Skoda Octavia 1.6 TDI 2010 (77 kW) - Engine Temperature Starting Issues (20, 40, 50, 60, 80, 90)
darek640 12699 17
Why does a Skoda Octavia 1.6 TDI fail to start only when engine temperature is around 25–35°C, while it starts normally at 20°C and at 40–90°C?
The problem was ultimately fixed by replacing the battery; the engine was cranking, but the battery did not deliver a strong enough kick at startup [#17200641] Before that, the useful checks were to verify the coolant temperature sensor value seen by the ECU in diagnostics and, if the temperature signal was not the cause, inspect injector overflows/corrections and the fuel dose valve [#16412789] [#16414213]
  • #1 16410632
    darek640
    Rate: 194
    I have a problem with the Skoda Octavia 1.6 tdi, 2010, 77 kw, at 25 - 35 degrees engine temperature does not start, but if there are 20 piles 40/50/60/80/90 it is ok.
    Checked wtr pump, injectors, engine controller, shaft and shaft sensor, battery, starter, even substitution.
    No errors, pressure on the bar 270 - 280 bar.
    Installation checked.
    If anyone has any good advice then I would be grateful.
  • #2 16410682
    nikusert
    Help: 699
    Rate: 1755
    At this temperature, how do you start the engine? What are you doing? Does it not happen at random temperatures that it does not want to smoke?
    Best regards.
  • #3 16410796
    ociz
    Help: 1379
    Rate: 3486
    Try to deceive the temperature measurement so that it sees other than these 25 - 35 degrees.
  • #4 16411556
    darek640
    Rate: 194
    You have to wait for it to cool down, as I wrote earlier on other topics. no problem, and when it comes to temperature, nothing helps even -40 degrees.
    We are currently operating at 29 degrees Celsius and the meatball does not smoke.
    [/ Code]
  • #5 16412607
    ociz
    Help: 1379
    Rate: 3486
    So how I understood the impact has a real temperature, not what the ECU sees?
  • #6 16412789
  • Suspected low starting fuel dose at 25–35°C
    #7 16413693
    darek640
    Rate: 194
    Yesterday we installed the second sensor outside
    Cold engine 15 degrees Celsius engine preheats the sensor to 28 degrees Celsius does not continue to heat the sensor to 50/60/70/80/90 degrees but the cold engine around 15 degrees C and does not smoke.
    However, when it is warm it is as I wrote earlier.
    I have the impression that at a temperature of 25-35 degrees, the starting dose is too low.
    Certainly it is not the computer's fault because it was changed.
  • Suspected fuel metering valve or injector imbalance despite temperature
    #8 16414213
  • #9 16415463
    darek640
    Rate: 194
    The valve was replaced.
    Read my last post one more time, engine cold but we heat the sensor itself.
  • #10 16419255
  • #11 16425248
    darek640
    Rate: 194
    This is very strange behavior.
    I shook it a bit in translation.
    I will try to simulate the temp 20st at boot.
  • #12 16427264
  • #13 16487045
    darek640
    Rate: 194
    Subject embraced.
    Moderated By T5:
    Will a colleague share a solution or a topic without substantive content in a bin?
  • #14 16496950
    hubert2101
    Tell me whether after the temperature sensor replacement the problem is determined. Write whether it is a temperature sensor from the engine or from the outside temperature
  • #15 16498499
    darek640
    Rate: 194
    The subject was half-covered, none of the sensors were replaced. A resistor was made to lower the engine temperature.
  • #16 17200641
    hubert2101
    Topic is closed.
    Problem solved. Battery replacement. He was spinning, but the battery did not give a sharp kick at start-up.
  • #17 18675486
    pawelekopal
    Skoda Octavia 2 1.6
    It wont start
    New battery
    New starter
    It burns shortly after applying voltage to the starter solenoid
    Do you have a diagram of fuses and relays under the hood and under the steering wheel. Which relay is responsible for applying voltage to the starter? Where to look further I want to check everything along the way before I look for a problem in the ignition cube.
    Thank you
  • #18 18675517
    nikusert
    Help: 699
    Rate: 1755
    If it burns briefly, then check the ignition switch whether it supplies voltage, as well as the engine harness or something has not rotted.
The discussion revolves around starting issues with a 2010 Skoda Octavia 1.6 TDI (77 kW) at specific engine temperatures (25-35 degrees Celsius). The owner reports that the engine fails to start at these temperatures but operates normally at others (20, 40, 50, 60, 80, 90 degrees). Various components have been checked, including the water pump, injectors, engine controller, and battery, with no errors found. Suggestions include checking the temperature sensor for faults, as it may not accurately reflect the engine's actual temperature, and considering the fuel dose valve's functionality. Ultimately, the problem was resolved by replacing the battery, which was not providing sufficient power for starting despite appearing functional.
