Seeking Recommendations for Superior Vocal Recording and Editing Software to Cool Edit Pro 2.1
PoyoLoco 41064 11
What software should I use for recording and editing vocals better than Cool Edit Pro 2.1?
Try Reaper, or if you want more established professional DAWs, Pro Tools, Cubase/Nuendo, or Samplitude, but the software itself matters less than the recording chain [#13046119] [#13045286] A good final vocal starts with a good microphone, an acoustically treated room, a mic preamp, and a proper interface; even the best program will not fully fix poor source material [#13036038] [#13036052] The extra "goodies" you want are mostly standard VST plugins rather than a different recording program [#13038975] For comfort and processing, the chosen DAW is mainly a matter of taste, habits, and the plugins you use [#13045286] If the signal is already good, even Audacity can be enough for recording and simple trimming/correction [#13036038]
  • #1 13034696
    PoyoLoco
    hello, as in the topic, I'm looking for a good program for recording and processing vocals. Currently I am using cool edit pro 2.1, but I think there will be better programs in this area ... Could you recommend any? Cheers
  • #2 13035107
    ShakeAll
    Help: 29
    Rate: 135
    Maybe you would define what you expect from the program, what you miss in Cool Edit?
    The most important is the microphone, cable and interface or sound card (not to be confused with the sound card), if any of these elements is weak it will not matter what you record the sound.
    First, write down what exactly you want to record, what equipment you have, what you expect from the recording software and what the end result should be.
    Greetings...
    ShakeAll
  • #3 13035885
    PoyoLoco
    Well ... I have a good microphone, and so is the cable. The audio interface also does not have a music card. I only record vocals and that's what I care about. I do not complain about the quality, but rather about the mastering possibilities and general comfort. For example, the recording of the session irritates me ... The end result, I would like a relatively 'comfortable' program in which I get very good vocal quality.
    Added after 1 [seconds]:
  • #4 13036038
    ShakeAll
    Help: 29
    Rate: 135
    Let me put it bluntly, a well-recorded vocal does not require much processing, if you do not have any interface or sound card, you also have a "good" microphone, even the best program for obediating will not help much here. Yes, poor material can be improved a bit, but it will still be poor material, only slightly improved.
    If you are serious about recording your vocals, buy at least a good usb microphone (it has a built-in interface), you will spend these three hundred dollars, but you will see what comfort it is when the material is well recorded. In fact, it does not need any major processing, or the addition of some effects such as reverb or delay.
    Another thing is the room where you record, good soundproofing is the basis and it does not have to be a soundproof room with screens, I record in the dressing room (clothes act as soundproofing).
    I apologize if you did not expect such an answer, but believe me, a few years ago I changed a lot of "cheap" solutions, because for amateur recording I do not need to have a studio right away, and unfortunately these cheap solutions are the most expensive.
    I felt sorry for those few words, bought a guitar interface with an XLR microphone input, a good amateur microphone, and practically my audio booth now comes down to trimming and correction of the sound intensity, and I record Audacity.
  • #5 13036052
    stasiekm
    Level 30  
    Help: 77
    Rate: 100
    The basis for a good final quality is a good recording at the very beginning. For vocals, start with a good microphone in an acoustically adapted room. Another important element is the microphone preamplifier and the interface to the computer. Only at the end of this chain is the sound processing software.
  • #6 13037641
    PoyoLoco
    Sorry, I made it vague. I have a 'cabin', I added a panel to the corner in my room and the resulting cuboid was damped with mineral wool. I have a microphone for PLN 300. Sinn7 Dasmic 3 and a mixer, rather standard with an XLR connector. Maybe I do not have a music card, but when I ordered a computer, I emphasized that the sound card should be expanded ... Generally, when it comes to processing, I mean such 'goodies', the quality itself is good but I heard that there are better programs than cool edit.
  • #7 13038975
    adambyw
    Moderator of Acoustics
    Help: 1120
    Rate: 829
    Such goodies that you write about are mainly standard plugins, e.g. VST, not programs.
  • #8 13039758
    PoyoLoco
    Ok, I'll look for plugins. In general, do you recommend a program? Eg Acid Pro 7?
  • #9 13045286
    adambyw
    Help: 1120
    Rate: 829
    A matter of taste and habits. With the recording itself, the program does not matter, because it only saves what the music card gives it to the disk. When processing, a question of convenience and the plugs you use.
    In the past, 3-4 programs dominated the market, such as the most professional Protools, then Cubase / Nuendo (Steinberg) which includes standards such as ASIO, VST, VSTi or Samplitude. Recently, similar programs have multiplied, although for me the first two are still the leading ones.
    Now another question arises, how much do you want to invest in the software, because the free ones are usually weak, the better ones cost up to about PLN 3,000.
  • #10 13045838
    PoyoLoco
    200, 300 PLN? You honestly surprised me with this maximum price ... :O My point is that cool edit, although good, is not necessarily convenient.
  • #11 13046119
    hipekk
    Level 19  
    Help: 16
    Rate: 43
    Or maybe Reaper?
    PoyoLoco wrote:
    The audio interface also does not have a music card. .
    What you got :) ?
  • #12 13046233
    PoyoLoco
    as I wrote, a desktop computer (with a sound card, supposedly a bit better ...), a mixer with phantom power, a condenser microphone and a booth. Such a home studio. And I would like to cover these topics a bit more, because I'm interested in all of this. From time to time my friends come over and record, I also record something there myself and I would like to have the best end result of the recordings.
The discussion revolves around seeking alternatives to Cool Edit Pro 2.1 for vocal recording and processing. The user expresses satisfaction with their current microphone and audio interface but seeks better mastering capabilities and overall comfort in the software. Responses emphasize the importance of high-quality recording equipment, including a good microphone, audio interface, and soundproofing, as foundational to achieving superior vocal quality. Recommendations include exploring software options like Acid Pro 7 and Reaper, while also considering the use of VST plugins for enhanced processing. The conversation highlights that the choice of software is often subjective and dependent on personal preferences and budget.
