110V to 230V: Convert USA Lamp to Polish Standard E14 Bulb & Voltage Adaptation
if1 13878 12
Can I convert a 110V USA lamp to work on 230V Polish mains and change the bulb base from E12 to E14?
No, not safely if the lamp itself is rated for 110V; changing the bulb socket or using an adapter does not make a 110V fixture suitable for 230V, so it should be checked by an electrician and the housing’s rated voltage must be respected [#13338535][#13782871][#13784465] One reply says the wiring probably would not need replacement, but that was only a guess, not a guarantee [#13338553] If the lamp body is actually suitable and only the bulb base is the issue, another user reports buying 230V bulbs with a US thread and using a cheap bulb adapter, while only the plug was adapted/replaced [#13782926]
  • #1 13338517
    if1
    Is it possible to easily convert the lamp from the USA 110V to the Polish standard 230V and change the input of the bulb from the input to the TYPE B bulb (probably the E12 screw) to the typical Polish type, eg E14?
  • #2 13338535
    pylos
    Level 30  
    Help: 151
    Rate: 413
    You can. Take it to an electrician.
  • #3 13338539
    if1
    thank you for the quick reply :)
    and will it be necessary to replace the cables in the lamp?
  • #4 13338553
    pylos
    Level 30  
    Help: 151
    Rate: 413
    Perhaps, but I don't think there would be a need.
  • #5 13782665
    if1
    On the English auction site, I bought a plug / adapter from an American bulb to a European one that is screwed in before the bulbs. 110V to 230V: Convert USA Lamp to Polish Standard E14 Bulb & Voltage Adaptation The cost of a few zlotys and the lamp works perfectly :)
  • #6 13782824
    mikolaj.
    Rate: 47
    Until it burns out. As purely theoretically - as they teach me at school - it would be appropriate to count the resistance and throw in a current limiting resistor.
  • #7 13782871
    Łukasz-O
    Admin of electroenergetics
    Help: 654
    Rate: 4287
    You write nonsense.
    The 230V bulb will burn out? I think he's kidding about this current limiting resistor. However, I suggest being more careful in the lessons.
    I would focus more on the parameters of the "lamp" itself (chandelier, luminaire?), Mainly the rated voltage. If the manufacturer says 110V on the housing, under no circumstances can it be connected to higher voltage, even after using "adapters".
  • #8 13782926
    januszx3
    Help: 214
    Rate: 420
    I had the same problem as the author of the topic and I was able to buy 230V bulbs with a US thread in Poland without any problems. The source of these bulbs turned out to be small lamps with a cap, in plastic housings, put directly into contact, in shops with "Chinese food", such "everything" for a few zlotys.
    I solved the problem of plugs in two ways, with adapters in many stores in Poland, or cutting and replacing the plug. All the rest of the lamp installation, unchanged.
    Initially, having US bulbs in stock (for 120V), I connected the appropriate diode (1N1007, built in the plug) in series and powered it with 230V, there is a slight flickering 50Hz, but the bedside lamp, not for reading in bed, and you can bear this flickering (not all of them even pay attention to it).
    Regards.
  • #9 13782987
    olekt2002
    Level 32  
    Help: 147
    Rate: 512
    If possible, I would ask for an explanation of the contraindications.
  • #10 13783820
    mikolaj.
    Rate: 47
    Luke-O
    My fault, somehow I imagined that the author wants to connect a 230 bulb using a lower voltage, and in such a situation my idea would probably be appropriate?
  • #11 13783857
    Mazi_082
    You can connect two bulbs in series and the voltage problem is over your head, and as for the plug, as the colleague wrote above in the store, "everything for a few zlotys" is available.
    Regards Mazi
  • #12 13784465
    HeSz
    Electrician specialist
    Help: 97
    Rate: 198
    Actually, I should send you to read about basic electric shock protection. And there, the first way is - insulation (other such as insulation partitions, protective barriers, voltage drops, etc. are not possible in the case of a device such as a lamp. Ready lamp. may be higher than this voltage, then failure to adapt such a limitation is stupidity, in addition, stupidity "falling under the paragraph" as it threatens the lives of users of a given device.
    Regards.
  • #13 13784574
    Łukasz-O
    Help: 654
    Rate: 4287
    mikolaj. wrote:
    Luke-O
    Not. Would not be suitable. Please don't embarrass yourself.
✨ The discussion revolves around converting a USA lamp operating at 110V to the Polish standard of 230V and changing the bulb socket from E12 to E14. Participants suggest consulting an electrician for the conversion, with some indicating that replacing the lamp's internal wiring may not be necessary. Various solutions are proposed, including using adapters for bulbs and plugs, and sourcing 230V bulbs with US threads in Poland. Concerns are raised about the safety of using 110V bulbs with 230V power, emphasizing the importance of adhering to manufacturer specifications to avoid electrical hazards. Some users share personal experiences with adapters and modifications, while others caution against improper voltage adaptations.
