Roller shutter controllers F&F, Zamel, Eltako - which do you recommend for group control?
ekmir 4860 3
  • #1 13357361
    ekmir
    Help: 18
    Rate: 408
    I need controllers for roller shutters with motors so that they can be controlled locally and in groups. There are many solutions on the market. Please share your experiences in this area.
    Which controllers are worth considering and which should definitely be dispensed with?
    I have a total of 9 roller shutters on the ground floor and 7 roller shutters on the ground floor.
    I was planning to use F&F controllers but would like to get an opinion on this?
    Maybe others are worthy of consideration (e.g. Zamel, Eltako, Schrack, Hager etc.). The controllers will be placed in arrays - on a rail.
    Feedback would be greatly appreciated.
  • Satel INT-IORS enables flexible shutter and smart-home control
    #2 13360000
    jann111
    Help: 180
    Rate: 507
    Hello,I have dealt with F&F and Zamele and there are no major problems with them.A total of maybe a dozen installations.But if you are planning an alarm installation e.g. on Satel (Integra), you could use the expander wyiść INT-IORS.In short, I will say only this: simple installation, coupled with the alarm, control from a smartphone and virtually any configuration.Of course, you can use this expander to control various receivers up to 16A per output.The disadvantage may be the price, but in my opinion it is worth it.It is almost a smart home.
  • #3 13361366
    tomix
    Help: 7
    Rate: 99
    ekmir , I have done a total of three installations for roller shutters and all were also based on F&F from Pabianic + remote control with their PLC Max. So far they are working without any problems. On the other hand, in my workshop I have also used a lot of F&F modular apparatus, more complicated than the oversized ones, and there are sometimes problems with proper operation.
  • #4 13993422
    ekmir
    Help: 18
    Rate: 408
    What do you think of such a solution:
    single control based on F&F, and any groups created based on Satel expanders
