SIEMENS SD13IT1S – lower spray arm not spraying, door lock stuck?
TxC 6462 3
  • #1 12648845
    TxC
    Rate: 14
    Hello, the problem is that the lower spray arm does not fly water. The upper frame is fine. If there were few problems, I was still so clever that I blocked the door lock to see if there was a problem with the lower arm and the lock now does not want to let go, so the door can not be closed :D . The dishwasher has already been written off so I have a free hand.
  • #2 12651304
    txxc
    Perhaps someone will at least suggest how to look for parts?
  • #3 12654118
    Stefciu_B
    Home appliances specialist
    Help: 312
    Rate: 1222
    txxc wrote:
    Can someone at least
    I am afraid that with the purchase of a part you only have the service, go to the website of Bosch you will find there telephone numbers for the service.
  • #4 13548297
    TxC
    Rate: 14
    The problem was in the engine turning the valve block - it was burned and it did not get dirty so the water was fed only to the upper propeller (in these dishwashers the water is fed once up and down once).
    A friendly colleague from the forum sold me an affordable drug along with a lock and a dishwasher that has been sold today :)
    For illustration, I attach photos:
    SIEMENS SD13IT1S – lower spray arm not spraying, door lock stuck? SIEMENS SD13IT1S – lower spray arm not spraying, door lock stuck? SIEMENS SD13IT1S – lower spray arm not spraying, door lock stuck? SIEMENS SD13IT1S – lower spray arm not spraying, door lock stuck? SIEMENS SD13IT1S – lower spray arm not spraying, door lock stuck? SIEMENS SD13IT1S – lower spray arm not spraying, door lock stuck?
