287
    Rate: 1098
    Well, unless it's a Peugeot combi with a separate window. This is a masterpiece and the question about the diagram is in place. In addition to the heater, the rear wiper and an additional stop flicker on the dusty paths. The paths rot before the eyes.
  • #6 6029781
    kybernetes
    Help: 426
    Rate: 1489
    If the track glue is cracked, it means that you applied it incorrectly (e.g. you did not clean it, applied it too thickly, you turned on the electricity too quickly - application instructions!), Or you used the wrong glue (old, unmixed, Chinese crap, etc.). Good glue holds very well, I have used it many times for repairs and I had no such complaint.
    It is best to check the power supply to the heating paths with an ordinary light. The reason for the lack of heating may be, for example, a blown fuse or a damaged damper adapter.
  • #7 6029925
    tomo19811
    Help: 23
    Rate: 103
    This is the way to go :) , I had silver-based glue {org Renault}, first you need to mix it well {this is the basis} then you know :) cover the tracks with adhesive tape on both sides, and apply the glue (I applied 3 layers with an interval of 3 hours, after each glue application I torn the tape off and glued it again during the next application, the point is that you will not apply glue perfectly to the width of the track and how you start to peel the tape once it dries, the glue layer starts to peel off the track and everything breaks down. The method described is extremely amateur :P , I honestly do not know how it is done professionally, but I will say yes .. out of 10 paths that the glass had, I had to do 8 and so far everything warms up as it should, also in more expensive cars {with glued glass} I see the sense of such a repair.
    I would like to add that the first connection to the electricity took place 24 hours after the last layer was applied.
  • Conductive adhesive failed to restore 3 cm heater break
    #8 7211568
    diabeel
    Rate: 119
    Today I bought Techicoll electrically conductive adhesive and did this:
    I taped over the broken tracks on both sides. A break in the path is about 3 cm
    I smeared it with glue and then spread it 3 times with glue only that I have such a problem that these paths still do not heat: / I broke the tape a moment ago and checked so it is just like other heaters and not ... when I smeared the paths, I turned on the heating of the glass for the test?
  • #9 7211662
    grzesiomix
    Or maybe there is another break somewhere on this path?
  • #10 7211681
    diabeel
    Rate: 119
    I checked very carefully and I did not find any other break anyway, it concerns 5 tracks. As the current was not so and there is no: / on the manufacturer's website I found information that the adhesive achieves conductivity after 8-24 hours, but it seems to me that it should conduct immediately?
  • #11 7211882
    MAROKESZ
    Rate: 32
    It should not and will not lead, because it has to dry. If you lack patience, they will do it to you in a glass replacement workshop and give you a guarantee.
  • #12 7214369
    diabeel
    Rate: 119
    and today I turn on the heating and the glass heats only in the places of gluing: / what did I do wrong and how to improve it
  • #13 7215559
    MAROKESZ
    Rate: 32
    The whole thread heats up, only the glued place faster and harder. Wait and look.
  • Pressing warmed glue joints restored heating continuity
    #14 7215616
    Przemo9826
    Help: 374
    Rate: 2502
    I also invested in such a glue, contrary to what everyone says in the instructions, it was written to turn on the heating, which will make the connection more durable and dry faster and that you can even dry it with a dryer. After an hour, the line did not work, but only the gluing point was warming up, I pressed this point with my finger, burned and the line started to heat up! I did the same on the other points and the effect was the same and still works today. It's probably not entirely professional and may not work for everyone, but I say how it was for me.
  • #15 7258209
    Gacol
    Rate: 67
    I have another problem, I have a broken contact that was (factory) "glued" (soldered ??) to the glass, how to fix it? this conductive glue doesn't hold that tight (tried) ...
    oh, the car is a Micra K12
  • #16 7260528
    MAROKESZ
    Rate: 32
    They do this successfully in some windshield assembly plants.
  • #17 7261088
    Piotr Pajkert
    Level 32  
    Help: 165
    Rate: 141
    Hello!
    For all these operations to be effective, the glass (or the damper with glass) must be removed. Additionally, clean the ends of the original track before applying conductive adhesive. I know it's a problem, but I suspect that's how the website does it. The end (connector) would be thinly glued with conductive glue and strengthened with glass glue. I have one in a tube. If someone wants, I will post a photo.
    Hi!
  • #18 7317204
    filterek110
    Rate: 8
    I did it in Honda (3 tracks) and the best glue is Epox15, two-component when it dries, it is hard as original. I bought some conductive varnish, but it was "kiszka" and I gave it to the store. resistance - is silver based.
  • #19 13283243
    ania_i_krzys
    Rate: 16
    Hello, does anyone have a detailed photo or a diagram of the distribution of the rear window heating paths in the Peugeot 308 SW after the lift - mainly vertical, because I wonder if all vertical paths should be connected. It looks as if these paths were never joined (at the very ends), the gaps are the same size, the ends are not torn, and you don't see that they are badly fused.
  • #20 15527744
    mat_ed_ison
    Rate: 23
    I will only correct my colleague from the above post that the glue is called Elpox15 ...
    • elpox215.pdf (140.72 KB) You must be logged in to download this attachment.
The discussion revolves around repairing glass heating paths, particularly for rear windows. Users share experiences with various conductive adhesives, notably silver-based glues and Techicoll electrically conductive adhesive. Proper application techniques are emphasized, including thorough cleaning, layering the adhesive, and allowing adequate drying time. Some users report issues with the heating not functioning correctly, suggesting potential additional breaks in the paths or improper application methods. Recommendations include using high-quality adhesives like Epox15 and ensuring the glass is removed for effective repairs. Diagrams of heating path connections are requested, particularly for specific models like the Peugeot 308 SW and Micra K12.
