Man TGX 18.440 - Understanding Adblue Error Code GDK/PDF 05530-01 and its Implications
Fast_international 22263 5
  • #1 14521733
    Fast_international
    Help: 6
    Rate: 87
    Today I got the error mentioned above. Adblue continues to download normally and the error is not active at the moment, but I would like to know what it says.
    Thank you in advance ;)
    daro111
    Help: 214
    Rate: 863
    5530 Monitoring of NOx emissions; Exceeded limit of NOx emission level 1 - cause unknown.
  • #3 14522453
    Fast_international
    Help: 6
    Rate: 87
    What could be the cause of this error?
    Thanks for deciphering the error ;)
    daro111
    Help: 214
    Rate: 863
    Possible reasons:
    - AdBlue leaks
    - bad quality of AdBlue
    - Exhalation valve does not close
    - Defective NOx sensor
    - Faulty catalytic converter
    It would be nice to diagnose the SCR system if everything is fine.
  • #5 14522546
    Fast_international
    Help: 6
    Rate: 87
    I would like to add that on a section of 1000 km, the error popped up 2 times, and each time I drove up a large hill with a full load. Today there are also some hills for me so I will be watching. Adblue continues to download. About 90,000 km have already passed from replacing the filters and checking the entire system, so maybe you would have to look into the first small filter, because Adblue always refuel in Germany or Austria and from the distributor, and with such refueling, I have no guarantee that the quality is approx. .
    I have not found any leaks anywhere, there is no dry and white sediment anywhere.
  • #6 14523495
    daro111
    Help: 214
    Rate: 863
    Fast_international wrote:
    Adblue continues to download. About 90,000 km have already passed from replacing the filters and checking the entire system, so you might have to look into the first small filter,
    First, replace the filters, test the SCR system. If the dosing is correct (amount of urea dosed), it remains to check the quality of the urea. If the above is ok, you need to look for the cause in the catalyst. It was here on the forum. look and read (not necessarily only for MAN).
