Indesit IWUD4105 Washing Machine: Blocked Pump & Hydrostat Replacement - Water Drawing Issue
olomaj 4656 16
Why does an Indesit IWUD4105 keep pumping without filling until I blow the pressure hose, even after replacing the pressure switch?
If a new hydrostat and clear hose do not fix the symptom, the control module likely needs reprogramming or replacement [#16482235][#17374610] Before that, clean the hydrostat cup/connection point and make sure the pressure hose runs freely from the drum/tub and is not blocked or damaged [#16466717][#16472565][#16477917] Check the siphon/drain hose between the pump and the tank for any blockage left by the trapped handkerchief, because a restriction there can prevent the pressure from building correctly [#16477917] Also verify the hydrostat hose is connected to the correct port and that the pressure switch reacts the opposite way when you blow into the hose, since the machine should stop filling under pressure, not vacuum [#16480934] In the thread, replacing the whole board/module solved the problem and the washer worked again [#17374610]
  • #1 16464968
    olomaj
    In the Indesit IWUD4105 washing machine, the handkerchief got into the pump and it blocked. I cleaned the pump and hoses with the hydrostatic hose. After starting the washing program, the pump works for a long time and does not draw water. Only when I take off the hose and lightly blow the hydrostat, water begins to take in. I put a new hydrostat on, and so is the symptom. If any of my colleagues knows what this is, please help.
    I greet everyone.
  • #2 16466717
    Lodxx
    Home appliances specialist
    Help: 105
    Rate: 245
    Clean the hydrostat cup, then where does the hydrostatic hose come from.
  • #3 16467089
    olomaj
    OK, I'll do it tonight and write what the effect is.
  • #4 16472456
    olomaj
    I don't see any mugs in this washing machine. The tubing goes directly into the drum.
    Thanks for the hint.
    Maybe some more suggestions?
    best regards
  • #5 16472565
    Kenworth 18
    Help: 2415
    Rate: 3702
    And did you blow the hose? Is it clear?
    Sometimes the hose can rub or break somewhere, and then there is no vacuum that activates the hydrostat.
  • #6 16472968
    olomaj
    The tubing is purged free.
    I will check if it is not damaged as you suggest.
  • #7 16477885
    olomaj
    The hose is checked, functional, no damage.
    In addition, I disconnected the controller from everyone for one day
    plugins. After everything is assembled, the washing machine behaves like this
    itself, i.e. it pumps out water for a long time but does not consume it.
    Maybe some hints?
    best regards
  • #8 16477917
    Kenworth 18
    Help: 2415
    Rate: 3702
    Take off and check if there will be something blocking the so-called siphon, i.e. the drain hose connecting the pump with the tank.
    There has to be some reason the vacuum is not being built up which triggers the hydrostat.
    If there was a handkerchief in the pump, something could also be stuck in the hose.
  • #9 16479660
    olomaj
    OK, I'll do it again, because I've already cleaned the pump and hose
    connecting the pump with the drum.
  • #10 16480934
    wiertacz
    Help: 312
    Rate: 382
    And have you not mistaken the hydrostat hoses?
    When you blow in the hose, then the washing machine should stop drawing water.
    While taking water into the tank, the hose creates pressure (and not a vacuum, as some people write here) and after reaching the correct water level and the associated pressure in the hose, the hydrostat switches its contacts and the washing machine stops drawing water and the next washing cycle begins.
  • #11 16481369
    Kenworth 18
    Help: 2415
    Rate: 3702
    I am sorry my fault and admit to the mistake.
    A colleague is right, buddy drill, only that the usual washing machines have a cube that is connected to the hydrostatic and it is rather impossible to attach it otherwise because of the tabs. Of course, I could be wrong.
    The author of the topic is an electrician and the probability of making a mistake when connecting the hydrostat is rather negligible. I think so.
  • #12 16482125
    wiertacz
    Help: 312
    Rate: 382
    Perhaps it is impossible to connect the cables incorrectly in today's washing machines.
    In my 26 year old washing machine, each cord connects separately and such a mistake is possible.
    But this does not change the fact that the symptoms indicate the opposite effect of the hydrostat.
  • #13 16482153
    Kenworth 18
    Help: 2415
    Rate: 3702
    The author of the topic writes that he replaced the hydrostat, the only question is whether it is an original or a cheap replacement or universal. Maybe the hydrostat itself has a different contact system inside, which forces a different connection method.
  • #14 16482194
    niewolno2
    Level 40  
    Help: 628
    Rate: 1255
    If the hose enters the tank directly, check the patency of this hole, for the sake of peace and quiet, I cut off a fragment of the old hose connection, if it is possible and put it on again, so I am sure that it always enters tightly.
  • #15 16482235
    nares
    Help: 1515
    Rate: 3381
    Module for reprogramming - for this ailment in IWUD nothing else helps and there is no point in producing more posts on this topic.
  • #16 16484772
    olomaj
    Thank you all for your interest in the topic.
    So far I have not fulfilled your recommendations because I am not at home. As soon as I can, I will work on the washing machine.
    The cables on the hydrostat have a plug that cannot be connected incorrectly. I changed the new hydrostat also from the washing machine to the probe
    INDESIT-original. I will also check the accessibility of the inlet from the drum to
    he will write about everything.
    best regards
  • #17 17374610
    olomaj
    I replaced the entire plate and the washing machine works. Thank you for your interest.
    Added after 8 [minutes]:
    There is another problem with the indesit iwc 6105 washing machine.
    No lights are on.
    I replaced the capacitors and thyristor on the board. Nothing helped, I also replaced the door switch.
    The door switch comes with 194V, and I think it should be 230V
    What else should i do
    I am asking for hints.
✨ The discussion revolves around a malfunction in the Indesit IWUD4105 washing machine, where a blockage caused by a handkerchief led to issues with water intake. After cleaning the pump and hoses, the user replaced the hydrostat but continued to experience problems with the machine not drawing water. Various suggestions were made, including checking the hydrostat cup, ensuring the hoses are clear and undamaged, and verifying the correct connection of the hydrostat. The user confirmed that the hoses were functional and that the hydrostat was an original part. Ultimately, the user resolved the issue by replacing the entire control board, restoring the washing machine's functionality.
