MAN TGX 480 - Adblue System, Emission Control Malfunction, GDK/PDF 5 05533-10 Error
sebotrucker 23769 5
  • #1 14066006
    sebotrucker
    Rate: 85
    Hello, about a year ago there was a general error of the adblue system, I fought with it for quite a long time, but I managed to do it for 20,000 hours, it was ok. exhale. After all, the error went out and it was ok. Now when I start the car everything is ok, but after driving a few km. the message "Malfinction emission control" 5 05533-10 is displayed and the balloon light with an orange exclamation mark starts flashing.
    The error is active all the time. After turning off the car and restarting, the indicator goes out, the error goes into a passive one. And again, after driving a few km, the same message is displayed, I noticed that when the engine is warm, the message lights up even after driving 1-2 km, and when cold, you need to drive even 10-15 km to get the error message. As of today, I replaced the large and small bosch strainer filters, the one in the ori cable. man. What does this error mean, I only know that the ending "-10" means a break, thanks in advance for your help :)
  • #2 14066124
    MAN Electronics
    Help: 321
    Rate: 1717
    sebotrucker wrote:
    Cleaning the injectors and dispenser i cooking in boiling water
    Hey, it's not potatoes... :D
    5533
    NOx sensor, internal error/NOx measuring cell
    NOx measuring cell check
    Short circuit, no signal
    MIL on/error memory entry.
  • #3 14066492
    sebotrucker
    Rate: 85
    Well, the important thing is that it helped :D
    So the silver cassette with the sensor or the sensor itself should be replaced? Because I know that the sensor itself can be replaced :)
  • #4 14072441
    MAN Electronics
    Help: 321
    Rate: 1717
    This "silver cassette" is a converter of the measured analog signal of the probe into a signal for the CAN bus that reads the controller (in simple terms, because not only).
    To what extent in your case it is only a damaged probe, I do not know, you can try replacing the probe itself, "almost" all brand manufacturers use VDO / NGK probes and they are interchangeable - the exception is the DAF EAS2 and the 2nd probe. But it may turn out to be a wrong lead ... because the probe itself may be good and the problem will be the electronics of the converter.
  • #5 14072539
    sebotrucker
    Rate: 85
    Damn thanks service technicianscani1 I have one more question if you can put a new one on this cassette from another car because manowska is terribly expensive and the numbers show that the scania and the renovate are the same and the price is not in comparison :)
  • #6 14369575
    lary_1981
    Rate: 26
    from DAFA you only need a different plug and replace the cables
