or-vid-js-1021 - sound inside the house only works very close to the microphone
szsemla 3432 3
  • #1 13376682
    szsemla
    After connecting the videophone Orno or-vid-js-1021 in order for me to hear anything inside the house I have to speak very close to the microphone, otherwise the microphone is kind of switched off. Is it possible to turn up the external panel or increase the sensitivity of its microphone because now using this videophone is very annoying.
  • #2 13420125
    polak2760
    Rate: 8
    If the equipment is under warranty send it for service.
    It is possible that the microphone hole is clogged - this should be checked. You may just need to increase the volume on the monitor - I had such a case:) - this is the cheapest possible video intercom so all sorts of miracles happen:)
    Regards
  • #3 14213976
    gregorypek
    i bought 2pcs.same thing no sound from the cassette at the wicket, I have been complaining for a month I demanded a cash refund I am still waiting.
  • #4 14578174
    gregorypek
    replacing the cable with a thicker one helped
