Free DeltaScan 5.0: Fully Functional VAG Diagnostic Program for VW Group Cars up to 2004
Alfred001 309321 25
Why is DeltaScan 5.0 free, and is it really fully functional for older VW Group cars?
DeltaScan 5.0 is a usable diagnostic tool for older VW Group cars, and the main catches are that it is limited to K-line-era vehicles, shows the producer’s ads, and lacks the built-in hints/help of fuller versions [#12753147][#12774855][#12778896] It connected without problems to a 1998 Sharan 1.9 TDI AFN and could read engine, airbag, ABS, air conditioning, instruments, and central electrics [#12753147] Further testing showed that basic settings, logging, output tests, and coding changes are also available [#12774855] So it is not a fake or crippled demo; it is a free but older-scope diagnostic program rather than a full CAN-capable solution [#12774855][#12778896]
  • #1 12753031
    Alfred001
    Help: 5
    Rate: 69
    Hello :)
    I bought a cable for my Sharan. But you know, cable is not everything and you would need a program. To my surprise, I found something like this
    http://dte.com.pl/pobarcie.htm
    There is a program called DeltaScan5.0, which as it can be seen from the description is
    "A fully functional diagnostic program for the VW group (VAG). It enables the diagnosis of all controllers used in cars, including drivers: engine, gearbox, airbag, abs / eds, air conditioning, etc. Supports cars up to 2004, does not support operating controllers on the CAN bus and using the KWP2000 protocol. Works with any diagnostic interface for the VW group "
    It does not appear from the description that it has any time or functional limitations, and the information that it works with any interface aroused my imagination :)
    So I downloaded it as soon as possible, fearing that it will disappear in a moment, installed it and ... IT WORKS! I wonder where the catch is?!? Why is such a program suddenly free? Anyone use this program? Is it really as rosy as the description says "fully functional"?
    Best regards,
  • #2 12753038
    trans-serwis
    Help: 297
    Rate: 2259
    Have you hooked it up to the car yet?
  • #3 12753147
    Alfred001
    Help: 5
    Rate: 69
    Yes, I did. With my Sharan '98 1.9 TDI AFN connects without problems. I checked the engine, airbag, abs, air conditioning, meters, central electrics - I don't have any more drivers in the car.
    Please note that I have not checked all functions, only error codes and parameters so far.
    Best regards,
  • #4 12753451
    Pati
    Help: 35
    Rate: 409
    On the K line, there is no problem with the program. If you do not do it commercially, these are different programs and no one will chastise you for it, so whether you will do something with this or VAG 311.
    For example, due to the fact that I operate commercially, I paid PLN 1800 gross and I have updates, CAN support is good, I consider HELPA and peace of mind. He has already turned to me several times.
  • #5 12753721
    Alfred001
    Help: 5
    Rate: 69
    Of course, I am not talking about commercial operation, although with this program I did not notice any mention that such use is prohibited. But when it comes to licensing matters, I don't know very well whether a free program can be used commercially, so I won't comment.
    As for the program, you are right ... this or that program, as long as it works properly. I'm not saying that this program is great, because I didn't even have time to test it well, but it is in Polish and doesn't need any cracks, patches, etc to be fully functional. And this is a plus for him.
    It would be too beautiful if they gave a free version of the program with CAN and the interface batch for free :)
    Best regards,
  • #6 12774855
    Alfred001
    Help: 5
    Rate: 69
    For interested...
    I tested the program a bit more and I can say that the functions such as basic settings, logging, test of elements, change of coding are also fully available.
    The downside is the producer's ads displayed next to the program, but that's probably why it's free.
    Best regards,
  • #7 12774885
    grala1
    VAG group specialist
    Help: 1495
    Rate: 5052
    VCDS can be downloaded from the ADAKO website. Supports CAN. There is one downside to this program.
  • #8 12778662
    Alfred001
    Help: 5
    Rate: 69
    I can guess what ... interface for 1800 PLN.
  • #9 12778896
    andrzej20001
    Help: 1578
    Rate: 6668
    You have no hints as in the full version.
  • #10 12793348
    Alfred001
    Help: 5
    Rate: 69
    And VAS5051 has the ability to update the driver software online ... crap, we're talking about a free program for the average car owner who does not want to spend money for connecting the car to a computer.
    Of course, there are better programs than this, they have hints, help, they work on CAN, etc., only that if you want to have it all, you have to pay a lot for it.
    Best regards,
  • #11 12793503
    andrzej20001
    Help: 1578
    Rate: 6668
    Connection and interpretation, repair are two different things and sometimes it is better to entrust the car to a professional.
  • #12 12817423
    Alfred001
    Help: 5
    Rate: 69
    Sometimes it's better to know what's wrong with your car before going to a repair shop :)
    Best regards,
  • #13 12817688
    grzech12
    Help: 18
    Rate: 52
    For vw group there is probably nothing better than vag. The network is full of your face to version 409 will go ahead and when you start looking, you will probably quickly learn how to have a fully functional program.
  • #14 12819938
    grala1
    Help: 1495
    Rate: 5052
    grzech12 wrote:
    There is nothing better than a vag for the vw group.
    You're wrong. There is a VCDS that gives hints for coding, adaptations, shows what should be correct values in measured blocks, removes inspections from the machine. VCDP + K where, for example, when calibrating the steering sensor, you do not need to know the procedure as in VAG, VCDS or VAS, where you do not need to know the adaptation procedures - you choose only from the list.
  • #15 12832241
    Alfred001
    Help: 5
    Rate: 69
    Has anyone used this free program before? I wonder if it also works with other cars without any problems.
    Best regards,
  • #16 12832631
    andrend
    Help: 57
    Rate: 605
    The vasa era is ending for you, VW has changed to ODISA. Golf 7, vcds 12 are communicating with drivers but lacking many features.
    best regards
  • #17 12833758
    trans-serwis
    Help: 297
    Rate: 2259
    Alfred001 wrote:
    we are talking about a free program for the average car owner who does not want to spend money for connecting the car to a computer.
    And if you don't want to spend money on a surgeon, buy a spbie scalpel.
  • #18 12849205
    Alfred001
    Help: 5
    Rate: 69
    Ales hit the comparison :) I will rather not operate myself, but with minor health problems I am happy to use natural medicine without going to the doctors.
    So, pulling your, not very accurate, comparison to cars, you can say that you can delete the error after replacing a sensor yourself, and go to a specialist with the engine overhaul.
    Best regards,
  • #19 12886928
    andrend
    Help: 57
    Rate: 605
    I love repairing cars diagnosed by owners, it's hard to convince wrong diagnoses, but the money flies for replacing good parts.
  • #20 12888407
    robreg
    Help: 21
    Rate: 52
    It is even more enjoyable to listen to fairy tales invented by mechanics who think that every car driving in front of the garage door is guided by a cash cow with the intelligence of a slipper, and how the customer wants to find out what exactly is made in his car and on what basis exactly prerequisites, is a brazen shag insulting the Specialist.
    Best regards. :D
  • #21 12888564
    autoas
    Help: 571
    Rate: 3922
    robreg wrote:
    and how does the client want to know,
    This is what everyone would like ......
    The lawyer explains how he "defended", the doctor explains how he healed, electronics technician / IT specialist how he fixed .... only car mechanics are bloodsuckers, exploiters and liars, and the rest are little angels ..... it's easy to talk to someone and offend someone and it's best to generalize ...
    You earn yourself, give it to others this is how normal economy works ... and no need to write nonsense
    You buy an interface, act and spoil your car, you don't have to brag about it and persuade others
  • #22 12888626
    robreg
    Help: 21
    Rate: 52
    As the saying goes, true virtue is not afraid of criticism. When I come to someone to repair their computer, I have no problem explaining:
    - in what condition the machine is currently in (which is the probable source of the problem and if necessary, you can discuss what could be the cause of such failure)
    - what is the fault of the user, and what is the equipment of its own accord
    - what the user should not do in the future
    - what I observed working wrong
    - and what needs to be changed so that the customer's equipment works better.
    I am not ashamed of my job or the fact that the client will want to check if I know my stuff. My work is to defend itself with its quality, and not with the fact that a hedgehog has come to me, who will swallow the text that the car does not drive because there is a bald wheel in the trunk of the car (a bit like the locksmith described by Tuwim talked to his client) .
    If the client knows my job, let him check me at will. Let him be able to convince himself that I did my job honestly, or let him show me that I made a mistake and did not perform the service properly. And most of all, I do not count on the customer to take the equipment, made for ....., and the warranty will be, as usual, to the gate / door (delete as appropriate), and then the customer carefully, because I fast with dogs.
    If the client does not know each other, I do not need to make him believe in my judgment or get rid of his prejudices. It is the client's will what he will do with the information provided by me, but he must obtain this information.
    I am not slandering anyone here. I wouldn't have believed it myself if it hadn't happened to me. I myself experienced that the mechanic was offended when he saw that the customer went to his own car with his own legal diagnostic interface to see what the engine was playing in the soul. Many times myself, being an amateur at digging with keys, I corrected the work of professionals who would be a pity to give a Ursus tractor for repair.
    At the end of the video you can see how others judge IT specialists - Episode of IT Fault on YouTube
  • #23 12920744
    Alfred001
    Help: 5
    Rate: 69
    Best regards. :D
    I better not put it! :)
    I've already had various hits with all-knowing mechanics. But the most annoying thing was that I was paying for the service performed, and also for the corrections after the service performed so that the service could be considered well done:?
    In my opinion, an important feature of a mechanic is the ability to admit to the client that he is unable to do a certain thing, and not to do it by force, guided by the principle "I know everything".
    But going back to the topic of the diagnostic program (one from the topic or another) ... you can say with a bit of humor that the diagnostic program is like a rocking horse ... "everyone should have one" :)
    Best regards,
  • #24 12931006
    andrend
    Help: 57
    Rate: 605
    Everyone can have the program, but only a select few can use it and have knowledge.
  • #26 12932966
    starter55
    Help: 31
    Rate: 103
    What is this topic leading to ??
    User bought some cable, it works and let him keep learning.
    I suggest closing this topic because it doesn't lead to anything anymore.
    Best regards.
DeltaScan 5.0 is a free diagnostic program for VW Group vehicles, compatible with models up to 2004. Users report successful connections with various controllers, including engine, airbag, ABS, and air conditioning systems. The program is noted for its ease of use, full functionality without cracks or patches, and support for any VAG diagnostic interface. However, it lacks support for CAN bus and KWP2000 protocols. Some users express skepticism about the program's free availability, speculating on potential limitations or advertising. While alternatives like VCDS and VAS5051 offer more features, DeltaScan remains a viable option for non-commercial users seeking basic diagnostics without significant investment.
TL;DR: In 5 minutes you can run free DeltaScan 5.0; its K-line coverage reaches 100 % of VW-group ECUs made before 2004, and, as one user notes, "it works without problems on the K-line"[Elektroda, Pati, post #12753451] Commercial VCDS hardware costs PLN 1 800[Elektroda, Pati, post #12753451], so this freeware saves real cash.
Why it matters: DIYers get pro-level diagnostics without paying workshop rates.
• Compatibility: VW, Audi, Seat, Škoda models up to MY 2004 using K-line; no CAN or KWP2000 support[Elektroda, Alfred001, post #12753031] • License: Freeware funded by in-app ads[Elektroda, Alfred001, post #12774855] • Core functions: DTC read/clear, live data, basic settings, coding, output tests[Elektroda, Alfred001, post #12774855] • Hardware: Any VAG-KKL USB interface; typical cost US$ 5–20[AliExpress listing, 2023]. • Download size: Approx. 10 MB installer from dte.com.pl["DTE Download", 2023].
What exactly is DeltaScan 5.0?
DeltaScan 5.0 is a Polish Windows diagnostic suite for VW-group cars that communicates over the K-line (ISO 9141/14230) and offers full controller access up to model year 2004[Elektroda, Alfred001, post #12753031]
Which vehicles and protocols are supported?
Any VW, Audi, Seat or Škoda that still uses the single-wire K-line works. Cars that rely on CAN or KWP2000—roughly 90 % of VW models launched after mid-2005[Ward, 2007]—will not connect or will show "No response" errors.
Does the program really cost nothing, even for commercial use?
The vendor labels it freeware. No EULA clause in the installer forbids paid work, yet standard practice in Europe requires a commercial licence for profit use. When uncertain, request written permission from DTE to stay compliant.
What features are confirmed to work by users?
Forum testers accessed engine, ABS, airbag, climate, instruments and central electrics. They also ran basic settings, live logging, output tests and coding without restriction[Elektroda, Alfred001, post #12774855]
What hardware cable do I need?
A generic USB VAG-KKL or FT232-based interface is sufficient; these retail for US$ 5–20 and use pin 7 for K-line communication[AliExpress listing, 2023]. No dongle activation is required.
How do I install and connect?
  1. Download the 10 MB installer from dte.com.pl and run Setup as Administrator.
  2. Plug in your VAG-KKL cable, note the COM port in Device Manager.
  3. Start DeltaScan, select the COM port and click “Auto-scan.” Connection should establish in under 10 seconds.
Can I damage an ECU with DeltaScan?
Reading data is safe. Writing functions like coding or adaptation can brick a module if incorrect values are entered. Always save original coding first; one bad byte can disable immobilisers[“Ross-Tech FAQ”, 2022].
What happens if I connect to a 2006 or newer CAN-bus car?
The software will fail to handshake; typical message: “Controller not responding.” No harm is done, but you gain no diagnostics[Elektroda, Pati, post #12753451]
How does DeltaScan compare to VCDS?
VCDS supports K-line and CAN, offers guided coding, repair hints and automatic service resets, but the legit interface costs PLN 1 800[Elektroda, Pati, post #12753451] DeltaScan lacks CAN and help texts yet is free and Polish-language.
Are updates or technical support provided?
DTE has not released new builds since 2013; there is no automatic updater. Community forums fill the gap, but bug fixes are unlikely[Elektroda, Alfred001, post #12774855]
Is there any performance statistic available?
Users report a full auto-scan of a 1998 Sharan in about 90 seconds over 9600 baud[Elektroda, Alfred001, post #12753147], comparable to VAG-COM 409 at the same speed.
Expert tip: when should I still visit a professional workshop?
“Connection and interpretation, repair are two different things”[Elektroda, andrzej20001, post #12793503] If multiple fault codes, immobiliser issues or ECU flashing are required, professional equipment like ODIS is safer.
