Programme to monitor gains/losses in a zero-energy house with PV and HVAC?
kerado28 2106 4
  • Seeking software to monitor house energy gains and losses
    #1 13311805
    kerado28
    Welcome.
    We are looking for a program, a package that will make it easier for us to "pin down" a system that monitors gains and losses in a model home and show this online.
    Specifically:
    Assumptions:
    - a demonstration house where we want to put some data on the internet available online for internauts
    - room temperature sensors - 5 pcs.
    - humidity sensors - 2 pcs.
    - temperature sensor in the mechanical ventilation system:
    - on the air intake
    - on the outlet
    - on the supply air
    - on the exhaust
    - recuperator efficiency
    - amount of electricity consumption in underfloor heating system (electric heating)
    - amount of energy produced from photovoltaic panels
    Thank you for your help and reply
  • #2 13312232
    tomleszno
    Help: 19
    Rate: 61
    And airflow meters on the recuperator would also be useful, so as not to deceive people with super efficiency. Related to the topic, you need a PLC + panel. Data from some panels can be presented on the web. There are really many solutions. It all depends on the hardware. And first of all it depends on your budget.
  • #3 13319020
    kerado28
    When you write flow meters - do you mean capacity?
    If so, I rather don't see a sensible solution here....
    As for the costs: we would first have to know the difference between the different solutions, then we can decide which solution will be the most advantageous for us.
  • Fatek PLC and Falcon Server monitoring setup with costs
    #4 13321987
    pafciowaw
    Automation specialist
    Help: 480
    Rate: 365
    PLC:
    controller: Fatek e.g. Fbs-20MAJ2-AC -600 PLN (net)
    communication: FBs-CBE module (Ethernet) - 320,-
    temperature measurements: FBs-RTD16 module (16 RTD inputs) - 1200,-
    current measurements: FBs-6AD module (6 analogue inputs, 14 bits) -620,-
    NOTE: the number of inputs is "oversized";
    for this Falcon Server (free) - a PC program that communicates with the PLC and downloads data.
    Then the data as DDE can be sucked into excell and other applications.
    prices are from http://www.plcs.net.pl/index.php/katalog-auto...i/sterowniki-plc/fatek/view-all-products.html
  • #5 13374075
    kerado28
    Thank you for the information
