Using Original PC USB Adapter 6ES7972-0CB20-0XA0 & 6GK1571-0BA00-0AA0 on VirtualBox with Win XP SP3
UFO_79 2928 5
  • #1 13444597
    UFO_79
    Help: 5
    I warmly welcome!
    Does anyone who has the original PC USB Adapter (6ES7972-0CB20-0XA0 or 6GK1571-0BA00-0AA0) possibly check and share information if it works correctly on a virtual machine? On VirtualBox I have put Win XP SP3 along with the whole Simens soft (Step 5.5, WinCC flexible etc.) and before I decide to buy the mentioned adapter I need to find out if I can easily connect with controllers, panels etc.
    I would like to thank you for any comments in advance.
    ILSSystem
    Automation specialist
    Help: 40
    Rate: 18
    I confirm, it works without any complaints.
    ILS SYSTEM Sp. z o.o.
    Hoffmanowej 19, Rzeszów, 35-016 | Company Website: www.ilssystem.pl
  • #3 13444916
    UFO_79
    Help: 5
    Thank you for the info. Do you know if other adapters (PCI, PCMIA) also work peacefully under a virtualbox?
  • #4 14688458
    grabek_radek
    Rate: 37
    I have another question for you, namely, connecting to this programmer for the profibus CPU input .... it only supports you 1.5 Mb speed, because if I change the network to 12 Mb I do not have a connection yet?
