LC420EUE - I am looking for a schematic of LCD matrix produced in Poland
kinkazu 15090 18
Where can I find a schematic for the LC420EUE-SEF1 LCD panel used in an LG 42LM620T?
There is no public schematic for the LC420EUE-SEF1 panel itself; the practical repair path is to use the TV/panel service documentation and troubleshoot the panel’s driver/T-CON board instead [#12716247][#12702747] The thread identifies the relevant panel/board context for the 42LM620T and mentions the T-CON board 6870C-0401B, with useful reference voltages such as VIN 11.47 V, VDD 16.63 V, HVDD 5.01 V, VGH 26.8 V, VGL -4.93 V, VCC 1.83 V, Vcore 1.82 V, GCLK 1.2 V, and VCOM 7.32 V [#12702747][#12702682] For wet or damaged parts on the small panel board, compare both sides, inspect the suspect capacitors/components, and measure them rather than expecting a factory schematic [#12716247][#12726538] In the end, the reported fault was solved by replacing one damaged capacitor on the matrix board [#12768603]
  • #1 12701938
    kinkazu
    Good day. I am looking for a scheme of the LCD matrix produced in Poland, the LC420EUE SE F1 model. Does any of the honorable men have one?
  • #2 12702477
    mirex
    Help: 1950
    Rate: 1990
    kinkazu wrote:
    Good morning. I am looking for a scheme of the LCD matrix produced in Poland, the LC420EUE SE F1 model. Does any of the honorable men have one?
    Regards
    Hmmm ..., and more broadly, what exactly do you mean?
    What do you want to achieve with this ... scheme?
  • #3 12702553
    kinkazu
    I have a LG 42LM620T. A little water was sprayed in from behind at the bottom and the components on the PCB of the directly connected matrix tape were damaged.
    I have a TV service manual. There are electronic diagrams of all discs with descriptions of elements, but the description of those connected to the matrix is not there.
    I assume that I will find this information in the matrix service manual.
    And then he will try to replace the elements that look damaged.
  • #4 12702621
    grubas
    Level 40  
    Help: 647
    Rate: 553
    Forget about your friend :-)
    Look for a new matrix (which is unprofitable) or rather a new TV.
  • #5 12702682
    lisek
    Service technician RTV
    Help: 6352
    Rate: 6883
    Na matrycy plytka driverow czy T-con"ie (6870C-0401B T-CON 32/37/42/47/55 FHD TM120 Ver0.2 )
    TL2350EP controler
    EEPROM/FLASH: 24C08_U5
    TPS65178 Gamma_buffer
    TPS65198 DC-DC
    Jaki masz objaw na ekranie?
    ________________
    Moze to sie przyda w poszukiwaniu
    VIN 11,47V
    VDD 16,63V
    HVDD 5,01V
    VGH 26,8V
    VGL (-)4,93V "z minusem
    VCC 1,83V
    Vcore 1,82V
    GCLK 1,2V
    VCOM 7,32V
    VCOML_FB 7,31V
    VCOMR_FB 7,31V
  • #6 12702720
    kinkazu
    Hmm, why? I can not find the instructions?
  • #7 12702747
    lisek
    Help: 6352
    Rate: 6883
    Bo to modele z 2012r.
    http://www.lgblog.co.uk/wp-content/uploads/2012/03/2012-Model-Master-V4.0.pdf
    Matryce:
    FHD 50Hz Edge LED
    32” 50 W Normal : T320HVN01.0-AUO- 32LS570
    32” Normal : LC320EUN-SEM1- 32LS570
    42” 70 W Normal : LC420EUE-SEM1- 42LS570
    47” 85 W Normal : LC470EUE-SEM1- 47LS570
    55” W Normal : LC550EUE-SEM1- 55LS570
    FHD T100Hz Edge LED
    32” 45 W FPR : LC320EUN-SEF2- 32LM620
    32” 50 W FPR : LC320EUA-KEF1- 32LM640
    37” 50 W FPR : LC370EUN-SEF2- 37LM620
    42” 60 W FPR : LC420EUE-SEF1- 42LM620
    42” 60 W FPR : LC420EUG-KEF1- 42LM660
    42” FPR : LC420EUG-KEF1- 42LM670
    47” 90 W FPR : LC470EUE-SEF1- 47LM620
    47” 70 W FPR : LC470EUG-KEF1- 47LM640
    47” FPR : LC470EUG-KEF1- 47LM669
    47” FPR : LC470EUG-KEF1- 47LM670
    55” 115 W FPR : LC550EUE-SEF1 - 55LM620
    55” 70 W FPR : LC550EUG-KEF1- 55LM640
    55” FPR : LC550EUG-KEF1- 55LM670
    FHD M100Hz Edge LED
    65” 230 W FPR : T645HB01 V0-AUO - 65LM620
    FHD T200Hz Edge LED
    42” 70 W FPR : LC420EUH-KEF1- 42LM760
    47” 90 W FPR : LC470EUH-KEF147- 47LM760
    55” 120 W FPR : LC550EUH-KEF1- 55LM760
    Procesory:
    LM860, LM960 - LG L9 CPU-Dual-core (ARM Cortex-A9 1Ghz GPU-Mali-400 MP4)
    LM7600, LM6xx - MediaTek MT5369
    Stosowano
    1.uniw. PSU+kontroler LED
    - EAX64427101 (1.4) (EAY62608901) dla 42LM620T matryca LC420EUE (SE) (F1)
    2. MAIN 42LM615T-ZE.BRUWLJU EBR75226869 EAX64317404(1.0) G4_L_TU123 chassis LD21B/LC21B ,matryca LC420EUE(SE)(F1)
  • #8 12702909
    kinkazu
    On the matrix:
     The second tuner looks the same, these 2 elements of the middle are as if drowned. You can not see the silver bar.
     On the screen the night, the sound is, T-CON's water did not reach. It was really unpracticed in the holes at the bottom of the TV. only the matrix drivers were on the way, nothing more. I can buy T-CON, because they are on eBay, but what's after me, like the matrix was falling.
  • #9 12703093
    lisek
    Help: 6352
    Rate: 6883
    Which elements?, They have numbers.
    Measure the voltage that I gave, draw conclusions.
    After all, with T-con on this small plate goes the connector (thin wires) can something upalilo / break?
    Voltages from Tcon are "transposed" into a small plate
    _______________
    Open, zassaj ( right side up> symol strzalka w dolne )> maybe from these "bushes" you can hear TV on the same matrix as yours
    Link
    (' :!: ') I'm sorry to write with a paw from UK Win, my home system was easy
  • #10 12703248
    kinkazu
    With T-CONA go 2 tape, one to the left the second to the right driver. each of the left or right parts has 3 tapes straight from the plate to the LCD. The tiles were wet. Some of the elements look worse than others. I will make a more detailed picture.
  • #11 12703683
    kinkazu
    Thanks for the instructions. The problem is that both yours and mine do not have a matrix electronics scheme.
    Instructions for 42LM620T here:
    http://any-server.com/42lm620s_42lm620t_42lm625s_chassis_ld22e.pdf " target="_blank" rel="nofollow noopener ugc" class="postlink inline" title="" > http://any-server.com/42lm620s_42lm620t_42lm625s_chassis_ld22e.pdf
    I counted on something similar to this:
    http://any-server.com/LG_Display_LP125WH2-SLT2.pdf " target="_blank" rel="nofollow noopener ugc" class="postlink inline" title="" > http://any-server.com/LG_Display_LP125WH2-SLT2.pdf
    I need to find a camera with a better macro function.
    Added after 7 [minutes]:
     Elements that I suspect I need to replace, I have circled a colic. There are a little more of them, but they look the same.
  • #12 12704776
    kinkazu
    Elements on C136, C133 look different than C104. For me, they look like "for exchange".
  • #13 12706002
    śfinkamorska
    As for me, a stave master is here for a definite exchange.
  • #14 12706076
    kinkazu
    I'll give advice, it's progress.
  • #15 12716247
    satgal
    Level 40  
    Help: 482
    Rate: 428
    You have to express yourself precisely in electronics. The dot and comma are of great importance. Does a friend imagine a matrix diagram where there are several million transistors and connections. The dies manufacturer does not provide components from which he assembled the matrix treating it as the most guarded secret, but only a pdf manual for tv producers needed to design it to work properly. What has a colleague's objections to these capacitors blocking the power supply can look like this when they were wet, but most importantly, they do not contain and this can be easily measured.
  • #16 12716662
    kinkazu
    Thank you very much for a specific answer. I have just measured resistors on the left and right S-PCB capacitors and have the same values, i.e. the problem is not in the "ugly" capacitors, or maybe on the power board or d-ic. I'll look for more.
  • #17 12726538
    satgal
    Level 40  
    Help: 482
    Rate: 428
    Like what do I have on the part of the beaten EUE matrix. It can be useful for measurements and comparisons eg tcon and tension on the strip.
  • #18 12746583
    kinkazu
    T-CONA and PSU disc replaced, the effect is the same.
    TV will take me to a specialist on Sunday and I hope that he will diagnose what is wrong.
    Thanks to the great satgal. I am probably asking you for help.
  • #19 12768603
    kinkazu
    The problem was solved after replacing the damaged capacitor, one of those in the picture. There is another, changing brightness in one of the corners of the matrix. On a bright background, you can see a flash every 2 seconds. A specialist colleague said the fault lies in a damaged D-IC and I will not repair this at home. Thank you very much for the help of Satgal. Regards and upcoming next time :)
The discussion revolves around the search for a schematic of the LC420EUE SE F1 LCD matrix produced in Poland. The original poster seeks this information to repair a damaged LG 42LM620T TV, which suffered water damage affecting the PCB connected to the matrix. Various responses suggest looking for a new matrix or TV, while others provide insights into the components involved, including T-CON and driver boards. Users share links to service manuals and diagrams, discuss the importance of precise measurements, and suggest potential replacements for damaged capacitors. Ultimately, the poster resolves some issues by replacing a damaged capacitor but faces ongoing problems with brightness fluctuations, indicating a possible D-IC failure.
