TDA3629 N4K0K8 Hn4472Y Light Position Controller—Which Manufacturer Is This?
Kropek007 7545 4
  • #1 12614568
    Kropek007
    Hi, when cleaning the electronics cabinet I came across as if I were a regulator, after a deep inspection I saw the sign TDA3629 N4K0K8 Hn4472Y
    I looked and I looked and it seems to me that it is a "Light position controller" only I do not know what ...
    Maybe you've already seen something like that?
    TDA3629 N4K0K8 Hn4472Y Light Position Controller—Which Manufacturer Is This? TDA3629 N4K0K8 Hn4472Y Light Position Controller—Which Manufacturer Is This? TDA3629 N4K0K8 Hn4472Y Light Position Controller—Which Manufacturer Is This? TDA3629 N4K0K8 Hn4472Y Light Position Controller—Which Manufacturer Is This? TDA3629 N4K0K8 Hn4472Y Light Position Controller—Which Manufacturer Is This? TDA3629 N4K0K8 Hn4472Y Light Position Controller—Which Manufacturer Is This?
    35mario1
    Help: 91
    Rate: 87
    Headlight position regulator from the car.
  • #3 12614655
    Kropek007
    Do you know maybe what? Brand? Model?
  • #4 12614744
    35mario1
    Help: 91
    Rate: 87
    It is difficult to determine the model, since such controllers were used by many manufacturers. I met such in Ford and vehicles from the WAG group.
  • #5 12614850
    Kropek007
    35mario1 wrote:
    It is difficult to determine the model, as these regulators were used by many manufacturers. I met such in Ford and vehicles from the WAG group.
    Just on one of the forums I came across a similar model (successor?) In Skoda Superb.
    But thanks for the answer, I wanted to make sure.
