Creating a Custom Talking Card with Sound Recording Feature: DIY Guide & Sources for Components
wloszka18 30831 14
How can I buy or build a small talking-card module that records sound from my computer and plays it back only when a button is pressed?
Buy a ready-made voice-record/playback module such as the ISD1730 (about PLN 18 at TME) or ISD1820, because these modules have simple record/play/stop pins and non-volatile memory, so you can trigger playback with a button instead of opening the card [#13206361] [#13209027] For the ISD1730, the poster says it needs only one resistor to set the sampling rate, plus an analog audio source for recording and an analog speaker for playback [#13206361] One reply warned that the Conrad module mentioned earlier likely uses volatile memory and could lose the recording when the battery is discharged, so a non-volatile module is the safer choice [#13205435] [#13209027] Another option mentioned was to follow the simple SD-card/WAV approach or buy an MP3 player module and remove unused connectors, but that is more complex than the voice-record chip solution [#13202032]
  • Seeking a recordable sound module with button activation
    #1 13201977
    wloszka18
    I am asking in advance for gentle treatment and answers written in a simple, understandable language for a woman and a layman. :-)
    I don't know if I'm asking this question in the right place and I don't know if I'm repeating myself, but most of the topics on this forum are black magic to me. But to the point. :-)
    I would like to do it, because unfortunately you can't buy a playing card anywhere, or rather a talking card, because I would like the sound from my computer to be recorded there.
    One company offered me to perform such a service for PLN 100, and in my opinion it is many times higher than the actual cost of performance, so I would like to do everything myself, and here I am asking for help.
    Where can I buy such an element as in playing cards and how to record my sound on it? Maybe there are companies that will send me this part with the sound already uploaded? It would also be nice if the sound did not turn on after opening the card, but only after pressing the button.
    I am asking for your understanding and help.
    Thank you in advance and best regards. :-)
  • #2 13202032
    speedy9
    Helpful for users
    Help: 1233
    Rate: 2425
    1. you can follow the layout from this site and prepare a WAV file: http://elm-chan.org/works/sd8p/report.html
    2. you can buy a ready-made MP3 player module and remove unnecessary jack and USB sockets, and even a card slot (solder the card permanently): http://dx.com/p/mp3-player-module-w-micro -sd-card-slot-mini-usb-3-5mm-jack-156001#.Ut45AxCtbDc
  • #3 13202128
    cirrostrato
    Help: 286
    Rate: 959
    wloszka18 wrote:
    I am asking in advance for a gentle treatment and answers written in a simple, understandable language for a woman and a layman. :-)
    In my opinion, the price for making and programming a single circuit is very reasonable, ordering several thousand such circuits would certainly be much cheaper. You will not do it yourself (bet?) Without knowledge in the subject and the appropriate accessories, today for PLN 1 it is "buying" a phone ... no offense. Regards.
  • #4 13202175
    wloszka18
    speedy9 Thanks - I'll read it and see if I can get through it. :-)
    cirrostrato If you don't want to help, then don't comment unnecessarily and don't offend, please.
  • #5 13202471
    cirrostrato
    Help: 286
    Rate: 959
    I'm not insulting (if you took it that way..) I'm just specifying the reality, my friend speedy9 showed links to topics where the layout will be the size of a Marlboro pack, and I don't think that's what you mean. Once again, I assure you that a system that works exactly according to your needs and costs PLN 100 is a bargain. Regards.
  • #6 13204598
    wloszka18
    I just found a ready-made one, on which I may not drop the sound from the computer, but I can just record it and such a module costs PLN 18.50 and that's enough for me. :-) So it can be done! :-)
  • #7 13204950
    excray
    Help: 739
    Rate: 657
    wloszka18 wrote:
    I just found a ready-made one, on which I may not drop the sound from the computer, but I can just record it and such a module costs PLN 18.50 and that's enough for me. :) So it can be done! :)
    Give me the link.
  • #9 13205435
    oj
    Help: 788
    Rate: 480
    It is not checked, but this module is based on volatile memory, i.e. when the battery is discharged, we lose what has been recorded.
    On Allegro "ISD1820 module - message player - developer" or link - the record remains after a power failure
  • #10 13205708
    wloszka18
    oh I hadn't thought of that - thank you! Only this module seems to me too "high" to hide it in the playing card. :-(
  • #11 13205825
  • #12 13206136
    speedy9
    Helpful for users
    Help: 1233
    Rate: 2425
    Probably not quite on non-volatile memory, though. From the description of a similar module on Aliexpress.com:
    if no longer used after the last recording will be saved for about a year.
    However, I think the batteries just last about a year ;) After replacing them it works again. It's just that replacing them in a card is rather problematic without destroying it.
  • #13 13206361
    Marico
    Help: 28
    Rate: 60
    If you like soldering, you can try with the ISD1730 system, the price is about PLN 18 in tme. The circuit is simple, it does not require external components (except one resistor to set the sampling rate) or an additional mcu to control it. It has an analog audio source for recording, an analog speaker and pins to which you simply connect play, stop, etc. It has non-volatile memory.
  • #14 13209027
    oj
    Help: 788
    Rate: 480
    voytaschec wrote:
    Why do you conclude that?
    1. I have similar modules
    2. Closing the page is the Play button, and it is not used to cut off the voltage, because the Rec button would not work
    3. On the given page, only this one is not listed as "non-volatile"
    ISD1820 module - message player - caller
    It is described as "non-volatile"
    http://www.casper-tech.pl/allegro_doc/ISD1820.pdf
  • #15 13354315
    niaha
    Italian18 Could you tell me which company can make such a card? I want to be able to record a track longer than 10 or 20 seconds. I will be grateful :)
The discussion revolves around creating a custom talking card with a sound recording feature. The user seeks guidance on sourcing components and recording sound, as commercial options are deemed too expensive. Responses suggest using a WAV file layout and purchasing an MP3 player module or specific recording modules like the ISD1820 and ISD1730. The ISD1820 is noted for its non-volatile memory, while the ISD1730 is highlighted for its simplicity and low cost. Links to relevant products and modules are shared, along with considerations regarding battery life and memory retention. The conversation emphasizes DIY solutions and the feasibility of creating a talking card at a lower cost than commercial offerings.
