Man TGX 18.440 - AdBlue Issues, Error 05508-04, 05031-02, Filters Replacement & CAN Error NO1
mateuszyo 38574 9
What does MAN fault 05508-04 mean on a TGX 18.440 with AdBlue problems, and where should I look for the cause of the loss of power?
05508-04 is a CAN error for the NOx module (NO1 message / no signal), and 05031-02 points to an AdBlue pump blocked or too slow; after the filters were replaced, the 05031-02 fault went away [#13314497] The first place to inspect is the wiring harness and connector for the NOx module, especially behind the right front wheel arch where the harness can rub through [#13314423] In this case the actual fault was a burned connector pin in the NOx sensor plug caused by water ingress, and later it was found that the sensor electronics were also damaged [#13316880][#13349246] Replacing the NOx sensor and removing the short circuit cleared the problem [#13349246]
  • #1 13313734
    mateuszyo
    Rate: 100
    I have a problem with Man TGX 18.440, it stopped downloading adblue and the error 05508-04 and 05031-02 lit up. After replacing the main and pre-filters, 05031-02 (overspeed detection and pump motor lock) went out, but still 5508 CAN error (NO1 message) remained. The car has no strength. Any ideas what this error 5508 could mean and where to look for the reason?
    diablo23248
    Help: 102
    Rate: 614
    Check the wiring harness for the NOx module behind the right front wheel arch, it likes to rub. Tomorrow I will check Man-CATs what exactly this error means and I will let you know around noon if none of my colleagues will tell me.
  • #3 13314497
    MAN Electronics
    Help: 321
    Rate: 1717
    5031
    AdBlue pump blocked
    Check the AdBlue pump for operation and correctness. The pump speed in the activated state drops below the minimum speed.
    5508 CAN error (message NO1)
    Control of CAN messages for errors in timing, signals, comprehensibility
    Data record error
    Currently, there is no impact on the functionality of the system.
  • #4 13314616
    mateuszyo
    Rate: 100
    Thanks colleagues for the quick reply and suggestions. Buddy @ diablo23248, tomorrow I will check Nox and let you know. I also took out the injector and dispenser to clean, but I doubt that it will help.
  • #5 13316219
    diablo23248
    Help: 102
    Rate: 614
    As Colleague 5508-04 wrote, CAN error (NOI message) no signal.
  • #6 13316880
    mateuszyo
    Rate: 100
    Thanks again, fault diagnosed. The problem is a blown contact in the plug in the NOx sensor. Water got in (the rest scorched) Pin 1. Do you know if this sensor can be disassembled? Anyone doing this? Will I be replaced by one small pin?
  • #7 13316960
    MAN Electronics
    Help: 321
    Rate: 1717
    It is possible to undress, the rest is manual skill.
  • #8 13322003
    mateuszyo
    Rate: 100
    NOx disassembled, soldered, still error 05508-04 (regardless of whether the plug is inserted or not). Before that, there was definitely no contact. Where are the wires leading from this sensor?
  • #9 13322361
    serwis_gh
    Diesel injection systems specialist
    Help: 211
    Rate: 1238
    New sensor. How can you be sure that it will show the correct values? If there is a second car, it is worth swapping places.
  • #10 13349246
    mateuszyo
    Rate: 100
    Problem solved. The sensor electronics were also damaged. After replacing the sensor and removing the short circuit, the problem disappeared. A short circuit at the plug to the module burned NOx. Thank you very much to all forum members for their help.
The discussion revolves around issues with the MAN TGX 18.440 related to AdBlue system errors, specifically error codes 05508-04 and 05031-02. The user reported that after replacing the main and pre-filters, the 05031-02 error (indicating overspeed detection and pump motor lock) was resolved, but the 05508 CAN error (NO1 message) persisted, leading to a loss of vehicle power. Suggestions included checking the wiring harness for the NOx module for damage, inspecting the AdBlue pump for blockages, and diagnosing the NOx sensor for potential water damage. Ultimately, the problem was traced to a blown contact in the NOx sensor plug, which was repaired, but the sensor electronics were also found to be damaged. After replacing the sensor and addressing the short circuit, the issues were resolved.
