DC Motor GR63x25 with Encoder RE30-2-500: Pin Descriptions, Wire Connections & 5-Pin Socket
gargulajan 12609 3
  • #1 13447128
    gargulajan
    Rate: 14
    Hello all,
    I have a request for more insiders in the encoders,
    I have a DC motor type GR63x25 with encoder RE30-2-500.
    Unfortunately, I do not know which pins on which pins this encoder has. In addition, four wires leave the plug and the socket has 5 pins. Is the missing pin in the plug needed. If so, does anyone know what type of plugin it is. I add photos with a motor and an encoder
    DC Motor GR63x25 with Encoder RE30-2-500: Pin Descriptions, Wire Connections & 5-Pin Socket DC Motor GR63x25 with Encoder RE30-2-500: Pin Descriptions, Wire Connections & 5-Pin Socket
    Thank you for your help and best regards
  • #3 13451957
    gargulajan
    Rate: 14
    I was browsing this page and pdfa from this encoder, but I could not understand what a kaman. I looked at it once more, and I think something is brightening up.
    Pytanko still small or pin up to + 5V.
    Someone knows what is the type of plug for this encoder, because I would have to add a five-wire cord to it.
    The resistors are inside the encoder and must be included in the application.
  • #4 13484785
    ideal666el
    Everything is fine, it's supposed to be. It is a motor, encoder and transmission specially prepared for the control panel of Besam Uni Slide Double door automation. I do not know what you want to use, but as for something other than this drive, it offers you a change. I have different engines from different drives, even with a transformer. I specifically need this model with the RE30-2-500 encoder and the GR63x25 engine and the SG80K 10: 1 gearbox. If you are interested, please contact me urgently.
    tel. 535999402
    e-mail: ideal-legnica(_at_)wp.pl
