Choice of electronic water meter with memory and accurate reading every 5 minutes
monter79 2154 1
  • #1 12938112
    monter79
    Help: 31
    Rate: 47
    Hi. I am looking for an electronic water meter, with memory and the ability to read water flow with an accuracy of 5min. The idea is to check at what times there is the highest water consumption.
    An interesting function would be to drive the NC/NO output when there is an established over-use
  • #2 13013354
    marcinosko
    Help: 7
    i read somewhere that it is possible to do this with a hall sensor applied somewhere in the top of the meter
