LG 42LC51-ZA (LP78A) - EAY34797001 Power Supply: Missing 3.4V, Backlight, No Picture
kasaki 13071 11
Why does an LG 42LC51-ZA have backlight but no picture, and is the missing 3.4 V rail the cause?
The missing 3.4 V rail is not necessarily the reason for no picture; in this model the fault can be on the T-Con, not the PSU. There is no dedicated schematic for the PLHL-T604A / EAY34797001 PSU, and in some LG versions the +3.4 V supply is not even needed [#11947598] For this TV, check the T-Con 6870C-0119A for the LC420WX6-SLA1 panel, especially fuse F1 and the TPS65161 IC; one case had F1 blown and the TV worked after replacing TPS65161 [#11948451] [#12077985] [#12086568] If you are still chasing the 3.4 V rail, inspect the transistor control path around CN800 and the base drive, because breaks there can prevent that voltage from being released [#11948451]
  • #1 11946809
    kasaki
    Hello, I have traced the topics on the forum but I did not find hints, LG 42LC51-ZA (LP78A) is backlight and no picture, I found 3.4V voltage in the EAY34797001 power supply voltage before Q208 Q209 5V transistor. So I stabilized the stabilizer so that I get 3.4V and there is no sound image.
    Does anyone have any idea or link to the power supply schematic?
  • #3 11946959
    mirex
    Help: 1950
    Rate: 1990
    You guarantee that there is a schematic of the power supply, should I then ask for a refund of 10 USD?
    Ehhh ... helpers. ;)
  • #4 11947275
    piotrusek29
    Rate: 37
    I will not give a guarantee because I did not download
  • #5 11947598
    lisek
    Service technician RTV
    Help: 6354
    Rate: 6885
    There is no scheme for this power supply PLHL-T604A (EAY34797001) from LG.
    He is on a universal print (pcb EAX32268301 / 9) and depending on the level of completion in active and passive elements, and the needs for the output drive has different names. look
    Link_popatrz on fot.2 / z_5_prawa page
    or
    Link_na Bottom foto.
    In some versions plasm from LG to + 3.4V is not needed.
    It was written in several forum posts.
    p.s
    https://www.elektroda.pl/rtvforum/topic2152741.html
    No picture is ... not only the lack of these + 3.4V.
  • #6 11947621
    lamer.
    Help: 138
    Rate: 49
    piotrusek29 wrote:
    I will not give you a guarantee because I have not downloaded
    Why paste this? And then there are claims to "mocked" advice. If the moderators dealt with such advice quickly enough, there would be no irony.
  • #7 11948320
    kasaki
    The 3.4V voltage is applied to the LP78A / PP78A module EAX32572503 / (1) version of the software version 37LC41-ZA v: 3.09
    Other voltages in the power supply are ok electrolytes changed from the description of the owner the image deteriorated gradually until it disappeared, after taking this nap. the effect is the same, is the motherboard dead?
  • #8 11948451
    lisek
    Help: 6354
    Rate: 6885
    no image, dzwiek jest
    Give me a break from Main.!
    Read (on the forum) and measure something on the T-Con 6870C-0119A for the LC420WX6-SLA1 matrix
    p.s
    yes, it probably is done + 3.4V per ssb
    - the transistor's battery is connected under the pin. 2 (on the left side (link) CN800
    check where the transistor base is controlled and if there are sometimes breaks in the circuit, that it does not release this voltage
  • #9 11948519
    mirex
    Help: 1950
    Rate: 1990
    lisek wrote:
    You will not find the scheme for this PLHL-T604A (EAY34797001) power supply from LG.
    or
    p.s
    No image is ... not just missing + 3.4V.
    Why do you need these pictures for him? It has a module, in nature, before the eyes.
  • #10 12077985
    kasaki
    Hello, I have not dealt with this problem for a long time but I am coming back and I want to finish the case.
    Colleague Lisek was right! The CTRL T-Con LC420WX6-SLA1 6870C-0119A logic is damaged. Specifically, the fuse F1 flared and the chip TPS65161 SMD on L1 is 3.3V, while the L2 12V should probably be around 18V.
    If someone has already exchanged this chip TPS65161, please let me know if it moved after the exchange
  • #11 12078069
    mirex
    Help: 1950
    Rate: 1990
    I did not move. There was something else. ;)
    But my friend succeeded. He went from the kick.
  • #12 12086568
    kasaki
    Layout TPS65161 replaced TV LG 42LC51-ZA Works!
    Ps.
    I think that this forum goes to the dogs many servicemen do not write anything outright misleads for fear of losing money.
The discussion revolves around the LG 42LC51-ZA (LP78A) television experiencing backlight issues and no picture, attributed to a missing 3.4V from the EAY34797001 power supply. Users provided links to power supply schematics and discussed the absence of a specific schematic for the PLHL-T604A power supply. It was noted that the 3.4V is not always necessary for operation. The original poster later identified a damaged T-Con board (LC420WX6-SLA1) and a blown fuse (F1), along with a malfunctioning TPS65161 chip, which was confirmed to be the cause of the issues after replacement. The resolution involved replacing the TPS65161 chip, which restored functionality to the TV.
