Saeco Picobaristo HD8926: Dealing with Water Circuit Priming Issues After Skipping Descaling
Katgol 37200 4
  • #1 16992519
    Katgol
    Rate: 43
    Hello. I have a problem with the machine today. After turning on the espresso machine, a message will be displayed about the need to descale the appliance, and I have decided to skip this step and I have gone to make coffee with no descaler at home. I turned on the latte and the milk frothed into the glass, but the coffee did not pour anymore, there was a message "start priming the water circuit" so I pressed ok, a red "insert water dispenser" message appears, of course the water dispenser is inserted. I rinsed the block threatening according to the instructions and nothing ... all the time this message and I can not push anything, only I can turn off the coffee machine, but when it's switched on it's the same. Do you have any experience with this problem ??
  • #2 16992677
    nioop
    Home appliances specialist
    Help: 503
    Rate: 3338
    The filter in the water tank is? If so please try without it.
    In addition, it proposes to rinse the reporting block under running water and possibly to set a thicker grinding.
    Kawa i Naprawa - Serwis AGD
  • #3 16992695
    Katgol
    Rate: 43
    I took out the water filter and nothing ... all the time the same message. The worst thing is that as exclusive and turn on it is nothing more than that I confirm "start flooding the water circuit" I can not do. You can not enter anything in any settings.
    Added after 47 [second]:
    The block was also rinsed
    • 20180127_175030.mp4 (84.5 MB) You must be logged in to download this attachment.
    nioop
    Help: 503
    Rate: 3338
    But please put the water dispenser into the espresso machine ;)
    We are not talking about a water tank but about the end which we plug in instead of the frothing cup ;)
  • #5 16993390
    Katgol
    Rate: 43
    THANK YOU VERY
