Indesit IWC5145 - how to unlock the door in the washing machine?
Jula 5 34305 3
  • #1 17334139
    Jula 5
    The washing machine probably broke, the washing was not finished, it stopped in the middle and it is impossible to press anything now, the washing machine does not respond at all, the door is blocked and the washing inside. And the question is how to unlock the door now to remove the laundry?
  • #2 17334207
    leonard40i4
    Help: 29
    Rate: 103
    Disconnect the washing machine from the power socket. Wait a few minutes. If it does not unlock, try hitting the housing near the door handle with your fist. It can help, but not always.
  • #3 17334462
    Kenworth 18
    Help: 2447
    Rate: 3760
    If the washing machine does not unlock the door despite removing the plug from the socket, please try this way:
    https://youtu.be/J7vzWGMvfOM
  • #4 17335485
    leonard40i4
    Help: 29
    Rate: 103
    If the door lock does not release, the above methods will not help.
    The poor quality of the blocking material causes the posistor (gray ingot) and thermal plates to move. This defect causes problems with opening or locking the door. In the worst case, a short circuit occurs and, as a result, the programmer is damaged.
    Some washing machines and locks have a special lever for emergency opening.
    From what I remember, this washing machine does not have this fancy.
    It remains to remove the top of the washing machine and mechanically reach the blockade.
