Hello, I have a problem, maybe someone knows what resistor to use to change the voltage such as in the topic from 12v to 5v with a current of 0.5A in advance, thank you
msichal wrote:The resistor does not reduce the voltage, only the current ...
Jacek79 wrote:msichal wrote:The resistor does not reduce the voltage, only the current ...
It is very surprising. Can you justify it somehow? I am the one who pops up with my resistor theorem - the power to this thing stuck on the other side of the resistor decreases.
damian3219 wrote:These are loudspeakers, for example, for mp3 and I want to connect them in the car so that the current is drawn from the battery and not from the battery because they discharge too quickly
karolglinik wrote:Hi. and I need a 9V in my car. As you know, the voltage in a car is variable, from 11 to 14V approx. Will I get a voltage of 9V using a 9V voltage stabilizer, or will it change? These stabilizers have 3 feet, how do you connect?
I plan to connect a voltmeter to this 9V source, which will measure the voltage on the battery. not sure if it will work out
karolglinik wrote:when it comes to the LM78L09A stabilizer, I gave 2 capacitors as shown in the catalog, I gave a 1uF and 0.5uF capacitor (in the catalog, tests were done with 0.33 and 0.1uF capacitors) and this system does not work (I also gave a diode to load the circuit). I am not sure if I connected the capacitors correctly. In electrolytic condition, how to recognize which pin is on "+" and which on GND. It is probably looking at the strip on the capacitor. Or maybe I gave too little legs?
sanmar wrote:This is a normal phenomenon in this system, the excess voltage is deposited on the stabilizer itself. Calculate the power based on the data - voltage drop on the stabilizer 24-12 = 12V times the current taken from the stabilizer output (100mA) gives: 12x0.1 = 1.2W.the only problem is the heating of this stabilizer
sanmar wrote:It's not possible. It must be - but for consolation - relatively small - for example: https://www.piekarz.pl/pl/?item=48275. You can also use the housing (as long as it is metal and you will isolate the stabilizer (plate) from it).not using any heat sink
trymer01 wrote:Of course - but the total amount of heat will not decrease by this.you can use a resistor but 100 Ohm with a power of min. 2W (better 3-5W) connected in series before the stabilizer, which will reduce the input voltage seen by the stabilizer and reduce the power of losses (the amount of heat) on it.
sanmar wrote:you have to take other data 12 / 0.1 = 120 ohms and also 5 W
sanmar wrote:the device is very small and in addition it is in a plastic housing, so I can not use any heat sink. The point is not so much that it heats up, but that the element does not heat up so much, that is, that it all spreads to both the resistor and the stabilizer
TL;DR: Dropping 12 V to 5 V @ 0.5 A by resistor burns 3.5 W—“not the best idea” [Elektroda, mr.Sławek, post #6810120] 7805 needs 3 V headroom and wastes 1.2 W/0.1 A [Elektroda, 398216, #16520553; etezet, #6871789].
Why it matters: Picking the wrong method overheats parts, drains batteries, and can kill audio gear or USB devices.
