INTERFACEINATOR - that is, the command center of the Earth differently
SylwekK 9159 28
  • A suitcase-based interactive toy called INTERFACEINATOR combines LEDs, buttons, switches, sound effects, educational mini-games, memory exercises, and an arcade-style RADAR module.
  • An ATmega328 coordinates 9 74HC595 shift registers, while WS2811 LED chains replace half the LEDs to simplify the PCB and increase playability.
  • The build took about 200 hours and produced more than 4,500 lines of C code, with nearly 40 different effects and melodies.
  • It runs from a 2200 mA power bank for about 8–10 hours, draws roughly 150 mA, and blocks play if battery status is too low.
  • There is no manual, so discovering the suitcase's functions is part of the fun.
  • INTERFACEINATOR - that is, the command center of the Earth differently
    What some on the forum know is that I like LED blinking. In this project, I gave it the maximum vent and was able to get carried away by the wave to such an extent that by the end I had had enough :)
    You remember Earth Command Center by colleague @ reaven22? Yes, it was his design that was the inspiration for my construction and even for this occasion I asked him for permission to use the lead melody from his suitcase, but on sound details later :)
    Watching the CDZ project a long time ago and contributing to the topic at the same time, I didn't even think that I would have the opportunity to do something similar in the future. Well, life sometimes surprises and when a cute nephew shows up, Uncle has to do something.
    The construction took me some time, and it was created in full conspiracy for at least a year. Maybe two people besides me knew about everything. Even my daughters did not notice that it was supposed to be a toy - daddy does the new driver and that's it.
    What were the assumptions then? Initially, it was supposed to be simple, some LEDs, some switches, buttons. In the meantime, ambition prevailed and ideas began to sprout slightly diversifying the fun - gameplay. A quick decision - some Atmega and shift registers to cover the buttons and lights, each of them freely programmable and generating sound effects. When, after several dozen hours of devising the layout and possibilities, I accidentally flashed somewhere on the WS2811 internet pages in DIP - the decision was immediate. Half of the LEDs were replaced in the project, thanks to which I was able to get rid of 6 pcs of 74HC595 registers, which made the schematic and the board extremely simple, and at the same time drastically increased the playability. I went back to the point of designing and thinking about new possibilities.
    In total, some 200 hours of thinking, planning, designing, soldering and programming (just over 4500 lines of program in C written from scratch) resulted in a device that not only lights up and makes sounds, but also has sewn educational options (e.g. fun colors, manual exercises with precise turning of knobs, simple rhythmics, etc.) and memory exercises (several versions). The latter option is particularly interesting due to the scalability of the game - even parents can do the competition :) There was also an arcade option in the form of a simple game with the use of the RADAR module.
    The two-and-a-half-year-old recipient is probably satisfied, and his parents, I have the impression, were more surprised by the suitcase than he was :)
    The device is designed in such a way as to logically combine certain elements, dependencies and react to signals. I introduced a random element (it can be changed with a hidden option or turned off completely) thanks to which games in modules (if they are active) start after a random time and expect the operator's reaction.
    Admittedly, the toddler will not use all the possibilities right away, but I announced to parents that you can absolutely not leave the device alone with this device, and they can use it (memory games start easily, but it gets really hardcore as you win).
    As for a child, a few minutes of play is absolutely enough and the joy of the flashing lights is ahead. Anyway, what kind of child will take more than 10-15 minutes.
    The toddler liked to click with a microwave and an oven, so I think that this suitcase will be a much better and safer option for him :)
    And one more important feature - there are no instructions for this. Searching for and discovering the suitcase's possibilities is all the fun.
    And a few more technical details.
    Ultimately, the system is controlled by Atmega328 16 MHz, and it is helped by 9 74hc595 registers - some of them are inputs for button operation, and some as LED control outputs. Quite a large PCB ordered from Allpcb.
    Hardware PWM is used to generate melodies and audio effects. In retrospect, I wish I had made two audio channels (the board was ready and some changes would be needed). All sounds are synthesized (including explosions, crackles, etc) and this had to be handled in time with sending the package to WS_LED. Added to this is the control of shift registers with a slightly modified software SPI to make it easier to read the input states. I do not give the diagram because there is nothing special about it. WS chain connection and rej595 are standard, as is the connection of potentiometers for analog inputs. There are no miracles here, just the basic rules straight from the beginner's guides :) The program and its capabilities are the most important here.
    After long thoughts on how to power this device, I fell on a small 2200 mA powerbank, which should be enough for about 8-10 hours of fun without a break. It is convenient and practical. The entire device does not exceed a current consumption of approximately 150 mA.
    I used ISD1820 to record and play back audio, which turned out to be a shot at 10, because whoever would not touch the suitcase, he likes this option the most :)
    There is also, of course, a power indicator with signaling. When the suitcase opens, the entire system is automatically turned on and the ENERGY module shows the battery status for a few seconds, and then goes to normal operation. If the status is too low, the device will not go into play mode, but will sound an alarm.
    The housing, as you can see, is an ordinary suitcase, and the base of the switches and lights is 5 mm milky plexiglass, and all the holes are drilled on a large CNC machine by a friend (once again, many thanks to Grzes :) On top, I designed a sticker printed in UV technology (printed by the company that deals with such things).
    Oh, the sound. in total, there are nearly 40 different effects and melodies. I first "compose" the theme melodies in a music program to transfer them easily to the processor later. It was more difficult with special effects - some of them required dozens of tests on foot to make them sound the way I wanted them to. And below my friend @ reaven22's melody as one to choose from the menu :)
    A few photos from the assembly stage.
    INTERFACEINATOR - that is, the command center of the Earth differently INTERFACEINATOR - that is, the command center of the Earth differently INTERFACEINATOR - that is, the command center of the Earth differently INTERFACEINATOR - that is, the command center of the Earth differently INTERFACEINATOR - that is, the command center of the Earth differently INTERFACEINATOR - that is, the command center of the Earth differently INTERFACEINATOR - that is, the command center of the Earth differently INTERFACEINATOR - that is, the command center of the Earth differently INTERFACEINATOR - that is, the command center of the Earth differently
    And this was the toddler's reaction (and then the presentation of the suitcase).
    SylwekK
    Level 32  
    SylwekK wrote 2764 posts with rating 2763, helped 82 times. Live in city Lipsko. Been with us since 2007 year.
  • #2 20089212
    ArturAVS
    Moderator
    Help: 2303
    Rate: 7830
    It looks like the "nuclear suitcase" of a certain president :D . As for the use of ISD1820, I have some doubts, it was better to use e.g. such a module with SD card support.
  • #3 20089389
    SylwekK
    Level 32  
    Help: 82
    Rate: 2763
    ISD can easily cope in this case, super quality is not needed here :)
  • #4 20089395
    ArturAVS
    Moderator
    Help: 2303
    Rate: 7830
    I did not mean quality, but the ease of controlling and loading audio files via USB.
  • #5 20089411
    SylwekK
    Level 32  
    Help: 82
    Rate: 2763
    Yes, it would be more interesting with that module (I read the article) only in the assumptions of the project I had a simple opportunity to record a few seconds and then play it back. If I was doing something with the messages, I would definitely consider using something stronger than isd.
  • #6 20090298
    walbe
    Level 19  
    Help: 28
    Rate: 44
    Super performance!
    INTERFACEINATOR - nice name, I wonder how to translate it? A face changer or maybe an International Face Changer? :-D
  • #7 20090317
    SylwekK
    Level 32  
    Help: 82
    Rate: 2763
    I don't know, that's what it came to my mind at the beginning and it stays that way :) Every invention of Dr. Dundershmirtz (the one from my avatar) had "inator" in the name and I liked it :)
  • Suggesting microSD documentation and sound effects packs
    #8 20091391
    Damian_Max
    Help: 40
    Rate: 96
    Great construction, big congratulations !!
    It looks very cool, it inspired me to build a substitute for what I have in my drawer.
    Heh, @ sylwekk1 on the (micro) SD card upload the batch, diagram, pcb, documentation / description (e.g. topic printed in pdf) and a dedication. Hide the card inside the device (with warm glue or somehow), when your toddler grows up, maybe he will look there :) (although it is already donated, it will be difficult to drop it there, but maybe under the pretext of 'service / replacement of xD batteries')
    As for sounds, you can download special effects packs for games, there is a lot to choose from.
    Aa and I found a bug:
    "You cannot leave this device alone"
    "the kid will take care of it for a few (teen) minutes"
    if the little one takes a dozen or so minutes, the parents will absolutely not wait and look, but will take care of worldly matters xD.
    Against the background of various toys, this interfaceinator does not look particularly dangerous.
  • Real-time sound generation and bug report
    #9 20091542
    SylwekK
    Level 32  
    Help: 82
    Rate: 2763
    @Damian_Max, thanks :)
    Probably yes, only for me everything is generated in real time by the processor (such a climate of 8bit :) ), and for those you write about, the player would probably come in handy. I myself have quite a large base of effects due to filming and editing.
    Actually, I was more concerned with the safety of the suitcase :)
    My parents recently informed me that they got into the play with the lights themselves :D
  • #10 20092007
    reaven22
    Help: 106
    Rate: 1367
    Congratulations on the design, workmanship and details !! :)
    It's nice that my design was an inspiration ;)
    My project, despite 9 years old, still enjoys Junior :) and soon she will start playing Junior.
  • #11 20092398
    Jawi_P
    Level 36  
    Help: 260
    Rate: 715
    Professional job! :)
    It looks insane. If I can give you a hint, hmm, I miss a built-in walkie-talkie and a second towel to the set, so that he can call his parents :) .
    Great project - a mega plus from me :)
  • #12 20092510
    SylwekK
    Level 32  
    Help: 82
    Rate: 2763
    Jawi_P wrote:
    If I can give you a hint, hmm, I miss a built-in walkie-talkie and a second towel to complete the set to call my parents.
    Well, then, probably in any security store, they would throw it on the soil. :)
  • #13 20093968
    398216 Usunięty
    Help: 3925
    Rate: 9447
    One thing is certain - you will not get on board any plane with such a suitcase.
    Workmanship and appearance the best. For something that doesn't do anything (useful), it's a wonderful thing. Although it can and does; provides a moment of peace from the questions "Dad, why ..." changing them to "Dad, what is this?" :)
  • #14 20094790
    Belialek
    Help: 19
    Rate: 124
    SylwekK wrote:
    You don't need super quality here :)
    But it's great quality :) Has your colleague thought about reselling the project and the batch? I would like to offer something like that for my child :)
  • #15 20095354
    SylwekK
    Level 32  
    Help: 82
    Rate: 2763
    I haven't thought about it yet, but I'm afraid the cost would be high. It would be a pity just those 200 hours of work :)
  • #16 20097062
    ditomek
    Help: 24
    Rate: 230
    Could a colleague give a rough overview of the functions and relationships between them? Is the translation into the surrounding world 1: 1 or some other? I mainly mean PLASMA and SPECTRO components. What functions do they control in real life?
  • Plasma educational module with manual RGB control
    #17 20097101
    SylwekK
    Level 32  
    Help: 82
    Rate: 2763
    PLASMA is, let's say, an educational module. With automatic operation, it shimmers with all colors (RGB led), while with manual control, the potentiometers can control each color separately and observe the effect and mixing.
    SPECTRO is a typical visual gadget. The module was supposed to be more extensive, but time was running out a bit and maybe in some update I will add a few previously planned things to it. Generally, there are several effects programmed there, which can be additionally modified in color.
  • #18 20098260
    Zenereczek
    Help: 7
    Rate: 29
    SylwekK, as always, beautiful!
    How do you find time for such masterpieces.
    Congratulations and admire.
  • #19 20098557
    SylwekK
    Level 32  
    Help: 82
    Rate: 2763
    Thanks :) Sometimes it's just a bit bad :)
  • #20 20098824
    Belialek
    Help: 19
    Rate: 124
    For one, a lot is PLN 100 and for another one million :)
    By selling the project / kit for self-assembly / finished product, these 200 hours have the opportunity to "earn" for themselves - otherwise there is "only" satisfaction with the project.
  • #21 20098877
    SylwekK
    Level 32  
    Help: 82
    Rate: 2763
    A matter worth considering. :)
  • #22 20099595
    SylwekK
    Level 32  
    Help: 82
    Rate: 2763
    Oh, I said how long it took and I forgot about the costs :)
    Well, it didn't work out cheaply. Not counting the time to develop the device and write the program, the cost of all elements of the toy was around PLN 400. I was also surprised after the count. The elements were bought at different intervals and on the occasion of other orders, I did not feel it so drastically in my pocket :)
  • #23 20100531
    Piottr242
    Help: 36
    Rate: 300
    How much did such a large printed circuit board cost you? And where did you do?
  • #24 20100586
    SylwekK
    Level 32  
    Help: 82
    Rate: 2763
    I was doing at ALLPCB, the cost of 5 items was something like 150 PLN. Well, in our country, nobody would make me cheaper.
  • #25 20115806
    tomus2k
    Help: 89
    Rate: 218
    SylwekK wrote:
    I don't know, that's what it came to my head at the beginning and it stays that way :) Every invention of Dr. Dundershmirtz (the one from my avatar) had "inator" in the name and I liked it :)
    Where's the kill button? Every inator had it :D
  • #26 20115836
    SylwekK
    Level 32  
    Help: 82
    Rate: 2763
    Oh tap ... you are actually right - a button that should not be pressed under any circumstances - will be an idea for version 2 :)
  • #27 20115933
    ArturAVS
    Moderator
    Help: 2303
    Rate: 7830
    SylwekK wrote:
    a button that must not be pressed under any circumstances
    Unlocked by turning two keys at the same time :D . Additionally, maybe a small pyrotechnic charge as a substitute for destruction? Safe for the pest, of course. After an "explosion" the entire INTERFACEINATOR would be "dead" until restarted by the constructor.
  • ISD1820 playback volume question
    #28 21574212
    JulianChrupek
    Rate: 73
    Great work.
    A Lexus among suitcases.
    I only came across your project yesterday when I posted mine:
    https://www.elektroda.pl/rtvforum/topic4125525.html#21573707
    Mine looks like the inside of a Russian fighter jet next to it, but the most important thing is that the kids have fun.
    Fellow @reaven22 is probably also happy that his project continues to inspire.
    I have a question about the ISD1820.
    The Chinese modules I used to acquire worked seemingly ok, but played back very quietly (perhaps a good thing by contrast, as the case is rather noisy).
    How did it work out for you?
  • #29 21574282
    SylwekK
    Level 32  
    Help: 82
    Rate: 2763
    Thanks, your suitcase looks great too, maybe even better than mine 😁 It really has a lot of bits and pieces and the baby won't get bored too quickly.
    The ISD module plays loud enough for a toy. The important thing is that the speaker doesn't lie freely, but is screwed to the case and creates some resonance in the case.
The INTERFACEINATOR project is a custom electronic toy inspired by the "Earth Command Center" design by @reaven22, featuring extensive LED blinking effects and sound playback using the ISD1820 voice recording/playback module. The creator chose ISD1820 for its simplicity and ability to record a few seconds of audio directly, despite suggestions to use SD card-based modules for easier audio file management and USB loading. The device includes modules named PLASMA and SPECTRO: PLASMA serves as an educational RGB LED color mixing module with manual and automatic modes, while SPECTRO provides various programmable visual effects with color modification options. The project involved around 200 hours of work and cost approximately PLN 400 in components, with PCBs manufactured at ALLPCB. The ISD1820 module delivers adequate sound volume when the speaker is securely mounted to the case for resonance. Suggestions for future versions include adding a "kill button" and possibly a walkie-talkie feature. The project is praised for its craftsmanship, visual appeal, and interactive features that engage children, providing a playful alternative to typical toys. The creator also emphasized safety and real-time effect generation by the processor, maintaining an 8-bit style aesthetic.
TL;DR: INTERFACEINATOR packs 200 hours of design time and a 400 PLN parts bill into one LED-soaked suitcase; "LED blinking to the max" [Elektroda, SylwekK, post #20089010] Built around an ATmega328 and WS2811 chain, it teaches color mixing, memory, and rhythm.
Why it matters: A DIY toy can rival commercial STEM kits while costing under €100 in parts.
Quick-Facts • MCU: ATmega328-P @ 16 MHz controlling 9 × 74HC595 shift registers [Elektroda, SylwekK, post #20089010] • LEDs: 50 × WS2811 RGB + discrete indicators; max draw ≈ 150 mA [Elektroda, SylwekK, post #20089010] • Power: 2 200 mAh power-bank, 8–10 h play per charge [Elektroda, SylwekK, post #20089010] • PCB: 250 × 160 mm, 5 pcs cost ≈ 150 PLN at ALLPCB [Elektroda, SylwekK, post #20100586] • Total BOM: ≈ 400 PLN (≈ €85) [Elektroda, SylwekK, post #20099595]
What exactly is the INTERFACEINATOR?
A suitcase-mounted electronic console for kids. It combines 50 addressable RGB LEDs, dozens of buttons, knobs, a radar game, memory challenges, and 40 synthesized sound effects, all driven by an ATmega328 running 4 500 lines of C code [Elektroda, SylwekK, post #20089010]
Why did the author swap six 74HC595 chips for WS2811 LEDs?
WS2811 LEDs include an internal driver, so one MCU pin can daisy-chain many pixels. Removing six shift registers simplified wiring, shrank the PCB, and opened room for richer animations [Elektroda, SylwekK, post #20089010]
How much time and money went into the build?
Design, soldering, and coding consumed about 200 hours, while hardware cost roughly 400 PLN (≈ €85) [Elektroda, SylwekK, #20089010; #20099595].
Which power source and runtime does it achieve?
A 2 200 mAh power-bank supplies the console. Average current is 150 mA, so playtime lands between 8 h and 10 h per charge [Elektroda, SylwekK, post #20089010]
My ISD1820 is quiet—any tips?
Mount the speaker firmly to the case so the enclosure forms a resonant chamber; this lifted volume to toy-friendly levels for the author [Elektroda, SylwekK, post #21574282] An extra 8 Ω mini-amplifier IC can add 6 dB if needed.
Can I buy a kit or finished unit?
The creator has not commercialised it yet; he notes pricing could be high but is "a matter worth considering" [Elektroda, SylwekK, post #20098877]
How do I record a new message on the ISD1820?
  1. Hold REC and speak into the on-board mic (up to 10 s).
  2. Release REC; the clip stores in on-chip EEPROM.
  3. Pulse PLAYE for full playback or PLAYL for momentary playback. "Super quality is not needed here" [Elektroda, SylwekK, post #20089389]
Can I add the infamous "kill button" every Dr. Doofenshmirtz gadget has?
Yes: wire an NC push-button to reset. For drama, gate it behind two simultaneous key-switches and a safe-LED; one user even proposed a harmless pyrotechnic pop before lockout [Elektroda, ArturAVS, post #20115933]
How is the project educational?
Modules teach color theory, fine-motor knob control, basic rhythm, and memory recall. Difficulty scales so even parents join the competition [Elektroda, SylwekK, post #20089010]
What’s the meaning of the name “INTERFACEINATOR”?
It riffs on Dr. Doofenshmirtz’s habit of ending inventions with “-inator.” The author liked the cartoon reference and kept it [Elektroda, SylwekK, post #20090317]
