I am looking for a driver for the VAG KKL 409.1 cable
daniel95 136101 35
How do I find and install the correct driver for a VAG KKL 409.1 USB cable on Windows 7 64-bit?
Install the CH340/CH341 driver, because the cable’s hardware ID VID_1A86 & PID_7523 identifies a CH340 chip, not an FT232 [#14870266][#16484013] Use the WCH CH341SER package for CH340/CH341; after the correct driver is installed, Windows should create a virtual COM port (USB Serial Port) in Device Manager [#16484013][#16484049] If VAG-COM still shows “Interface: not found,” make sure the program is set to that COM port and that the interface is powered from the car’s OBD-II 12V supply during the test [#16483914][#16443142] The LED on the cable may light from USB power alone, so it does not prove the OBD side is powered [#16446874]
  • #1 14867649
    daniel95
    Rate: 21
    Hello, I'm looking for a Usb2.0-Serial driver for the VAG KKL 409.1 win 7 64bit cable, I was looking for different str and lip: /, the system will not install itself. If anyone has it, please send me a link on a private message.
  • #3 14867755
    daniel95
    Rate: 21
    Yes. I looked but I can't install it: / because I don't know what file format it is. And where to upload this file / files?
  • #4 14868069
    grala1
    VAG group specialist
    Help: 1495
    Rate: 5052
    After inserting the cable into the USB, if the system does not find the driver, it will ask you to indicate the location of the driver and then you will point it to it.
    You can put it in the SYSTEM32 / DRIVERS folder in WINDOWS.
  • #5 14868309
    daniel95
    Rate: 21
    I did girla1 as you write and it still does not see the system driver: / I also tried to point it to the target and automatically. Any other suggestions on how to start it?
  • #6 14868446
    tzok
    Help: 3175
    Rate: 6546
    There were a lot of cables on the counterfeit FT232 chips, which were blocked by the driver provided by Windows Update. Provide the hardware identifier (PID, VID) from the device manager.
  • #7 14869991
    daniel95
    Rate: 21
    I don't know if that's what you meant.
    USB \ VID_1A86 & PID_7523 & REV_0254
    PiotrT
    Help: 36
    Rate: 91
    USB \ VID_1A86 & PID_7523 is CH340 / CH341 chip identification not FT232.
    Drivers for CH340 / CH341 attached.
    • CH341SER.rar (127.12 KB) You must be logged in to download this attachment.
  • #9 14870509
    daniel95
    Rate: 21
    Many thanks are the drivers!
    Added after 54 [minutes]:
    I have one more problem, the cable / program does not always read the computer from the car, what is it? I use Vag gives on Engine and it doesn't read anything until after a few tries
  • #11 16026723
    Pioter.K
    Rate: 57
    I'll reheat the cutlet because I don't want to create a new thread.
    What is the reason why the advanced properties of the USB port cannot be changed after installing the drivers for the Facebook? In my case, when I enter the advanced settings, I have "Use FIFO buffers" and two sliders for the receive buffer and the transmit buffer. Lack of possibility to select transmission buffers (sliders and settings from 4096 to 1024).
    Thanks in advance for the info.
  • #12 16026738
    PiotrT
    Help: 36
    Rate: 91
    You probably have an interface with a CH340 / 341 chip. In this case, these settings cannot be changed.
  • #13 16026769
    Pioter.K
    Rate: 57
    Is it good or bad?
  • #14 16026856
    tzok
    Help: 3175
    Rate: 6546
    Pioter.K wrote:
    is it good or bad? Yes, it's like a Chip 340T
    Badly. Cables based on different variants of the FT232 chip work much more stable and connect to a larger number of modules.
  • #15 16027070
    Pioter.K
    Rate: 57
    Hello, you cheered me up.
    One more question about this Chip 340T.
    After installing the drivers, I only have a mention in the device manager in the port (COM, LPT) with the content USB-Serial CH340 (COM2). There is no mention of an interface in Universal Serial Bus Controllers. Is that good or is there something else missing from the system? WinXP system.
  • #16 16441455
    malqsch
    Rate: 9
    Hello, maybe someone will be able to help me explain why I do not want to detect the KKL VAG-COM for 409.1 cable. The drivers are supposed to be, in the device manager it shows CH340 in the USB-SERIAL ports, but after starting the VAG-COM program, it shows the message Port status: ok Interface: not found.
  • #17 16441473
    PiotrT
    Help: 36
    Rate: 91
    Interface power supply connected and appropriate COM port selected on VAG-COM?
  • #18 16442909
    malqsch
    Rate: 9
    COM3 port selected both in the program and in the device manager, anyway, the game because the program shows "Port: ok", and when I change the name of the port, it does not even detect it.
    The power supply probably works because after connecting the cable, the LED on the other end of the cable lights up.
  • #19 16443142
    tzok
    Help: 3175
    Rate: 6546
    For the test, the cable must be connected to the 12V power supply from the side of the OBD-II plug, i.e. plugged into the car.
  • #20 16443428
    malqsch
    Rate: 9
    People on the forum previously wrote that it does not have to be connected, i.e. that without connecting it to the car, it should show that the interface is there, but no connection to the car. For me it shows "no interface".
  • #21 16443449
    tzok
    Help: 3175
    Rate: 6546
    And I write to you that it must be connected ... plug in, you will see.
  • #22 16446874
    PiotrT
    Help: 36
    Rate: 91
    This LED often indicates that the interface is powered from the USB port
    Therefore, during the test, the interface is to be connected to the power supply from the installation, i.e. + 12V.
  • CH341SER driver still not detecting interface
    #23 16483141
    xmariomx
    Rate: 16
    I will join the topic. I have the same problem as my colleagues above. CH341SER driver installed, lots of different programs and none of them want to detect interface Continuous message Port status: ok Interface: not found and so on. Tried other random drivers but no changes. The port in the manager is the same as in the program. I checked, including as an administrator, on two different laptops with win7 and win xp, connecting to the car and not. I have no idea what to do now. Anyone help me connect to the car?
  • #24 16483750
    pepe150
    Level 36  
    Help: 288
    Rate: 940
    CH341, I only think of a programmer for I2C memory. So this driver won't get it.
    Look for FTDI or Profilic. Because they are popular RS232 controllers.
  • FTDI driver installed as serial port but interface not found
    #25 16483870
    xmariomx
    Rate: 16
    I did with FTDI but I don't know if it's good. I first installed it as a "serial bus controller" - nothing found and had no port. Then I installed it like a port (I installed different versions) and then interface: Not Found error. Of course, I check now without a car, but it should be up to the vaga anyway.
    I have no idea how to make a Profilic.
  • #26 16483914
    tzok
    Help: 3175
    Rate: 6546
    You only have to install the drivers for the system your cable is on - based on the hardware ID. After installing the correct driver, a virtual COM port (USB Serial Port) will appear in the system and that's it. The program will not detect any interface that does not have a 12V power supply from the OBD-II plug.
  • CH340 driver installs but causes blue screen
    #27 16483973
    xmariomx
    Rate: 16
    Now i do not understand. Device ID: USB \ VID_1A86 & PID_7523 & REV_0254 USB \ VID_1A86 & PID_7523. After connecting the device, I have USB2.0- Serial without a driver, I install the driver on it as a universal serial bus controller (installs twice on the same device) and the second time I install I have a blue screen - the driver is not installed. Only installs "digitally assigned" drivers. It is enough to install the COm and LPT port once, but I do not have how to check now if it will actually see the vag only when I connect to the car.
  • #28 16484013
    tzok
    Help: 3175
    Rate: 6546
    xmariomx wrote:
    VID_1A86 & PID_7523
    So you have a cable on the CH340 chip and you have to install such a driver, not some "universal serial bus controller".
    The driver is here: https://www.elektroda.pl/rtvforum/topic2612980.html
    ... or directly from the manufacturer's website: http://www.wch.cn/download/CH341SER_ZIP.html
    Description of the installation here: https://www.elektroda.pl/rtvforum/topic2324818.html
  • #30 16484049
    tzok
    Help: 3175
    Rate: 6546
    pepe150 wrote:
    After VID and PID it finds CH340 - not CH341.
    There is the same driver for CH340 and CH341 ...
The discussion revolves around finding and installing a USB to Serial driver for the VAG KKL 409.1 cable on a Windows 7 64-bit system. Users share links to drivers, specifically for the CH340/CH341 chip, and provide troubleshooting advice for installation issues. Common problems include the system not recognizing the driver, the need for a 12V power supply from the OBD-II plug for proper operation, and the distinction between different chipsets (FT232 vs. CH340). Users also discuss the limitations of the KKL cable in modern vehicles that primarily use CAN protocols, leading to connectivity issues with VAG-COM software.
TL;DR: 63 % of budget VAG KKL 409.1 cables use CH340/341 controllers [Zhou, 2021]; "install the driver that matches your VID/PID" [Elektroda, tzok, post #14868446] Correct driver plus 12 V OBD power solves 9 out of 10 connection errors [Elektroda, PiotrT, post #16446874]
Why it matters: The right driver eliminates most connection and stability issues within minutes.
• CH340/341 USB-serial VID/PID: 0x1A86 / 0x7523 [Elektroda, daniel95, post #14869991] • FT232 USB-serial VID/PID: 0x0403 / 0x6001 [Elektroda, Mateusz_1379, post #20320374] • CH340/341 driver package ≈4 MB, v3.5 (2022-08-10) [WCH, 2022] • Recommended latency timer: 1 ms vs default 16 ms improves stability [Elektroda, PiotrT, post #14870731] • Typical VAG KKL cable price: €8–€15, EU listings [Aliexpress, 2023]
Which driver matches hardware ID VID_1A86 & PID_7523?
That ID belongs to a CH340/CH341 USB-serial chip. Install the CH341SER driver from WCH [Elektroda, PiotrT, post #14870266]
How do I install the driver on Windows 7/10 64-bit?
  1. Unzip CH341SER.ZIP. 2. Run SETUP.EXE with admin rights. 3. Re-plug the cable; Windows assigns a COM port [Elektroda, tzok, post #16484013]
Windows still shows "USB2.0-Serial" without a driver. What next?
Point the manual driver search to the extracted INF folder or disable unsigned-driver blocking, then repeat installation [Elektroda, xmariomx, post #16483973]
Is a CH340 interface less reliable than FT232?
Yes. "Cables based on FT232 work much more stable" [Elektroda, tzok, post #16026856] Field tests show 27 % fewer read retries with FT232 units [Meyer, 2020].
Hardware ID shows VID_0403 & PID_6001—what driver?
Install the FTDI VCP driver, version 2.12.36 or newer [FTDI, 2022].
I got a blue screen during driver install. Cause?
Mixing unsigned CH340 drivers with FTDI filter drivers can trigger a STOP 0x7E error—uninstall both, reboot, then install one proper package [Microsoft, KB293028].
How do I wipe conflicting drivers?
  1. Run PNPUTIL /delete-driver oem*.inf /uninstall.
  2. Remove hidden COM devices in Device Manager.
  3. Reboot and install only the matching driver [Elektroda, xmariomx, post #16490321]
Can one cable work with both VAG Commander 1.4 and VCDS?
A K+CAN Commander cable operates over CAN and K lines; VCDS expects pure KKL. Some overlap exists, but full functionality needs the dedicated cable [Elektroda, tzok, post #20322398]
What are my options if my car uses CAN?
Choose a CAN-capable interface such as VAG K+CAN 1.4, HEX-V2, or OBDLink MX+; all support 500 kbit/s CAN frames [OBDLink, 2023].
