Accessing BIOS on Sony VAIO SVF152C29M: Key Combination & Step-by-Step Guide
horh3 46506 8
  • #1 13501213
    horh3
    Maybe I am dealing with a flimsy problem, but I am not able to cope with the bios input of exactly this Sony SVF152C29M model. I've been looking everywhere, including videos on YT and nothing, I can't help myself. Maybe some of you know what key the bios starts with. Please help.
  • #2 13501380
    dt1
    Admin of Computers group
    Help: 7315
    Rate: 8292
    In many Sony laptops, the BIOS is entered by pressing the VAIO CARE button with the laptop turned off. I don't know if your particular model will respond the same :)
  • #3 13602608
    ergie
    Help: 34
    Rate: 291
    Zapożyczone z innego forum:
    F10 – Recover or maintain your system
    F11 – Start from media (USB device/optical disc)
    F12 – Start from network
    F2 – Start BIOS setup
    F4 – Shut down
    In case you’ve Windows 8 on the VAIO netbook follow this steps:
    press once the button ASSIST
    Switch it on
    Wait and at the menu press F2 for bios
  • #4 13603154
    BigPunisher
    Everything's fine, but I didn't have Win8 on the board and I don't ... So how do I do it?
  • #5 13603282
    ergie
    Help: 34
    Rate: 291
    So the F2 key does not work? (press it sequentially)
  • #6 13606701
    BigPunisher
    It works, but how can I upload a new system without a CD?
  • #7 13606908
    ergie
    Help: 34
    Rate: 291
    You asked to enter the bios and not reinstall the system.
  • #8 13606939
    qkiz_xt
    Rate: 20
    If you want to reinstall the system you originally had in your laptop, use the recovery.
  • #9 13606970
    ergie
    Help: 34
    Rate: 291
    In windows, start all programs, look for something with the name "Recovery".
    Just before you do anything about it, protect your data (move it to another drive, e.g. external) so that you don't delete important things.
To access the BIOS on the Sony VAIO SVF152C29M, users typically need to press the F2 key during startup. Alternatively, for models with Windows 8, pressing the ASSIST button while the laptop is off and then selecting F2 from the menu can also work. Other function keys mentioned include F10 for system recovery, F11 for booting from media, and F12 for network booting. If the F2 key does not respond, users are advised to press it sequentially. For system reinstallation, users should utilize the recovery options available in Windows, ensuring to back up important data beforehand.
