Installing a microwave sensor in a room with two outlets - how to do it?
Tomaszek 55 3471 6
  • #1 13174331
    Tomaszek 55
    Rate: 31
    Hello!
    I would like an answer to the following question: can a microwave motion detector be installed in a room? To a question edited in this way there is of course the answer "Yes, you can!" but I am concerned with something else. Well, there are two exits from this room. One leads to the terrace and the other to the inside of the house. My idea is to switch off the unnecessary light when going out onto the terrace and switch it back on when returning to the room (the light switch is located closer to the centre of the house). However, I would also like the light to stay on continuously when people are in the room. The second question is how to effectively screen the detector, so that the detector control is not affected by people's movements on the upper floor (it is a suspended NidaGypsum ceiling and a floor on joists on the other side). Well, and I wouldn't want to spend a fortune....
  • #2 13174404
    xury
    Automation specialist
    Help: 878
    Rate: 1498
    The fundamental question is why should it be microwave and not PIR ?
  • #3 13175418
    Tomaszek 55
    Rate: 31
    For aesthetic reasons. The chandelier I constructed is of plywood, in the form of a circle hanging a few cm below the ceiling. There are six adjustable LED spotlight meshes arranged around the perimeter. I wouldn't want any protruding PIR detector type elements, as it will lose the charm of a levitating plate....
  • #5 13175823
    Tomaszek 55
    Rate: 31
    Well I wouldn't want such a revolution.... I was just thinking of a simple soloution to make the contraption detect the presence of a person or several.... Like Leonardo, I'll wait until someone builds the device I need....
  • #7 13928217
    Tomaszek 55
    Rate: 31
    I gave up - too much rework. I installed a double line of IR sensors.
