Excel: Creating Formula to Alter Font/Cell Color Based on System Date Comparison
Helloween 38877 4
  • #1 13291359
    Helloween
    Rate: 20
    I am asking for help from honorable users of "excelers"
    I have a cell (cell formatting is set to date) in which I enter the date of the next periodic health and safety test of the employee, e.g. 2016-02-11, how to write a formula that will change the font color of this date and / or fill the cell if the system date is a month earlier (until 2016-01-10 is to be normal formatting)?
    I tried conditional formatting but I can't do much with the date.
    skorik
    Rate: 10
    try this (in Excel 2007 or later):
    Select the cell with the date of the next test, click:
    conditional formatting -> rules for highlighting cells -> greater than ... -> in the window that opens, select the cell in which you have the current date and add "+31" (without quotes) or as many days as you need. So in this window you will have e.g. = $ C $ 3 + 31
    Maciej Gonet
    VBA, Excel specialist
    Help: 824
    Rate: 481
    Good evening,
    Conditional formatting is the right direction. For example, you can use the formula for cell value less (or less than or equal to) than:
    Regards
    • Form_war_daty.xls (18 KB) You must be logged in to download this attachment.
    dt1
    Admin of Computers group
    Help: 7315
    Rate: 8292
    Welcome,
    This can be easily done with conditional formatting - as shown in the picture.
    An example from Excel 2003, probably works the same in the newer ones.
    / edit: I see I was forewarned a bit :)
  • #5 13291554
    Helloween
    Rate: 20
    Thank you very much for your help, everything works as it should now :)
    edit:
    I also checked (user example @-Maciej_ Gonet which I liked the most) in OpenOffice Calc (3.2) and it also works with the difference that after changing the system date - when testing - you have to close the file and reopen it to take conditional formatting into account.
    In Excel, each of the examples provided by you works without any problems without closing and re-opening the file :)
    Thank you again.
