Mercedes Actros MP 4 ACM - ACM error, low pressure Actros MP4
danuttzzro 11142 3
  • ACM fault with low air pressure and limp mode
    #1 20200868
    danuttzzro
    Hello everyone
    I have tested my truck and I am getting the following error message on the tester
    I have the following error
    AFTERTREATMENT CONTROL UNIT IS MISSING OR BROKEN
    Air pressure too low as well
    Also on the dashboard the engine light is on and low power
    What could be the reason, what needs to be changed?
    The ACM or the Nox sensor?
    Thank you
  • #2 20612618
    charitou
    ACM is installed near catalytic converter and gets so hot that sometimes parts are desoldered and come loose. Remove ECU and shake it and listen for loose parts.
  • #3 20612868
    Gerri
    Mercedes specialist
    Help: 865
    Rate: 3629
    Hi
    Is ACM control unit visible on the test? If not, first of all check supply voltage on small plug of ACM control unit.
    Remove the plug back cover and you will see red and brown wires - it's constant voltage from battery. On the pin "16" of the small plug (wire black/green) you can find voltage from ignition switch.
  • #4 20613819
    charitou
    Gerri is right! That is the first thing you do.
