1-Wire - Sensors show 85°C above 53°C, how do I fix this on Windows XP?
3093 6
  • #1 13211018
  • #2 13211062
    Steryd3
    Help: 241
    Rate: 301
    A bit strange- when I used this sensor in a microprocessor system (on an AVR) there was no such phenomenon. The transmission does not change - only the temperature values sent from the sensor change. The value 85 - from what I remember - is characteristic insofar as it is the result of the first measurement from the sensor - after the first power-up. If I were you, I would take a look at the sensor to see if there is any assembly error or mechanical damage which becomes apparent when it is heated up. Alternatively, try replacing the sensor - it costs a few PLN and can explain a lot.
  • #3 13211156
  • #4 13243495
    Jacek Rutkowski
    Help: 69
    Rate: 275
    If you are using the full resolution of the DS18B20 sensors then the conversion time is 750ms and for at least this time a logical single should be sustained on the bus before you start reading.
  • #5 13250915
  • #6 13278195
    3-2-1-zwarcie
    Rate: 8
    Try swapping the power supply from the parasitic to the normal one (i.e. connecting the sensor on 3 wires).
    I heard somewhere that the sensor may not be getting enough power through the parasitic.
  • #7 14631610
