Renault Clio II ph 2 - Humming, knocking to the rhythm of driving
zbyszek100 4731 4
  • #1 16379923
    zbyszek100
    Rate: 207
    Hello, I have a problem in Clio II 75KM / 55kW 1.2 2001 gasoline with hum probably in the rear wheels, I'm not sure from which side. From 70 km / h there is a humming, knocking noise that makes sounds faster as speed increases. Until now, I thought it was humming from winter tires, but yesterday I changed to summer and it's even louder. There is silence on the reverse. I also noticed that when I turn left there is a very similar noise, as if something was rubbing against something, when it straightens it is quieter. It does not go to the right.
    Additionally, when starting, braking, downshifting (when it jerks the car) it creaks and grinds teeth just like a human. The sound is not muffled, it can be heard quite well on the right side, more in the front.
    Bearing? I am asking for tips.
  • #2 16379942
    jenusz11
    Help: 33
    Rate: 196
    the bearing is definitely a hum and this grinding can also be caused by it if it already had a large play or something else broken or not tightened in the suspension
  • #3 16380169
    zbyszek100
    Rate: 207
    it's also possible it's a pillow?
  • #4 16380177
    web69
    Help: 188
    Rate: 629
    Remove the brake drum, check the shoes, spacers and other springs. and rather fast, because you can wring out unwanted oberek ...
  • #5 16404285
    zbyszek100
    Rate: 207
    ok bearing replaced and silence while driving, until nice (rear left wheel). The crackling problem remained when starting, braking, and now what I noticed when driving backwards. In the video, the car is on the manual and I slowly release the clutch, you can hear this creaking (it is not caused by the hand brake, because if the clutch is too loose, it makes a different sound).
    https://www.youtube.com/watch?v=NB6YdEOAvkM
    Brake? Maybe exhale?
