MAN TGX 18:480 2008 - Adblue GDK/PDF System Errors (05018-13, 05019-13, 01542-05) & Solutions
sebotrucker 41688 9
Why do AdBlue/GDK-PDF errors 05018-13, 05019-13 and 01542-05 appear at the same time on a MAN TGX 18.480, and where should I look for the fault?
The thread points to a wiring or connector fault in the AdBlue installation, especially in the harness near the AdBlue module/pump rack under the right wheel arch, rather than a bad dosing unit or heating valve [#17032020][#17044285] 05018-13 means AdBlue preheating valve open / temperature higher than expected, 05019-13 is AdBlue heating (tank heating valve) fault with short to plus/minus or interruption, and 01542-05 is a dosing device supply-voltage malfunction [#17031737] One suggested check is the beam under the AdBlue module about a meter from the plug, because wires can chafe there, and the tank heating valve should measure about 25–60 ohms [#17032020] In the solved case, a broken wire was found at the junction where the heating-valve harness joins the thick conduit to the pump, and another pink wire under the frame was damaged; repairing the cables with heat-shrink restored operation [#17044285] The fault also behaved intermittently with water/salt exposure, so checking plugs, cubes, and corrosion/dryness in that area is worthwhile [#17044285][#17035702]
  • #1 17031664
    sebotrucker
    Rate: 85
    After a four-day stoppage of the car, I got 4 errors in the GDK / PDF system
    5 05018-13 Active
    3 05019-13 Active
    5 01542-05 Active
    5 05527-12 Passiv
    The last one was deleted, the rest is still active or the message "malfunction emission control" may light up every now and then.
    What may be the problem? I will only add that the errors all appeared at the same time.
    kodar
    Help: 10
    Rate: 70
    05018 - 13
    Adblue preheating valve open, temperature higher than expected.
    05019-13 Aktiv
    Error criterion: Short to plus (12V) or minus, interruption.
    05527-12
    Temperature sensor in B996 (humidity sensor at the air filter). FMI12 indicates open circuit or short circuit to + Ubat
    malfunction emission control - malfunction of the emission control
    01542-05
    malfunction of the dosing device and its supply voltage
  • #3 17031988
    sebotrucker
    Rate: 85
    The error from the humidity sensor has gone out, the rest of the errors are active non-stop. In my opinion, the problem is with the installation, as all the errors occurred at the same time. Where to look for the problem, or possibly in which cables?
    dare23
    Level 19  
    Help: 32
    Rate: 242
    I would start searching in the beam under the adblue module on a distance of about a meter from the plug to the module. It happens that the wires are chafing there. Also check the resistance of the adblue tank heating valve, it should be between 25 and 60 ohms.
  • #5 17034180
    sebotrucker
    Rate: 85
    Today the car went on the road, after about 50 km the errors started to fade, but they fired again and all at once. Either there were all 3 or there were none. Now, after about 100 km traveled, the errors are gone and they do not burn. So I confirm that the problem is somewhere in the installation. The last snowfall plus salt and those are the results. Water has entered somewhere and that's why there are such circuses. Only on Saturday I will have the car free. First, I will check the resistance in the coil of the valve feeding the refrigerant fluid, then the dispenser also the resistance of the coil. Then I will check all the plugs and cubes at the module, dispenser, fluid valve, and at the sonar at the bottom of the tank. If I find nothing, I will write.
  • #6 17035702
    darfur5
    Help: 267
    Rate: 1715
    Start by disconnecting and reconnecting each plug, this way you will improve the conductivity of the connectors, they may become rusty.
  • #7 17037629
    sebotrucker
    Rate: 85
    Today it was ok for 150 km until there was water on the asphalt. Now the mistakes are back and they are burning non-stop. Dice checked, dry like pepper everywhere. I inadvertently forgot to connect the cubes at the fluid valve and the errors with the cube connected and disconnected are the same, nothing changes. There is nothing left for me to do but go on the valve cables. Well, unless the valve itself is damaged, but I will check it with a meter only when I return home for the weekend.
  • #8 17043290
    kakibara
    Help: 202
    Rate: 1284
    Check the orange plug on the right side of the tank, often green in the center or poor contact.
  • #9 17044285
    sebotrucker
    Rate: 85
    I had problems with this ankle last winter and a new one has been fitted.
    Today I struggled with the problem, I started by checking the resistance on the valve from the heating and the dispenser.
    Heating valve 28-30 Ohm, dispenser 13 Ohm.
    So the components are operational. After disconnecting the cubes from the dispenser and the fluid valve, the errors are the same with the FMI 13 tip.
    I started with the installation. The bundle that goes from the fluid heating valve connects to the thick conduit that goes to the pump. Just at this point, at the very junction, and precisely that plastic tee, one cable was broken from the heating control valve. The pink cable that goes from the pump somewhere under the frame was also completely eaten, but still held up. I cut a few cm, added the missing lengths, and welded them with heat-shrinkable sleeves. After turning the ignition on, the indicator light flashed a few more times and came on steadily. After starting the car, the diagnosis error 5 05018-13 Passiv 5 01542-05 Passiv, while 3 05019-13 Aktiv. So I went for Multidiaga. There was only one error left in Mulidiag, this 3 05019-13 error, which turned into a discontinuous error and into a passive error in the car diagnostics. I deleted it in diagnostics, everything went out together with the GDK / PDF system. Just in case, I spilled some preparation on the contacts, I did 15 km and so far everything works fine. I think the problem was in these corroded cables in the area of the right wheel arch, and exactly in the place of the adblue pump rack ;)
  • #10 20467882
    pavmotas
    Maybe someone can help with error 505006-09. And its description. Thanks.
The discussion revolves around the MAN TGX 18:480 (2008) experiencing multiple active errors in the AdBlue GDK/PDF system, specifically codes 05018-13, 05019-13, and 01542-05, which indicate issues with the AdBlue preheating valve, tank heating valve, and dosing device, respectively. Users suggest that the simultaneous occurrence of these errors points to potential wiring issues, particularly in the harness near the AdBlue module. Recommendations include checking the resistance of the heating valve and dispenser, inspecting connectors for corrosion, and ensuring proper connections. One user identified a broken wire in the installation, which was repaired, leading to a temporary resolution of the errors. However, the problem reappeared under wet conditions, indicating possible water ingress affecting the electrical components.
