Dolce Gusto Krups 1006 Piccolo: Water Not Consumed and Machine Not Functioning Properly
socjolog2013 84237 16
Why does a new Dolce Gusto Krups Piccolo heat up and light normally but not draw any water, and how can I prime it?
The pump is most likely air-locked and needs to be primed with water before it will draw normally [#12544448] The simplest fix reported is to force water into the pump inlet/suction hose with a syringe until the pump starts humming and moving water [#13555182][#17704037] Another working method is to repeatedly lift and lower the water tank many times so bubbles come out and the hose gradually fills; once the water level reaches the pump, the machine usually starts pumping after several seconds [#18060175][#18657594] One user also confirmed that after priming, the pump became quieter and the flow returned, but in a later case a bent needle in the capsule head still had to be straightened [#20002238] If the machine is new and still under warranty, it is also reasonable to use the warranty instead of disassembling it [#12546356]
  • #1 12544184
    socjolog2013
    Rate: 10
    Since yesterday, I have been the owner of the Dolce Gusto 1006 coffee machine and I have such a problem - the first time I used the coffee machine, it only hummed, i.e. it was audible that it was working, but no water was consumed. Now, when you turn it on, you do not even hear that it works, only the diode is on - when turned on, it flashes red, after 30 seconds it turns on green - which is probably ok? The coffee machine is supposed to be warm, that is, as if the heater was working, but neither the water heats up, nor is it consumed. What could be wrong?
  • #2 12544448
    nioop
    Home appliances specialist
    Help: 503
    Rate: 3329
    Maybe there is air in it? You would have to help him and push the water with a syringe after disassembling the coffee machine ..
    Is it a new or used coffee machine?
    Kawa i Naprawa - Serwis AGD
  • #3 12544980
    socjolog2013
    Rate: 10
    The coffeemaker is new ... I'll try with this syringe
  • #5 13554269
    horus21
    I have the same problem, only the machine is after the warranty. When I attached a syringe to the tube, I thought it was air-poisoned, and I injected water, it went - both heated and cold. As soon as I put the tank on, it's nothing - no reaction. The espresso "does not hum". I removed the phoenix-50 b2p pump, I thought that I would discover something but nothing. How to check if the pump is working and whether the capsule container really has to be inserted for the pump to work?
    And one more question: Two metal sleeves and one plastic fell out of the pump. Should they be arranged in the same order as in the picture ??
    • _DSC0349.JPG (301.49 KB) You must be logged in to download this attachment.
    • _DSC0348.JPG (194.41 KB) You must be logged in to download this attachment.
  • #6 13555182
    nioop
    Help: 503
    Rate: 3329
    Yes, without a "container" for capsules, the pump will not start ..
    Connect the pump to 220V, you should hear its loud operation.
    The sleeves are correctly positioned. Connect the pump and check if it is humming.
    It will probably buzz .. ;)
    So when the pump is operational, take a picture of the inside of the coffee machine and I will explain to you two simple methods for repairing the equipment ..
  • #7 13568495
    Kris1809
    Help: 5
    Rate: 134
    I warmly welcome! I do not know how a colleague upstairs wants to assess the efficiency of the pump after "hum"? Take it out of the coffee machine, connect it with a power cable with connectors for 230 variable power supply, take two hoses, look at the direction of water flow, connect and see the effect. Or look at the magnetic water sensor, put the magnet to it, detach the pom pom from the circuit and check it. Greetings!
  • #8 17019112
    pirat1001
    Rate: 12
    I had the same situation. The pump is working, but no water is flowing. After disassembling, I only made sure that the wires and the needle were not obstructed. I used a 50 ml syringe. I used Teflon tape as an adapter. First, however, "dry" I pushed the remnants of the water that was in the hose supplying the pump. Something gurgled. Then I connected the full syringe already. ... And everything moved. Prophylactic descaling and cleaning. Great coffee ...
    • Dolce Gusto Krups 1006 Piccolo: Water Not Consumed and Machine Not Functioning Properly IMG_20180207_082932.jpg (4.8 MB) You must be logged in to download this attachment.
  • #9 17702862
    rolando13
    it's the same for me. suddenly the coffeemaker stopped working and did not start, even though I undressed the whole thing and blown it with compressed air.
    I did not do one - I did not pour water on the pump and the question is is it necessary? I assume new equipment from the store that the inside is 100% dry without any liquids?
    the needle itself - should it slide out or is it fixed / stationary?
    I rather have option 2.
    The machine is 3 years old, used from case to case. I will be happy to fix it, if not, unfortunately, in the garbage can :( .
    can you do anything?
    PS. after turning on it heats up and buzzes, in my opinion something is clogged. I cleaned the needle with a pin.
  • #10 17704037
    DarekTorun
    Help: 6
    Rate: 9
    It seems to me that "flooding" alone may not help. I would have to fit a syringe to the suction hose from the pump. When the pump hums the syringe, you need to push the water under pressure. When it clicks, you need to quickly turn off the pump so that it does not suck in air again
  • #11 17704861
    rolando13
    okay, I'll do it, I'll try.
    What about that needle?
  • #12 17710728
    pirat1001
    Rate: 12
    The needle is integrated into the module and is stationary
  • #13 18060175
    carriermistral
    Rate: 26
    I use my coffee machine every few months or even every few years and airing is a standard. I did not use syringes because sealing such a system and looking for a syringe is a bit of a chore. The easiest way is to pump the water with the reservoir - you have to take it off and put it in many times - you will see floating air bubbles in the water, and if someone has already removed the part of the casing from the pump side, you will see how the water level in the hose gradually rises - when it is slightly above the halfway point between the tank and the pump, you can start the coffee machine and the pump should draw after a dozen or so seconds - it helped me so much.
  • #14 18657594
    WaLeC_TW
    Rate: 23
    Hello dear forum members.
    I thought that I would also add my 5 cents to the topic.
    I had a similar symptom myself. Express was humming but did not pick up any water.
    I made a solution that has popped up here several times.
    Namely, fill the container with water, it does not have to be full. Then many times, really many times from 30-40 times I raised it to a height of 2 cm and lowered it. Each time I saw bubbles coming, i.e. the pump flooded inside with water. After a dozen or so times the attempt, the water gently leaked, so I knew it was close, I picked it up several times and then another attempt and it sucked.
    After that, I personally conclude that if the express has a break of several months, it will announce itself. It's even normal for me, the water from the pipes will dry up and you need to bleed it.
    I would like to thank those people who throw up such cool, meaningful and working solutions here.
  • #15 19450006
    Emilian777
    I confirm the effectiveness of this patent!
    My friend spared me disassembling the contraption :)
    Thanks a lot!
  • #16 20002238
    juhas444
    Previous comments and hints were very useful. In my case, after such venting, you could hear the pump filling up and it started to work quieter. The water still didn't fly. Straightening the needle sticking into the capsule helped. I used a 0.4mm rod for inserting nozzles for 3D printing. You have to be careful after the hot water bursts. Better to wait a while.
  • #17 20440350
    vickier
    I also confirm that the patent with the tank works
✨ The Dolce Gusto Krups 1006 Piccolo coffee machine is experiencing issues where it does not consume water and fails to function properly. Users suggest potential causes such as air trapped in the system, which can be resolved by using a syringe to push water through the pump. It is recommended to check if the capsule container is properly inserted, as the pump will not operate without it. Some users have successfully resolved similar issues by repeatedly raising and lowering the water tank to release air bubbles, while others have disassembled the machine to inspect the pump and needle for blockages. Regular maintenance, including descaling and cleaning, is advised to prevent such problems.
