Calculating Resistor Values for Voltage Reduction from 12V to 4-5V for Fans and LEDs
Ash Ketchum 96274 4
  • #1 1395462
    Ash Ketchum
    Help: 39
    Rate: 79
    What is the formula for the voltage drop across a resistor? I mean the formula by which I can count, for example, the value of a resistor that allows to lower the fan voltage from 12V to about 4-5V (or a potentiometer) or to power the led from 12V.
  • #2 1395504
    Piter102
    Rate: 9
    Ohm's Law: The ratio of voltage to current is constant. (R = U / I) and is called the electrical resistance. You need to know the electricity.
    Added after 16 [seconds]:
  • #3 1395526
    Ash Ketchum
    Help: 39
    Rate: 79
    And how to calculate the current for a windmill for example. Do you follow its rated current stated on the label? This is probably the current for the rated voltage (12V). How to calculate the current for a lower voltage, e.g. 4-5V?
  • #4 1395910
    robert_bytom
    Help: 12
    Rate: 20
    If you have given the current for 12V, the current for the lower voltage is proportionally lower (e.g. for 6V it will also be half the value).
  • #5 1396268
    Paweł Es.
    Help: 1236
    Rate: 693
    It has to be measured, it cannot be counted directly.
    In addition, the starting current must be taken into account. It cannot be too small because the fan will not start.
    It is good to have a regulated power supply, choose the voltage so that the fan rotates at the desired speed and measure the current consumed.
    We have:
    Uz - measured voltage from the regulated power supply
    Iz - current consumed at this voltage
    Ucc - target supply voltage
    In steady state (i.e. when the fan is rotating at a constant speed)
    Ucc = Uz + Iz * Rx
    Rx - series resistor
    that is
    Rx = (Ucc-Uz) / Iz
    The power of the series resistor must be greater than
    Prx> (Ucc-Uz) * Iz in Watts
    For such a circuit to start reliably, an electrolytic capacitor of 470 uF or more can be placed in parallel to the series resistor.
    At the moment of starting, the charging current of this capacitor will give a current pulse to facilitate starting. After charging to voltage (Ucc-Uz), the current stops flowing and we have a voltage on the fan limited by a resistor.
    When the power is turned off, the capacitor discharges through the limiting resistor.
    As for the rated current written on the housing, I measured myself an Adda Corp brushless motor. AD0812MS-A70 a little used already (plain bearings)
    According to what is on the housing, it consumes 120 mA at 12V
    According to tables from ADDA Corp. this type draws 150 mA at 12V
    And according to measurements:
    [code:1:41dfb82822]
    Uz Iz
    12V 190 mA
    11V 171 mA
    10V 151 mA
    9V 133 mA
    8V 116 mA
    7V 99 mA
    6V 81 mA
    5V 63 mA
    4V 45 mA (niestabilnie)
    Rx = (Ucc-N * Ud) / Id
    N - number of diodes connected in series
    Id - diode current 10-20 mA
    Ud - voltage drop on one diode (from 1.8 to 4.1V depending on the color and Id current)
    Ucc supply voltage
    The power of the resistor must be greater than:
    Prx> (Ucc-N * Ud) * Id
    • Calculating Resistor Values for Voltage Reduction from 12V to 4-5V for Fans and LEDs wentyl.jpg (5.63 KB) You must be logged in to download this attachment.
