Samsung UE46EH6030 - Darkened Half Screen, Slow Refresh & T-Con Board Replacement Outcome
cash988 15219 4
  • #1 16396070
    cash988
    Hello, I have a problem with the TV picture. More than half of the screen is dim, it wakes up slowly and at the left end the refresh is very slow, the rest of the screen is fine. I turned on the TV but you can't see anything that was burned out, etc. I tried to do it as in the movie but it did not work.
    I replaced the T Con Board with a new one and nothing helped (luckily I can give it back). I have unhooked the T Con tape from one panel but there is also a bit of a darkened screen on the other half. I don't have much possibility to fix it at home, I would have to send it. What could be the reason, is it profitable to repair it?
    Samsung UE46EH6030 - Darkened Half Screen, Slow Refresh & T-Con Board Replacement Outcome Samsung UE46EH6030 - Darkened Half Screen, Slow Refresh & T-Con Board Replacement Outcome
    Andrzej4567
    Help: 26
    Rate: 252
    The matrix glass is damaged.
    Please enter the matrix model as there is.
  • #3 16399964
    cash988
    LTJ460HW10-V
  • #4 16400604
    Andrzej4567
    Help: 26
    Rate: 252
    You can try to fix it, but you need to have a lot of practice in this type of repair.
  • #5 16402024
    cash988
    I could send for repair, but will the repair price not be too high (e.g. more than 50% of the TV price)? Can you order matrix glass somewhere?
