EXCEL 03 - How to Highlight Cells Based on Date Thresholds Before Events?
promyk5 65935 16
How can I use Excel 2003 conditional formatting to highlight a cell 7 days before a birthday or another date 60 days in advance?
Use conditional formatting with a formula that checks the date against DZIŚ()/TODAY() plus the needed offset, then apply the desired fill color. For birthdays, the forum suggests a formula based on MONTH and DAY with `TODAY()+7`, e.g. `JEŻELI(ORAZ(MIESIĄC(D27)-MIESIĄC(DZIŚ())=0;DZIEŃ(D27)-DZIEŃ(DZIŚ()+7)=0);PRAWDA;FAŁSZ)`, and the same pattern can be reused for another date by changing the referenced cell and the offset to 60 days [#5962845] In Excel 2003 go to Format > Conditional Formatting, choose the Formula condition, and paste the formula there [#5966614] Then set the formatting you want, such as a highlight color, and copy that formatted cell to the rest of the target range with Paste Special > Formats so the rule applies across your list [#5966614] The same post also notes that you can replace TRUE/FALSE with text like “Birthday in 7 days” if you want a label instead of a logical result [#5962845]
  • #1 5962651
    promyk5
    A question for Excel 2003 magicians
    I have a customer base.
    I need to make an alarm go off for me - e.g. highlighting this person with a color, if:
    1) today's date retrieved with the function
    is 7 days less than the date of birth. So 7 days before the birthday of a given person, I need to know about it :)
    2) as above, but a reference to a different date and here I need to know 60 days before that date.
    And it would be great if this distinguished person appeared on the page from the menu to my database (first tab). Because my database consists of many tabs.
    Thank you in advance.
  • #2 5962845
    adamas_nt
    Help: 1508
    Rate: 659
    In the first case, you can apply conditional formatting where the remainder of the division of years will be zero.
    Formula:
    = IF (MOD (YEARFRAC (E2, (TODAY () + 7) * 1), 1) = 0, TRUE, IF (MOD (YEARFRAC (E2, (TODAY () + 6) * 1), 1) = 0 ;TRUTH FALSE))
    for 2 days (+6 and +7)
    You can use the same formula in the second case using values other than TRUE AND FALSE, eg "Birthday in 7 days" etc. in combination with VLOOKUP or as you see fit.
    Edit
    You can also combine the MONTH AND DAY functions:
    = IF (AND (MONTH (E2) -MONTH (TODAY ()) = 0; OR (DAY (E2) -DAY (TODAY ()) = 7, DAY (E2) -DAY (TODAY ()) = 6, DAY (E2) -DAY (TODAY ()) = 5)), TRUE, FALSE)
    for 3 days.
    Formula:
    = IF (AND (MONTH (E2) -MONTH (TODAY ()) = 0; OR (DAY (E2) -DAY (TODAY ()) = 0)), TRUE, FALSE)
    for 7 days.
    Whereas the formula:
    = IF (AND (MONTH (E2) -MONTH (TODAY ()) = 2, DAY (E2) -DAY (TODAY ()) = 0), TRUE, FALSE)
    will return 'TRUE' 2 months before the date in E2
    Or use a VBA using a function DatePart .
  • #3 5986533
    promyk5
    adamas_nt - I used this formula:
    =JEŻELI(ORAZ(MIESIĄC(D27)-MIESIĄC(DZIŚ())=0;DZIEŃ(D27)-DZIEŃ(DZIŚ()+7)=0);PRAWDA;FAŁSZ)
    And I get a true cell if my client has a birthday in 7 days.
    Now how do I make this client stand out?
  • #4 5986614
    adamas_nt
    Help: 1508
    Rate: 659
    Apply conditional formatting. Select the first cell of the range (columns), from the menu choose: Format> Conditional formatting and as a condition choose: 'Formula'. Paste the above-described one into the formula window and set the cell formatting as desired. Then right-click the formatted cell pm, select copy, select the range (column with names) in which the formatting is to work and select: 'paste special> Formats'. You will not "lose" the names entered in this way.
    However, in a cell in the formula you can change: TRUE; FALSE to e.g. "Birthday in 7 days"; ""
  • #5 8593236
    Pawel P.
    Rate: 24
    I will step on this topic.
    I am looking for a solution for excel to highlight cells with a date lower than today by, for example, a month.
    I've tried in various ways, but haven't managed to set it up yet.
    The point is that I set a review date and that a month earlier, excel would highlight this date for me with some color (e.g. yellow), and if it was reached or exceeded, it would also change to the next color (e.g. red).
    Thanks in advance for any suggestions.
  • #6 8594011
    marek003
    Level 40  
    Help: 801
    Rate: 488
    As you can see all the suggestions are above :)
    You can also yes
    create two conditions in conditional formatting (see above how)
    typing in the first
    =ORAZ(A1-DZIŚ()0)
    in the second
    [code:1:75df8f7e3c]=A1-DZIŚ()
  • #7 8622759
    Pawel P.
    Rate: 24
    This is how it works, only in the second condition it must be>, not = 0
    Thanks
  • #8 10007766
    m-haus
    I will connect to the topic. How to make selected cells highlighted on a specific day every month. Let's say two days before the date in yellow and the day of the date in red. And one more question, is it possible for the red underline to disappear after clicking on it?
  • #9 10011538
    marek003
    Level 40  
    Help: 801
    Rate: 488
    Do as described above.
    It is possible, but only through a macro.
    I propose (without a macro) to extend the conditional formatting with an additional condition in the style that if in the next cell there is the word "I KNOW" then the format returns to white.
    Of course, then, instead of clicking on the cell, write "I KNOW" in the next cell.
  • #10 10039635
    Lobo_PL
    I'm sorry in advance, but I am asking for the 2007 version
    I have a fleet of company cars and I did highlighting in Excel 30 days before the end date of the inspection and insurance, but can it be additionally done so that when the car is highlighted, information appears in the tasks in the Outlook program?
    best regards
  • #11 11006906
    darwaw007
    I attach a ready file with formulas.
    green color not older than 90 days
    yellow older than 90 days but not older than 180 days
    red color older than 180 days
    • formatowanie warunkowe daty.xls (14.5 KB) You must be logged in to download this attachment.
  • #12 11829754
    meyouwe
    I am probably duplicating the thread, but despite my sincere intentions and the time spent with advice on the forum and excel, I can't figure out a rule. I wanted to make it easier for myself to check the payment deadlines for invoices, so I created a table as in the attachment. I would like to include 2 elements in it.
    1) the cell with the invoice amount would become red if the due date has passed
    2) if I entered a date in the column for payment for VAT, the cell with the amount would change to green.
    Please support me :)
    • tabela fv.xls (17.5 KB) You must be logged in to download this attachment.
  • #13 11834669
    Maciej Gonet
    VBA, Excel specialist
    Help: 824
    Rate: 481
    The answer to Mrs. meyouve's problem.
    You need to select cell F2 and use conditional formatting (in Excel 2003 Format / Conditional Formatting) and enter conditions for formulas:
    Condition1: = ISNUMBER (H2)
    and format the background green. The invoice amount will turn green when a number is entered in the H column (it is not easy to verify that it is a date).
    Condition2: = AND (NOT (ISBLANK (G2)); G2
    • tabela fv.xls (28.5 KB) You must be logged in to download this attachment.
  • #14 13555394
    pinki110
    Rate: 12
    I need a formula that will highlight in red, as the date in A2 will be 7 days earlier than = TODAY () today is e.g. G5
    so as in A2 it will be April 22, 2014, cell A1 will be in red.
  • #15 13558065
    Maciej Gonet
    Help: 824
    Rate: 481
    In cell A1, conditional formatting according to the formula:
    if the red color is to appear for dates 7 days before the current date and remain so in the following days, or
    if the red color is to be only for 1 day for dates 7 days before the current date.
  • #16 17163257
    apple99
    please help with this formuka :( I can't get to that
  • #17 17211283
    marek003
    Level 40  
    Help: 801
    Rate: 488
    What can't you come with?
    Select a color formatted cell or an entire column where the cells are formatted, press conditional formatting and rule management ...
    You will see all condition formulas.
The discussion revolves around using Excel 2003 to highlight cells based on date thresholds related to birthdays and other significant dates. Users seek to create conditional formatting rules that will alert them when a person's birthday is 7 days away or when another specified date is 60 days away. Various formulas are suggested, including the use of the IF, MONTH, DAY, and TODAY functions to achieve the desired highlighting. Additionally, users inquire about extending these functionalities to include reminders for other dates, such as invoice due dates, and how to manage formatting across multiple tabs in a workbook. The conversation also touches on the use of macros for more complex conditions and the integration of Excel with Outlook for task management.
