Indesit H20 Error: Internal Valve Check & Washing Machine Powder Rinse Discussion
h4d3s89 15603 2
  • #1 16289827
    h4d3s89
    The topic of the H20 error was a long time ago, generally after the error, the manufacturer says that it is a problem with the internal valve, so I also turned it off. However, after what I read here, I'm not so sure about this valve damage now. In general, the washing machine rinses the powder from the drawer and now I'm wondering how to check this valve if it works?
    :arrow: I corrected TONI_2003
  • #2 16373395
    brzoza59
    Rate: 9
    Hello!
    Before you replace the valve, check the sieve in the washing machine once and the sieve in the hose at the valve, and solenoid valves rarely fail. Usually the strainers overgrow depending on what water is in the network. Therefore, the error H20 or lack of water.
    Regards
  • #3 20343562
    pwsrd
    @h4d3s89
    There are two solenoid valves and check the resistances on both. In my case, one worked and the other didn't. As a result, when water was to be fed through the second faulty one (drawer handling the softener), the error H20 .
