[Solved] ASUS F555LJ-XO948T Win10: Can't Access BIOS with F2 During Startup - Solutions?
kopcisię 43737 6
  • #1 17332111
    kopcisię
    Rate: 17
    Laptop Asus F555LJ-XO948T Win10 does not respond to F2 at startup, every time Windows starts, the F2 button when the system starts working properly. Any ideas or hints?
  • #3 17332145
    kopcisię
    Rate: 17
    I'm just writing that doesn't work. What would you do in such a situation?
    Bios reset? Before I spin it, I prefer to ask, maybe someone has encountered such a problem?
  • #6 17332269
    kopcisię
    Rate: 17
    Thanks "damkon"!
    in your link it is written that instead of closing, force shut down by holding power 5 s and only then start F2 + Power. And it worked!
    The link from "dt1" also very practical, probably it would also be effective, but since the first one played, I have no way to check. :)
    Thanks a lot!!! I close the topic.
  • #7 17332281
    kopcisię
    Rate: 17
    Thanks "damkon"!
    Added after 7 [minutes]:
    The use of a "hard" reset helped avoid disassembling the laptop.
    Eh, where are these laptops with removable batteries!
✨ The ASUS F555LJ-XO948T laptop running Windows 10 is experiencing issues accessing the BIOS using the F2 key during startup. Users suggested alternative methods, including pressing Esc followed by Power, and performing a hard reset by holding the power button for 5 seconds before attempting F2 + Power. These solutions proved effective in resolving the access issue, allowing the user to enter the BIOS without disassembling the laptop.
