Samsung UE46C6000: Vertical Stripes Obscuring Image at Cold Start - LTF460HJ03 Matrix Issue?
Top Serwis 27600 9
Why do cold-start vertical stripes appear on a Samsung UE46C6000 and then disappear after a few minutes?
The fault is most likely on the main board, specifically the graphics/scaler chip, not the matrix or T-con. One diagnosis noted that with the rear panel removed, twisting the casing changed the symptom, and loosening the motherboard screws made the problem disappear [#13427141] A later check narrowed the search to the main board and concluded that BGA reflow did not help because the graphics chip/scaler was damaged [#13493327] The suggested remedy was motherboard replacement [#13423051], and after the board was replaced the TV worked normally again [#13519908]
  • #1 13422174
    Top Serwis
    Help: 66
    Rate: 242
    When turned on, cold vertical stripes appear that obscure the image content, disappear after about 5 minutes. Chilling T-con and motherboards correctly operating TV does not evoke malfunction. Probably something with the LTF460HJ03 matrix electronics.
    Maybe someone had a similar fault? Samsung UE46C6000: Vertical Stripes Obscuring Image at Cold Start - LTF460HJ03 Matrix Issue?
  • #2 13422205
    piasek3322
    Top Serwis wrote:
    Chilling T-channel and motherboard correctly operating TV does not evoke malfunction.
    Because the matrices cool the "genius".
    "RTV service" horse would laugh.
    marek07
    Help: 24
    Rate: 75
    replacement of the motherboard
  • #4 13423146
    mirex
    Help: 1950
    Rate: 1990
    And you will pay for this "advice"?
    Or otherwise ...
    I understand that this is a "tip" and offer to sell in one, so send this album to your colleague, and join me right away ... 2 dicons for a return shipment if you need it. ;)
    Did not you teach your spelling?
  • #5 13423991
    marek07
    Help: 24
    Rate: 75
    I see that erudition is unenviable
    Moderated By radsat:
    3.1.13. It is forbidden to publish entries that violate the spelling rules of the Polish language, careless and incomprehensible. Next time there will be a prize.
  • #6 13427141
    Top Serwis
    Help: 66
    Rate: 242
    When the rear panel was removed, the TV reacted to twisting the casing.
    Loosening the screws from the motherboard, the problem resolved. I will do reballing bga systems.
  • #7 13427474
    zbyszekskibinski
    Help: 179
    Rate: 340
    Hello, I do not understand why a colleague wanders to determine where the fault may be, in the matrix, T-con or maybe the motherboard, you can not determine whether the stripes appear during OSD / MENU only or not and do not narrow down with the reduction of image proportions as well whether they appear immediately after turning on the TV-then you could come to some conclusions without measurements even.
  • #8 13493327
    Top Serwis
    Help: 66
    Rate: 242
    Search area narrowed to the main board. BGA overdraft does not work, the graphics chip / scaler is damaged. To confirm the theory another damaged plate from the series "6"
    Typical product aging effect, after warranty and on TV.
     If someone repairs these CDs, please use PW.
    Greetings.
  • #9 13493912
    zbyszekskibinski
    Help: 179
    Rate: 340
    piasek3322 wrote:
    Top Serwis wrote:
    Chilling T-channel and motherboard correctly operating TV does not evoke fault.
    "RTV service" the horse would laugh.
    And what? However, this is not a matrix?
  • #10 13519908
    Top Serwis
    Help: 66
    Rate: 242
    Disc replaced, Tv regained fitness.
The discussion revolves around a Samsung UE46C6000 television exhibiting vertical stripes on the screen during cold starts, which disappear after approximately five minutes. The issue is suspected to be related to the LTF460HJ03 matrix electronics. Various responses suggest potential causes and solutions, including the possibility of a faulty motherboard or T-con board. One user noted that loosening screws on the motherboard resolved the issue temporarily, while another identified a damaged graphics chip/scaler on the main board as the root cause. Ultimately, replacing the damaged board restored the TV's functionality.
