VeraLite and Danfoss Living Connect - no temperature reading, heating indicator light
blur 6411 14
Why does a Danfoss Living Connect thermostatic head in VeraLite always show 0 for current temperature and not respond to the heating on/off indicator in the Vera UI?
The Danfoss Living Connect head does not report the current room temperature to Vera; it only provides the target room temperature, so seeing 0 for the measured temperature is expected for this model [#12828211][#14247866] The Vera on/off heating control in the UI does not work properly for this thermostat because it is a Vera software limitation, not a fault in the head itself [#12828211] If you want temperature-based regulation, use a separate room sensor such as an Everspring ST814 [#12828211] Vera also has limited support for floating-point numbers, which restricts temperature control logic [#12828211] If the thermostat does not respond at all, first remove it from the radiator before pairing and make sure it is the Z-Wave version marked Living Connect @Z [#14247866][#14293581]
  • Danfoss thermostat reports zero temperature and lacks heating indicator
    #1 12476872
    blur
    Help: 12
    Rate: 58
    Welcome,
    i am currently testing the micasaverde VeraLite system, to start with I decided to pair this with a Danfoss Living Connect thermostatic head. The process itself went without any problems and the head responds to commands, however I don't think it works 100%, the first issue is that it doesn't read the current temperature (always "0")and the second is the on/off heating light. I don't know if this is the way it is supposed to be or if I still have to paste in something on foot ? the software in the heads is SW 2.51
  • #2 12746678
    chrobry25
    Rate: 76
    Buddy can you write something more - did you do further tests ? How about this temp reading ?
  • #3 12746839
    blur
    Help: 12
    Rate: 58
    I will sooner finish my Z-Wawe temperature sensor as I figure out this reading.
  • #4 12828211
    martyr
    The Danfoss head in the system does not show the current temperature only the temperature value to be in the room (with a relatively large error of +-1st). The on/off switch in the UI does not work either (software issue in vera).
    If you want to regulate the temperature from the sensor you have to use a separate device e.g. Everspring ST814. Please note that at the moment the VERA soft does not support floating point numbers so the temperature control logic is severely limited (a new UI is reportedly being developed which will use commas).
    I have been using the VERA system with Z-WAVE nodes (from various manufacturers) for a long time and so far (apart from the aforementioned floating point problem) everything works OK.
  • #5 12992350
    blur
    Help: 12
    Rate: 58
    I am just testing the Stella Z head, this one has an outside temperature reading but the Vera shows a bunch of buttons that are not used :) i.e. cooling and on/off.
  • Danfoss thermostats pair but reject software commands
    #6 14236157
    pito3625
    I have an identical one and a VERA lite controller.
    Have you perhaps managed to solve the communication problem with them?
    Danfoss paired me with the controller shows the temperature but I can't do anything through the software, it shows some communication error. On the head the bell and the connection icon flashes.
    Stella on the other hand shows all these icons like yours and doesn't respond to commands either.
  • #7 14236331
    blur
    Help: 12
    Rate: 58
    Where did I write that I have a communication problem ? maybe you bought a version without Z-Wave ? it reports but you can not do anything, a friend recently bought so :) read what you have on the sticker must write Living Connect @Z
  • #8 14241664
    Jacek79
    Level 37  
    Help: 233
    Rate: 1132
    There is a lot described in the fibaro forum about heating control
  • Pairing procedure may explain software control failure
    #9 14241909
    pito3625
    blur wrote:
    Where did I write that I have a communication problem ? maybe you bought the version without Z-Wave ? it reports but you can't do anything, a friend recently bought :) read what you have on the sticker it must say Living Connect @Z
    It occurred to me that Since not everything is working 100% for you then you have a communication problem with the thermostat. That's what I have. On the sticker I have it working fine.
    The controller sees the heads but I can't through the software set anything. Can you tell how you paired the heads with the controller? Because I think this is the problem here
  • #10 14247866
    blur
    Help: 12
    Rate: 58
    Everything works 100% for me, I just "thought" that you could read the temperature from the head sensor, but the manufacturer did not provide this for this model, the Stella-Z instead has this possibility. To add the head you have to remove it first, that's the trick. https://www.youtube.com/watch?feature=player_detailpage&v=yXqFmBvhigQ listen clearly to what the guy says from 6:56
  • #11 14248045
    pito3625
    ok thanks a lot.
    I think I managed it yesterday. It seems to be working. I'm going to test it out.
    I will also add a stelle today to see how it hula.
  • #12 14251407
    pito3625
    supposedly this danfoss is added, I do everything like this guy.
    I see it on the controller on the website.
    I set a scene of some kind and the temperature changes on the display and the heater doesn't change temperature. I don't get it.
    Maybe at Christmas I'll check something else out, or I'll wait for a friend who has a head like this to help me out
    Merry Christmas
  • #13 14293581
    blur
    Help: 12
    Rate: 58
    The question is did you first remove this device before adding it ? are you sure you have a Z-Wave head ? this is exactly the symptom when the head is not in Z-Wave
  • #14 14293747
    pito3625
    The head works. Everything is already ok.
    With the stella I still have a problem, but I don't know if it's not a problem sometimes with the physical connection to the radiator. I will keep trying.
    Thanks for your help in any case.
