Skoda Fabia 2000 1.4 Comfort: Engine Temp Indicator Issue after Cold Start - Possible Causes?
rawlik 83297 16
Why does the coolant warning light come on after a cold start in a Skoda Fabia and then go out after the engine warms up?
The most likely cause is a too-low coolant level in the expansion tank, which can trigger the warning on a cold engine and then disappear once the coolant warms up and the level rises again [#1302544][#1302608][#10170444] If the level is correct but the fault keeps returning, check the expansion tank and its level sensor/connector for contamination or poor contact; several users reported that rinsing or replacing the reservoir fixed the warning [#4998583][#9660798][#21747311] A VAG scan for fault codes and clearing them was also suggested as a first check [#1302457]
  • #1 1300873
    rawlik
    Rate: 12
    I have a Fabia 1.4 from 2000 comfort, after starting the car, the engine temperature indicator lights up, even though the engine is still cold, when the engine temperature rises a bit and I start the engine again, everything is OK. This malfunction occurred after a frosty night when the car was outside and I think it may be related to the low temperature. Maybe someone had a similar situation or knows what could be causing the light to come on?
  • #2 1302457
    diag
    Help: 45
    Rate: 209
    VAG to hand and first check for errors, then delete and see how to proceed.
    nom
    Help: 49
    Rate: 84
    I do not remember exactly if this light came on, but when I had too little coolant in the equalizing tank, a light came on, probably because of the engine temperature and it was "beeping" 3 times.
    Check the instructions, maybe just add some liquid.
  • #4 1302608
    rawlik
    Rate: 12
    Thanks for the quick reply. I'm just waiting for the interface, so maybe I'll be able to say more later
    The simplest solutions are the best, but it turned out that there was not enough coolant in the expansion tank, which I had not noticed before. nom thank you very much.
  • #5 4243200
    rdcom
    Rate: 83
    I am the owner of a fabi 1.4 mpi 68 KM.
    The temperature indicator has been acting weird lately. Please let me know where the temperature sensor is
  • #6 4243942
    marekfiesta
    Level 19  
    Help: 16
    Rate: 323
    temperature sensor see picture
    • Skoda Fabia 2000 1.4 Comfort: Engine Temp Indicator Issue after Cold Start - Possible Causes? Klip_2.jpg (152.83 KB) You must be logged in to download this attachment.
  • #7 4244987
    rdcom
    Rate: 83
    Thank you for the advice, but from the photo I can't figure out where this sensor is. When looking at the front engine, I can see 2 sensors, one next to the oil filter, the other one on the lower right next to the oil filter. When I move it next to the oil filter, the gauge shows the coolant temperature correctly.
  • #8 4998583
    jan_man
    Rate: 51
    the reason for the lighting of the cooling indicator may be:
    Oily expansion tank (ultrasonic sensor does not work)
    poor electrical contact in connection with the temperature sensor located on the thermostat
  • #9 9660798
    Grzegorz Kaczmarzewski
    Hello. I had the same problem and the contamination in the tank was rinsed out and the problem was gone. And as for the electrical cables, as some describe it, it is enough to shorten the cube at the tank to make sure whether the sensor is blown up or the installation. after shorting the pins, when the light goes out, the sensor must be replaced
  • #10 10154461
    r.stankiewicz
    Rate: 37
    I will step on the topic!
    I have a problem with my factory I 1.9 SDI engine (2001). After replacing the thermostat (probably not immediately, but on the next day), the coolant temperature indicator stopped working. I replaced the sensor because I was sure it was his doing. Unfortunately the indicator was still dead. I shorted the contacts at the sensor for a short time - after switching on the ignition, the indicator swung halfway, but it fell down shortly (this was the case every time the ignition was turned on). The above would eliminate the sensor and indicator. Where else to look? Maybe someone knows how the connection of the sensor and the indicator works. I will be grateful for any help
  • #11 10170444
    stefano11
    Help: 32
    Rate: 132
    Just add g12 fluid after the night, you have too low a level as the engine warms up, the level rises and it's ok.
    Alternatively, you have a damaged head gasket and the oil gets into the cooling system, stays in the tank and contaminates the electrodes
    Added after 5 [minutes]:
  • Cold-start coolant warning likely from low level or sensor fault
    #12 21363523
    jsasanowicz17
    I will also add my voice to the statement. I own a 2000 skoda Fabia comfort, 1.4mpi engine. A month ago I replaced the coolant reservoir and about a fortnight ago I picked it up from the mechanic and it had the following done: timing change, oil and filters, cleaning of the cooling system. My problem is that for the last three days it has started to get mega cold and my coolant light appears (squeaks and flashes) on a cold engine when I start the car, but when the car warms up and I turn it off and start it again, everything is fine. Does anyone have any idea what this could be?
    Regards
  • #13 21363537
    M.R-V4
    Help: 76
    Rate: 164
    A little over thirteen years ago, colleague @stefano11 in this topic gave a very likely cause. Have you checked the fluid level in that expansion tank you mentioned at all on a cold engine?
  • Coolant level drops again after refill
    #14 21363576
    jsasanowicz17
    Yes, I checked the fluid level, it was too low 3 days ago, so I added it and it was quiet for a while, but yesterday the light started to come on again.
    Added after 4 [minutes]: .
    Additionally, on the model I have, the mechanic told me not to fix the head gasket because he had a customer with the same car, replaced the gasket and then had it replaced again a few months later because it's that type of car and nothing can be done about it. On the other hand, I'm curious if anyone else is having the same problem as me, or is the mechanic just bullshitting me and I'll have to bear the same costs again because he didn't want to mess around with replacing the gasket?
  • #15 21712381
    radziolw
    I had the same problem. I cleaned the expansion tank as much as I could and the problem disappeared for about 2-3 months. I bought a new reservoir for about PLN40 and 2 years were peace. Now the problem has reappeared. I'm going to try washing it first, as you can see sediment on the walls, but it doesn't look very dirty. I will let you know what the effect is.
  • #16 21712960
    danielzy
    Help: 167
    Rate: 319
    The effect if short-lived. Only replacing the reservoir will give peace of mind for longer.
  • #17 21747311
    radziolw
    I replaced the reservoir with a new one (replacement for PLN49). The problem with the indicator light disappeared. As a colleague wrote, I did not play with cleaning anymore. A game not worth the candle.
The discussion concerns a Skoda Fabia 1.4 MPI/Comfort where the coolant temperature warning lights up on a cold start after frost, then disappears once the engine warms up and is restarted. The most common causes identified are low coolant level in the expansion tank, contamination or sediment on the coolant reservoir level sensor electrodes, poor electrical contact at the sensor, or a faulty expansion tank/reservoir. Suggested diagnostics include checking fault codes with VAG, inspecting coolant level on a cold engine, cleaning the reservoir, and testing the sensor by shorting its contacts. In several cases, topping up coolant or replacing the expansion tank/reservoir permanently solved the issue.
