  • KKL cable limited to engine module on 2006 Golf
    #1 16177990
    qulet
    Rate: 215
    HELLO !
    My question is about the diagnostic cable KKL VAG-COM FOR 409.1
    The cable after connecting to the car and computer with the VAG-COM VER311.2 program (WINXP VMWare) communicates only on the "Engine" module.
    Under win7 x64bit, the VCDS-lite 1.2 program only works with the "Engine" module
    What can you do with this cable to communicate with other modules?
    I know that the cable supports cars manufactured until 2004
    Mine is from 2006, in theory the connection should not be established. In practice it is, but very limited. Is any modification possible to connect to other modules?
    The cable is intended for home use only. Expensive interface drops off.
    I am asking for advice in this matter.
    Greetings to all readers !!!
    coperfild
    Help: 291
    Rate: 1699
    You won't do anything the rest of the modules are on the wall that this cable doesn't support.
    daro31ie
    Automation specialist
    Help: 366
    Rate: 650
    Buddy, you have to buy a cable with kkl + can.
    You have most modules on a can rail.
    You have the cheapest one. Best regards, gift.
  • #4 16178922
    qulet
    Rate: 215
    Thanks for the answers !
    Regards!
    Added after 8 [minutes]:
    Is this cable "ok"
    Moderated By T5:
    I deleted the link. 3.1.18. Do not send links that will become inactive after some time. This will cause the discussion to lose any meaning.
    It will work, but that's not what you expect.
  • #5 16178967
    grala1
    VAG group specialist
    Help: 1496
    Rate: 5053
    Ok, if you want to make problems.
    Search for VCDS or VAS.
  • #6 16178987
    qulet
    Rate: 215
    I am asking for an extension of "how do you want to cause problems" ......
  • #7 16179004
    grala1
    Help: 1496
    Rate: 5053
    It is difficult to use, you can delete the contents of the meter or engine controller when you do not know what to do.
    It is better to add and buy VCDS where you have a multitude of descriptions on the net.
The discussion revolves around the limitations of the KKL VAG-COM diagnostic cable (version 409.1) when used with a 2006 VW Golf Plus 1.9 TDI. The user reports that the cable only communicates with the "Engine" module using VAG-COM version 311.2 on Windows XP and VCDS-lite 1.2 on Windows 7 x64. Responses indicate that the KKL cable does not support other modules, as they are primarily on a CAN bus, and suggest purchasing a more advanced cable that includes CAN support for full functionality. Caution is advised regarding potential issues when using the cable, with recommendations to consider VCDS or VAS for better compatibility and support.
