7-room detached house: DHT11 temp/humidity sensors with one control panel?
Luk4sz666 2856 2
  • #1 13475972
    Luk4sz666
    i want to put a temp and humidity sensor in each room (7 rooms), (e.g. dht11 or other) and connect these sensors to some kind of control panel. A control panel in the form of just a display(s) or some kind of computer connection. I am looking for something simple and reasonably cheap. I can plaster the cables from the sensors to the control panel. Do you have any ideas?
  • #2 13476086
    trance123
    Help: 27
    Rate: 134
    Type smart home into the search engine there is a ton of it, DS18B20 on twisted pair 5 category etc.
  • Bluetooth 4.0 wireless sensors with year-long battery life
    #3 13558538
    Pawel2420
    Help: 136
    Rate: 101
    If the distances are not great then you can use wireless sensors. For example, we make ones that communicate via Bluetooth 4.0. They cost a little under £100. Dimensions: diameter 32mm, thickness 9.5mm. A CR2032 battery lasts almost a year.
    They transmit measurement results online and also archive them in the internal memory. They can also send an alarm when the programmed values are exceeded.
