Actros MP4 - ACM Error 0C1112 & CPC Code 5AF3EE: Engine Light Flashing & Module Info
marekkas 52560 5
  • #1 13389285
    marekkas
    Rate: 38
    Hello everyone, as in the topic, what are these modules and what do these errors mean, the engine light is flashing. If someone had a whole list of MP4 errors, I would be very grateful.
  • #2 13389722
    serwis_gh
    Diesel injection systems specialist
    Help: 211
    Rate: 1238
    ACM is an exhaust gas treatment module (commonly called AdBlue.)
    The fault is the exceeded NOx value after the catalytic converter on the A57 sensor.
    It can only be deleted via VeDoc after testing the NOx sensors and possibly replacing them, sometimes 2.
    CPC is a fault in CAN communication with the MCM (engine module) on CAN four.
  • #3 13389861
    marekkas
    Rate: 38
    Ok, thanks, but the limited power message hasn't appeared yet.
    And you have a whole list of errors, maybe for the future :D
    serwis_gh
    Help: 211
    Rate: 1238
    I work on Star C4 and I didn't need to make a list of faults, I know most of ACM and MCM by heart. I will not copy the entire list for copyright reasons.
    Sorry, there will be no torque limit for this fault. There will be a limitation in the same fault, but with the following code: 0C1101 after the next engine start.
  • #5 15414948
    darek87rb
    Does anyone know something like ACM 65FOED error number 0004463154003?
  • #6 15417090
