Clio II 1.2 16v Engine: Understanding A2 and E2 in Valve Adjustment Procedure
spawacz4 80898 19
What do A2 and E2 mean in the valve adjustment procedure for a Clio II 1.2 16v engine?
A2 means the intake valve on cylinder 2, and E2 means the exhaust valve on cylinder 2 [#12470597] The thread also clarifies that A = intake and E = exhaust, with the number indicating the cylinder/valve position; on this engine, cylinder 1 is on the flywheel side [#12470551][#12470612] The “groove” mentioned in the procedure refers to the camshaft used for the overlap/passing method, where you adjust valves according to the specified sequence [#12470597]
  • Clarifying A2 and E2 camshaft groove markings
    #1 12470491
    spawacz4
    Rate: 32
    Hello I need to adjust the valves in Clio II with 1.2 16v engine on the electrode I found the advice:
    "The camshaft with a groove.
    This camshaft can be recognized by the groove
    located between the cams (A2) and (E2).
    Repeat the steps provided in the method
    valve adjustment specified above, with
    using the following adjustment values:
    - intake valve adjustment clearance: 0.25 to 0.32
    mm,
    - outlet valve adjustment clearance: 0.35 to 0.42
    mm,"
    My question is as follows what is A2 and E2
    Thank you in advance for your answer.
  • #2 12470527
    Przemo9826
    Help: 374
    Rate: 2502
    Do in passing.
  • #3 12470543
    mateuszhtml
    Rate: 11
    That is, how?
  • #4 12470551
    Przemo9826
    Help: 374
    Rate: 2502
    Educate yourself, it's not secret knowledge.
    I'll hint that in this engine the first cylinder is on the flywheel side.
  • #5 12470558
    mateuszhtml
    Rate: 11
    Cool thanks for your help.I'm waiting further maybe someone will be kind enough to write what's going on.
  • #6 12470567
  • #7 12470569
    spawacz4
    Rate: 32
    As far as I know Mijanka is the moment when the exhaust valve closes and already in the meantime begins to open the intake or colloquially co-opening of the valves. But how does this relate to A2 and E2 ?
  • #8 12470575
    mateuszhtml
    Rate: 11
    But people a colleague is asking not how to set the valves but what is a2 and e2. From what I have seen in this car counts the pistons from the right.
  • Renault valve-adjustment notation and piston numbering clarified
    #9 12470576
    Przemo9826
    Help: 374
    Rate: 2502
    He he, you disarm me :)
    You are speaking in a topic that is not yours, besides, I will not describe a method that has been widely known for years, taught in schools along with the basis of engine construction and widely described on the web. Maybe I still have to insert pictures especially for you? Because you are so lazy and look for you do not want to?
    mateuszhtml wrote:
    just what is a2 and e2
    The renault came up with, but it is better on the passing, more convenient.
    mateuszhtml wrote:
    From what I have seen in this car counts pistons from the right.
    You've been....
    spawacz4 wrote:
    from what I know Mijanka is the moment when the exhaust valve closes and already in the meantime begins to open the intake or colloquially co-opening of the valves
    You see the froth? The questioner got trained, read, thought, take an example.
  • Clarifying A2/E2 positions and camshaft groove identification
    #10 12470587
    mateuszhtml
    Rate: 11
    No thanks for the pictures because it's already the coil cables themselves show where 1,2,3 ,4 is but smaller what is A2 AND E2 is it between the second one on the outlet and the second one on the intake ?
    God man you wrote :Sobie renault came up with, but it is better on passing, more convenient.
    I know how to set the valves, but in the clio you have two shafts one with a groove between a2 and e2 and the other without a groove and the question is what is a2 and e2 and not how to set the valves.The point is to find out how to find the groove according to which you set because there are two options because of the two shafts clear?
  • Clarifying valve overlap for setting valve clearances
    #11 12470595
    spawacz4
    Rate: 32
    Przemo9826 wrote:
    spawacz4 wrote:
    as far as I know Mijanka is the moment when the exhaust valve closes and already in the meantime begins to open the intake or colloquially co-opening of the valves
    You see the froth? The questioner has trained, read, thought, take an example.
    From my profession as a Mechanic Technician my knowledge is :) To sum up I am looking for a pass-through then we set the valve clearance am I combining well ?
  • Intake and exhaust valve numbering clarification
    #12 12470597
    Przemo9826
    Help: 374
    Rate: 2502
    (A1) Cylinder intake valve 1
    (A2) Cylinder intake valve 2
    (A3) Cylinder intake valve 3
    (A4) Cylinder intake valve 4
    (E1) Cylinder exhaust valve 1
    (E2) Valve Cylinder exhaust valve 2
    (E3) Cylinder exhaust valve 3
    (E4) Cylinder exhaust valve 4
    If you are setting up for passing then you can have a shaft without a groove with a groove and God knows what else, that's why I say that it's better on a passing engine.
  • #13 12470612
    mateuszhtml
    Rate: 11
    Well, and now it is clear and just a moment ago I learned that these A2 and E2 are explained that :
    A- is the intake - apport(French)
    E- is the exhaust - épuiser
    A 2 is the cam number.
    Now I will find this groove because I know where it is and I will set myself to pass.
    I know everything and greetings.
  • #14 12470616
    Przemo9826
    Help: 374
    Rate: 2502
    Well, but you don't need this data, you can have bare shafts without any markings then you will always make a pass.
  • #15 12470623
    mateuszhtml
    Rate: 11
    And you wrote with or without a groove there is no difference, because with a groove there is probably 0.30 and 0.40, and without a groove some other value, probably 0.15 and 0.25.
  • #16 12470628
    spawacz4
    Rate: 32
    So to recap the topic. Setting to pass is:
    Set co-op on the first then adjust the clearance on the 4th cylinder then co-op on the second and adjust on the third, co-op on the third then adjust on the second
    Did I understand correctly?
  • #17 12470632
    Przemo9826
    Help: 374
    Rate: 2502
    mateuszhtml wrote:
    And you wrote with or without groove it makes no difference well it does, because with groove is given there I think 0.30 and 0.40 and without groove some other value I think 0.15 and 0.25.
    I wrote about the method.
    spawacz4 wrote:
    Did I understand?
    Good boy.
  • Questioning which valve-clearance specifications apply without the identifying g
    #18 12470639
    mateuszhtml
    Rate: 11
    Well I know, but I don't mean the method I meant what kind of data should I choose or those 0.30 and 0.40 or those from the book from the repair of the clio, and to know this you would have to check this groove.
    Unless the mechanic fooled me and there are not two different shafts in these clio, but I see that the moderator himself advised someone how to give this groove 0.30 and 0.40, and I from what I saw today I do not have this groove.
  • #19 12731960
    spawacz4
    Rate: 32
    Valves set, forum knowledge solidified greetings :)
The discussion revolves around the valve adjustment procedure for the Renault Clio II equipped with a 1.2 16v engine, specifically clarifying the terms A2 and E2. A2 refers to the intake valve of cylinder 2, while E2 denotes the exhaust valve of cylinder 2. Participants emphasize the importance of recognizing the camshaft groove for proper valve clearance settings, which are 0.25 to 0.32 mm for intake valves and 0.35 to 0.42 mm for exhaust valves. The conversation also touches on the method of setting valve clearances and the potential variations in camshaft designs, leading to different adjustment values. Ultimately, the author successfully completes the valve adjustment, confirming the utility of the forum's shared knowledge.
