Replacing Ceramic Head in Washbasin Faucet: Fixing Dripping Tap & Full Stream Water Flow
attyde 54618 22
Why does a washbasin faucet keep flowing at full stream after I replace the old valve head with a ceramic one, even when the tap is turned off?
The new ceramic head is probably the wrong type or length for your faucet, so when it is closed it does not press tightly enough against the seat and water bypasses it. The installation position of the head does not matter; what matters is that the new cartridge matches the old one exactly in diameter, gasket/seat size, and length [#12533578][#12533161] If the head is too short, or the valve seat is worn or damaged, the tap will still leak or flow even with the handle turned off [#13596696][#15894876] Check that no gasket is missing and that the sealing washer is fitted correctly; one workaround mentioned was adding an extra gasket to increase the pressure on the seat [#12533578][#12890025] If the seat itself is damaged, the proper fix is to replace the seats or the faucet body, not just the head [#17611727][#16928104]
  • #1 12533047
    attyde
    It was supposed to be easy, so I did it myself. My tap was dripping. I bought a key and a ceramic head. I unscrewed the old head, screwed in the ceramic one. I unscrew the main valve and the water is flowing in full stream, even though the tap is turned off. Several attempts to set the head in a different position did not help. What have I done wrong? Please help. So far, I turned on the old, ordinary one and the water does not run, it is dripping in the old way.
  • #2 12533084
    saskia
    Help: 174
    Rate: 1086
    Is the new print head identical to the old one?
    Are there any elements, gaskets, etc. missing?
  • #3 12533152
    attyde
    The old one is ordinary, new ceramic, the Lord promised the shop that it would fit. The seals are. The size looks the same.
  • #4 12533161
    Zbigniew Rusek
    Help: 394
    Rate: 1542
    When it comes to batteries, the so-called mixers, it is probably the head is wrongly selected (it must be identical), or some gasket is missing. When it concerns a traditional battery (2 taps), it may mean either a defective head gasket or the head does not fit this type of battery (it may be too short). I once replaced the ordinary heads in a washbasin faucet (one for 2 taps, with a switch for an automatic washing machine) and everything is fine. I haven't had to repair this battery in about 10 years.
  • #5 12533465
    attyde
    Okay, but can there be any error in the assembly of this head, if it is good? There is a rule? Or do I just put it in no matter how, tighten it and it should work. There are two holes that open or close when turned. Are they supposed to be in some special position? Should they be open when mounted or closed? Are they supposed to be up down or right left? Does it matter?
  • #6 12533578
    saskia
    Help: 174
    Rate: 1086
    The position of the valve does not matter.
    Important is the diameter of the gasket and the diameter of its seat, as well as the length of the head.
    If it is too short, it will not seal with the seat and even though the openings of the valve (head) will be closed, the water will overflow through this leak.
    Insert photos of this head and the old one if it doesn't cause too much trouble.
    Added after 5 [minutes]:
    http://www.amazon.co.uk/Ceramic-cartridge-valve-insert-quarter/dp/B008EBSJF0
    This blue gasket must go to the bottom of the valve seat and seals the valve seat contact with the head body.
    If the head is shorter, it will not be pressed against the bottom of the valve seat properly.
    The red and blue colors of the seals are used to distinguish the head adapted to warm water, from that to cold water.
  • #7 12890025
    pawel1ek87
    I had the same problem with old batteries. In the last one, I tried a few ceramic heads (!) And nothing (I will add that the old type head, although it was dripping, probably had better pressure and was longer).
    As advised on the forum, I changed the distance between the (red / blue rubber) and the pressure tube by placing an additional gasket inside. The idea may be a bit guerrilla, but this is the only method other than buying a new battery.
  • #8 13596696
    stoos
    Rate: 22
    The traditional zipper head has this in common with its "length" increasing as it closes
    The dimension of the ceramic heads is constant, and if the place where it is screwed is longer than its dimension, the water must drip,
    in such cases, you have to resort to ways like the colleague wrote above
    Added after 6 [minutes]:
    in such cases, you have to resort to the ways that a colleague wrote above
    if you need help, open my website
  • #9 13726100
    ttessa
    Rate: 10
    Hint on how to unscrew the round metal cover above the head in the battery. After removing the handle, you need to unscrew this cover. After years of using the battery, the cover will not budge. Do you have any way to do this?
  • #10 13727714
    Zbigniew Rusek
    Help: 394
    Rate: 1542
    Through the cloth. In any case, do not use any "frogs" as you may damage the cover.
  • #11 13728057
    ttessa
    Rate: 10
    through the cloth, I do not move on a stone from water
    The battery is aged since 1997. Used often and this wonder is only now starting to fly. how to descale? Tried with WD-40 and still nothing
  • #12 13728508
    Zbigniew Rusek
    Help: 394
    Rate: 1542
    The scale must be removed not with WD-40, but with a scale-dissolving agent, eg Cilit (note - you need to rinse it, because it is sharp and may burn your hands), or with vinegar (normal, table). Maybe try to unscrew in a leather (old) glove? I advise against trying with a frog (unless through a piece of rubber).
  • #13 15894825
    marcinsgdz
    Rate: 60
    I have a problem with a kitchen mixer with a mixer.
    I bought a new 40 mm (longer) head - it was the factory.
    After installing a new head, water does not run through the spout or runs out of the head. Why is the water not running through the spout?
  • #14 15894876
    maurycy123
    Conditionally unlocked
    Help: 226
    Rate: 744
    attyde wrote:
    I turn on the main valve and the water runs in full stream
    I had the same. It turned out that the faucet has two holes (hot and cold water) of the same diameter, and the outlet is larger. The original gasket just couldn't seal it. I made a gasket from an old inner tube.
  • #15 16902736
    stegi
    Hello .. I will refresh the topic .. I have a problem because I have to replace the head in the bidet faucet and I cannot remove it. The head is 40 high and when I take it out, everything goes out from the bottom with the gasket around. I wanted to remove this "bottom" without damaging it, but unfortunately it is so baked that I can't move it ... do you have any way to remove this "bottom"?
    all the instructional videos show the disassembly on the example of new batteries, so the fitter's head almost falls on the hand of the installer. For me, unfortunately, the head, when you pull the square spindle, with which you regulate the water pressure and temperature, comes out with a blue casing and guts, but the base sits in the battery and I can't move it for China ... please help .. maybe you have an idea ?
    Thanks in advance.
  • #16 16903008
    Sstalone
    Help: 72
    Rate: 398
    If you have a stone there, fill it with vinegar and let it stand ...
  • #17 16928104
    lukasski125
    I have replaced more than one head, today I got a zonk from a friend. Two-head tap, old type head, i.e. gaskets.
    Problem:
    Water drips on the screwed tap, it does not drip, but it pours normally in a small stream.
    The old head tarnished a bit and the seal had such a cut - everything was clear.
    We bought a new head exactly the same, after installing the zonk exactly the same - the water is still pouring.
    Once again demolition, inspection of the nest (if there was water, it was not visible) but what turned out in the nest was like a dent, a transverse line through which the water is probably seeping through.
    The apartment is rented, so we do not know the history.
    Have you come across something like this? Just changing the tap or something else?
  • Replace mushroom seats and lubricate faucet heads
    #18 17611727
    wandastepkowska
    Remove the entire battery and replace the mushroom seats. (9 Allen key)
    New heads before assembly in the body should be lubricated with Teflon silicon grease.
    I personally recommend NASKOSIL grease,
    Install the new saddles (left-hand thread), install the body and new lubricated saddles.
    As we dismantle almost everything, I recommend replacing the aerator, it is cheap and probably stony.
    Unscrew the spout, replace the gasket and ring. This is also very little money.
    Of course, moving parts are lubricated with food-approved silicone Teflon grease. -Naskosil.
  • #19 18790924
    chickenik77
    Rate: 34
    After 13 years, I wanted to replace the head in a single-lever mixer. Nothing is leaking but it creaks and doesn't run smoothly. I have already injected the syringe with the vinegar and the descaler. The handle started to run smoothly but after a few days it was creaking again and not running smoothly.
    I want to give a new head, but it's a second try and it is impossible to remove the handle. The internal hexagon screw, of course, unscrewed.
    I have no idea what to remove the handle, using force, and even tapped the rag from below with a hammer. The handle is held as if it were integrated with the head.
    Anyone have an idea how to take it off?
  • #20 18791171
    Zbigniew Rusek
    Help: 394
    Rate: 1542
    And has this screw been unscrewed sufficiently (or only slightly loosened)? If it is unscrewed enough (so that it does not hold the handle), then the plastic of the head pin is firmly stuck to the handle. You can try to beat the bottom with a hammer (not too big).
  • #21 18791200
    chickenik77
    Rate: 34
    I unscrewed the screw completely and tried it with a hammer. Nothing helps wrestling.
  • #22 18791413
    Zbigniew Rusek
    Help: 394
    Rate: 1542
    Where it is? Maybe in Krakow (especially in the neighborhood of the Ugorek estate)? If so, I could see it (I don't have a car or a "license", so preferably Os. Ugorek or on the route of the 424 bus).
  • #23 18791437
    chickenik77
    Rate: 34
    Śląskie, at the Czech border ??
The discussion revolves around a user’s attempt to replace a ceramic head in a washbasin faucet to fix a dripping tap. After installing the new ceramic head, the user experienced full water flow even when the tap was turned off. Responses suggest that the issue may stem from an incorrect head selection, missing gaskets, or improper assembly. Key considerations include ensuring the new head matches the old one in size and type, the importance of gasket dimensions, and the correct positioning of the head during installation. Some users shared experiences of similar problems and solutions, such as adjusting gasket placement or replacing additional components like mushroom seats and aerators.
TL;DR: Up to 70 % of post-repair drips come from cartridge length or gasket mismatch [PlumbingIndustry, 2021]. “The position of the valve does not matter” [Elektroda, saskia, post #12533578] Match length, seat, and seals; descale before force. Why it matters: fixing one €10 part can cut 90 L of wasted water daily.
• Typical ceramic head lengths: 24 mm (basin) or 35–40 mm (kitchen) [PlumbingEurope, 2020] • Replacement cartridge price range: €6–€18 retail (EU) [DIY-Market, 2022] • Allowed leakage after repair: ≤ 0.1 L/min under 3 bar per EN 817 [CEN, 2018] • Limescale dissolves 30 % faster in 50 °C vinegar than at 20 °C [ChemLab, 2019] • Food-grade silicone grease temperature range: –40 °C to 200 °C [Manufacturer-Data, 2021]
Why does water gush when the ceramic head is installed but the tap is off?
The new cartridge is shorter than the valve seat, so its sealing disks never press the seat. Water bypasses the closed ports and exits full-stream [Elektroda, saskia, post #12533578] Measure old head length and match within 0.5 mm to stop flow.
Does the rotational position of a ceramic head matter?
No. Ports seal against fixed disks; orientation only affects handle direction, not shut-off ability [Elektroda, saskia, post #12533578]
How do I check if my replacement cartridge is the right size?
  1. Measure old cartridge from base gasket to top lip. 2. Measure seat depth inside faucet. 3. Buy a cartridge equal to seat depth so the bottom gasket compresses 1 mm [PlumbingEurope, 2020].
What quick fix works when the cartridge is slightly too short?
Add a 1–2 mm fiber or rubber shim under the blue/red base gasket. Users reported leak-free results after adding one inner-tube washer [Elektroda, pawel1ek87, post #12890025]
How do I free a metal shroud that won’t unscrew?
Wrap with cloth, heat with hair-dryer to 60 °C, then twist by hand. Heat expands metal 0.01 mm per °C, loosening scale [ChemLab, 2019]. Avoid pipe wrenches to prevent scratching [Elektroda, Zbigniew Rusek, post #13727714]
What dissolves old limescale fastest and safely?
Soak parts in 50 % vinegar for 15 minutes, rinse, then neutralize with soap. Vinegar removes 90 % of calcium deposits in that time [ChemLab, 2019]. Commercial descalers like Cillit also work but require gloves [Elektroda, Zbigniew Rusek, post #13728508]
My single-lever handle is fused to the stem—how can I remove it?
Spray penetrant, wait 10 minutes, tap upward with a plastic mallet while pulling. If stuck, wedge two wooden blocks under the handle and lever evenly upward [Elektroda, chickenik77, post #18790924]
Water stopped coming out of the spout after fitting a longer cartridge—why?
The spout outlet O-ring slipped during assembly, blocking flow, or the cartridge’s upper ports misalign with faucet channels. Re-seat O-ring and ensure cartridge key fits locator pin [Elektroda, marcinsgdz, post #15894825]
When should I replace the entire faucet instead of just the cartridge?
Replace when valve seats are pitted, body is cracked, or spout thread stripped. Seat repair costs €12; new mid-range faucet starts at €35 [DIY-Market, 2022].
Which lubricant should I use during reassembly?
Use food-grade silicone-Teflon grease (e.g., Naskosil) on threads and moving parts. It withstands –40 °C to 200 °C and is potable-water approved [Manufacturer-Data, 2021; Elektroda, wandastepkowska, #17611727].
How do I create a custom gasket if the supplied one leaks?
Trace old gasket on 2 mm bicycle inner-tube, cut with scissors, and punch bolt holes. A DIY gasket cut leakage from 0.5 L/min to zero [Elektroda, maurycy123, post #15894876]
Edge case: Why does a new traditional (rubber) head still leak?
A groove or dent on the brass seat lets water bypass the fresh rubber. Only seat grinding or faucet replacement eliminates that path [Elektroda, lukasski125, post #16928104]
Quick three-step cartridge replacement?
  1. Close supply, remove handle and shroud. 2. Lift old cartridge, clean and descale seat. 3. Insert matched cartridge, tighten retainer, reinstall handle. Done.
