Everyone - Daytime running lights and directions in one bulb - diagram
Adimas 10872 7
  • #1 16725821
    Adimas
    Dear experts,
    a topic recently very fashionable. LED bulbs appeared on the market, which shine in both colors - white and orange depending on which electrode voltage is applied. There are of course ready sets that do not know how they work, but I would like to connect such bulbs myself.
    The idea is for the bulbs to glow white when the parking lights (dipped) are off (i.e. daytime running light function), but when I turn on the turn signal, the function should turn off during operation and turn on the Left or Right Turn Signal (K) function when work stops direction with a second delay or 2 seconds back should switch on daylight. With the parking and dipped headlights on, the directions should operate normally and the daytime running lights should be off. You probably saw such lights on the street in the latest Skoda Superb and other more expensive cars. Could it be easy to create such a scheme yourself? How would you approach this? Are there such relays with a switch-off delay? What would the connection diagram look like? I tried to draw it, but unfortunately I fell. Can you help?
  • #2 16725847
  • #3 16725870
    Adimas
    eurotips wrote:
    Buddy from October 1, reviews based on new rules,
    put these bulbs in your shoes because you have to have what it says on the lamp in the lamp.
    I sincerely doubt that anyone would look into shades from directions in which light bulbs burn with the correct frequency. During the inspection, the daytime running light circuit could be disconnected and only the directions left.
    But not about this topic. Can anyone help solve this puzzle? It seems to me that four relays would be needed, two on each side, two ordinary and two time-delayed AR150. Just how to connect it all now?
  • #5 16727564
    Adimas
    I'm not an expert, so forgive me if I drew it contrary to art. It seems to me that such a system could work if the time were set to above 2 seconds, the LED would remain in the off position while the direction would flash at a higher frequency. I am not sure about the yellow connections, are they correct? Can you combine it like that? The whole system has become very complicated, on both sides you need at least 3 ordinary and two time relays. It probably can be much easier to combine, but it is beyond my skills. Everyone - Daytime running lights and directions in one bulb - diagram
  • #7 16727778
    Adimas
    Gee, these are too high thresholds for my legs, some diodes, transistors, resistors, for this you need a knowledgeable electronics engineer to construct such a system. I meant a simple connection of wires with quick connectors than etching of a printed circuit board. :)
    I understand that the idea turns out to be original and its implementation requires advanced knowledge of electronics. Probably soon there will be some ready products for quick assembly. I'm not the only one who came up with this idea, which can be seen in the two-color light bulbs market.
  • #8 16728093
The discussion revolves around the implementation of dual-color LED bulbs that function as daytime running lights (DRL) and turn signals. The user seeks advice on creating a circuit that allows the bulbs to glow white when the parking lights are off and switch to orange for turn signals, with a delay for returning to DRL after signaling. Participants suggest using relays, including time-delay relays, and discuss the need for resistors when integrating LED bulbs into existing systems. Diagrams are shared to illustrate potential wiring solutions, and the complexity of the project is acknowledged, with some expressing the need for advanced electronics knowledge. The conversation highlights the growing popularity of such LED systems in modern vehicles, like the Skoda Superb.
