Seeking Optimal PC Program for Real-Time Audio Monitoring
DziQux 12438 5
  • #1 17079744
    DziQux
    Hello, I am looking for a PC program with real-time listening.
  • #2 17080081
    Recoil83
    Level 19  
    Help: 29
    Rate: 32
    I don't understand the question, could you elaborate on what exactly you want to do?
  • #3 17080455
    DziQux
    I want to hear the microphone in the speakers, just no delay.
  • #4 17080475
    pawel1029384756
    Help: 33
    Rate: 277
    Well, in the case of a computer program it is not achievable, there will always be some latency. Only the analog solution will give the desired effect.
  • #5 17080548
    Recoil83
    Level 19  
    Help: 29
    Rate: 32
    In total, in each DAW you can perform real-time monitoring of the connected equipment, but it is related to latency, as a colleague wrote above, and it can be influenced by increasing or decreasing the ASIO driver buffer.
  • #6 17080957
    adambyw
    Moderator of Acoustics
    Help: 1120
    Rate: 829
    Only non-professional equipment will not allow you to descend too low with a delay. It's once. And two that very small buffers cause a very high CPU load and unreliability. There may often be so-called 'drops', i.e. missing samples.
    As Paweł wrote, either an analog solution or a card that implements it digitally but in hardware in the internal DSP, not in the computer through the DAW.
