Mercedes Actros MP4 - MCM 660012 Error Code: Motor Flashes, Power Loss & Troubleshooting
Andik1313 54261 15
How can I fix MCM error 660012 on an Actros MP4 when the engine light comes on and power drops?
Clean or replace the venturi tube first, because several users reported that this fixed MCM 660012 and the power loss [#17386793][#20054775] The venturi tube is at the very front of the engine, and the sensor is screwed into it from above; cleaning the small hole in the sensor/tube was specifically mentioned [#20303728] One user said replacing the turbocharger also cleared the fault and linked code 660012 with sensor B608 and the turbocompressor [#20056031] Another case needed an engine ECU software change after turbo and sensors had already been replaced [#20583305] If the fault returns after cleaning or replacing the venturi tube, the turbocharger, boost control, sensors, and ECU software are the next reported checks [#20056031][#20583305]
  • #1 17337660
    Andik1313
    Rate: 63
    In the Actros mp4 the motor flashes, there is a slight loss of power and the error code MCM 660012 is displayed. Any idea for the fault?
  • #2 17385593
    Adrian.86
    Rate: 49
    Hello, I have the same problem when it is hard up the hill after a long climb, the engine light comes on. MCM error 660012. The fault disappears when the car is lightly. Switching from normal to Eco driving mode helps, but going up the hill with Robur to Eco is paranoid. Nothing showed on the website. Someone something?
  • #3 17386793
    Andik1313
    Rate: 63
    For me, the topic is solved, the Venturi tube is replaced and the problem is gone.
  • #4 17588883
    Pan_gaman
    Rate: 41
    What tube replace?
  • #5 19703853
    aliveratrans
    Rate: 34
    Andik1313 wrote:
    I have the topic resolved, the venturi tube replaced and the problem disappeared.
    Hello what tube you have replaced??? Thanks
  • #6 20054213
    ariateline
    Rate: 18
    I have a problem too. Replacing the turbo sensor did not help. All sensors have been replaced without improvement. Anyone have an idea?
    Adrian.86 wrote:
    Hello, I have the same problem when it is hard up the hill after a long climb, the engine light comes on. MCM error 660012. The fault disappears when the car is light. Switching from normal to Eco driving mode helps, but going up the hill with Robur to Eco is paranoid. Nothing showed on the website. Someone something?
    Did you fix it?
  • #7 20054775
    Tiromaniak
    Try cleaning or replacing this tube as your colleague mentioned. At a friend's, after cleaning, the fault has ceased. Likewise, they changed the boost sensors, the turbines did not do anything.
    Additionally, if the Mercedes is weak and smokes a lot, I recommend to plug the retarder (if any) and code it. At a colleague's, after being blinded from 30/31, he went down to 27 with full charge.
  • #8 20055260
    ariateline
    Rate: 18
    What exactly are we talking about? About the EGR exhaust pipe or the turbo pipe?
  • #9 20056031
    aliveratrans
    Rate: 34
    I am fixing this problem with the turbocompressor. I have changed the turbo and all is ok, the error code 660012 and the sensor B608 is due to the turbocompressor.
  • #10 20057759
    ariateline
    Rate: 18
    So, if I understand correctly, have you finally replaced the entire turbocharger? Was the turbo failure related to oil consumption?
  • #11 20074558
    aliveratrans
    Rate: 34
    I am changed yes the turbocompressor, 2 weeks all ok, after 2 weeks now today the same error come back.... i will change the tubes, but i don't know which tubes, the tube of turbo when is the sensor for turbo, or the tube after EGR. Some people can help me which tube i can change?
  • #12 20075981
    ariateline
    Rate: 18
    Did DPF regeneration become more common than average? The AMC module interferes with the EGR control, the turbocharger may not have enough exhaust gas ... Check the data on the NOX sensors first!
  • #13 20077773
    ariateline
    Rate: 18
    Is the turbopressure control unit (A0001531559) fault not possible? my 1845 Actros, makes a mistake when the weather temperature is over 30 degrees Celsius. I suspect the pressure control unit will malfunction due to heat. Turbo pressure control unit with number A0001531559 on a workshop table.
  • #14 20303393
    Arti04
    I had the same errors and it turned out that AdBlue injection was pouring, it led to clogging of the muffler. I cleaned it and it's ok now.
  • #15 20303728
    citromaniak
    Help: 53
    Rate: 389
    The venturi tube is at the very front of the engine, the sensor is screwed into it from the top. The sensor is removed and cleans this small hole if I remember correctly.
  • #16 20583305
    elawar80
    I fixed this error after 3 months of trouble and after turbo and all sensors changed and failed. I changed the engine computer software and now everything is wonderful.
✨ The discussion revolves around the MCM error code 660012 in the Mercedes Actros MP4, characterized by engine light activation, power loss, and issues during uphill driving. Users report various troubleshooting steps, including replacing the Venturi tube, turbocharger, and sensors, with mixed results. Some found success in cleaning the turbo pipes or changing the engine computer software. Others suggested checking the DPF regeneration frequency and NOX sensors, as well as the turbo pressure control unit, especially under high temperatures. The Venturi tube's location and its sensor were also highlighted as critical components in resolving the issue.
TL;DR: 30°C heat can trigger MCM 660012; "my 1845 Actros makes a mistake when the weather temperature is over 30 degrees Celsius." This FAQ helps Actros MP4 owners fix motor flash and power loss from code 660012 with clear checks and field‑tested fixes. [Elektroda, ariateline, post #20077773]
Why it matters: It cuts downtime and avoids needless parts swaps by prioritising checks you can do fast, on-road or in-shop.
What symptoms go with MCM 660012 on an Actros MP4?
Typical symptoms include a flashing engine warning, slight power loss, and MCM 660012 shown on the display. [Elektroda, Andik1313, post #17337660]
Does switching to ECO mode help when 660012 appears uphill?
Yes. One driver reports the engine light during hard climbs and that “Switching from normal to Eco driving mode helps.” It’s a temporary workaround under load. [Elektroda, Adrian.86, post #17385593]
What is the Venturi tube and where is it on the MP4?
It’s an intake Venturi with a small sensing orifice. “The venturi tube is at the very front of the engine, the sensor is screwed into it from the top.” Cleaning the orifice can restore readings. [Elektroda, citromaniak, post #20303728]
How do I clean the Venturi tube to try clearing 660012?
Three steps:
  1. Locate the front‑of‑engine Venturi and remove the top‑mounted sensor.
  2. Clear the small sensing hole/orifice of soot deposits.
  3. Refit the sensor, clear the code, and road‑test under load. [Elektroda, citromaniak, post #20303728]
Did replacing the Venturi tube actually fix this code for anyone?
Yes. One owner states, “the Venturi tube is replaced and the problem is gone.” Cleaning is a quicker first try, but replacement also works. [Elektroda, Andik1313, post #17386793]
Which tube should I look at—EGR pipe or turbo pipe?
Focus on the Venturi tube at the very front of the engine with the sensor on top. That’s the piece people clean or replace. [Elektroda, citromaniak, post #20303728]
I replaced boost and turbo sensors and still have 660012. What next?
Try cleaning or replacing the Venturi tube. A member reports sensors and turbo work did nothing, while Venturi cleaning resolved the fault. [Elektroda, Tiromaniak, post #20054775]
Could the turbocharger itself be the cause of 660012?
Yes. One report says replacing the turbo cleared MCM 660012 and sensor B608 faults. Verify boost control and mechanical condition before replacement. [Elektroda, aliveratrans, post #20056031]
Why did 660012 return two weeks after a new turbo?
One owner had the code return after two weeks and considered replacing related tubes next. Inspect piping near the turbo and EGR paths. [Elektroda, aliveratrans, post #20074558]
Can heat or the turbo pressure control unit trigger intermittent 660012?
Heat can matter. “My 1845 Actros makes a mistake when the weather temperature is over 30 degrees Celsius.” The pressure control unit A0001531559 was suspected. [Elektroda, ariateline, post #20077773]
Could AdBlue or DPF issues cause similar power loss and codes?
Yes. An over‑injecting AdBlue system clogged the muffler/DPF. After cleaning, performance and errors normalized. Check dosing and backpressure if regens spike. [Elektroda, Arti04, post #20303393]
Should I check NOx sensors or the AMC module if regens are frequent?
Yes. One tech notes the AMC can affect EGR control. Verify NOx sensor data first when DPF regenerations become unusually frequent. [Elektroda, ariateline, post #20075981]
Can an ECU software update resolve stubborn 660012 cases?
It can. A member fixed the error after months by updating engine computer software: “now everything is wonderful.” Use professional flashing tools. [Elektroda, elawar80, post #20583305]
Is it normal for diagnostics to show little besides 660012?
It happens. One driver saw the fault during climbs, but “Nothing showed on the website.” Capture live data under load to catch it. [Elektroda, Adrian.86, post #17385593]
